[Liblas-commits] hg: get rid of SizesArray junk
liblas-commits at liblas.org
Sat Oct 9 22:36:40 EDT 2010
changeset 684912262acb in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=684912262acb
summary: get rid of SizesArray junk
diffstat:
include/liblas/lasdimension.hpp | 46 ++++++++++++++++++++++++++++++--------
include/liblas/lasschema.hpp | 6 +----
src/las_c_api.cpp | 33 +++++++++++++++++++++++++--
src/lasdimension.cpp | 15 +++++++-----
src/laspoint.cpp | 10 +++++---
src/lasschema.cpp | 49 +++++++++++++++++++---------------------
6 files changed, 105 insertions(+), 54 deletions(-)
diffs (truncated from 354 to 300 lines):
diff -r 2fe4df7bda66 -r 684912262acb include/liblas/lasdimension.hpp
--- a/include/liblas/lasdimension.hpp Sat Oct 09 18:17:39 2010 -0500
+++ b/include/liblas/lasdimension.hpp Sat Oct 09 21:36:25 2010 -0500
@@ -70,22 +70,21 @@
namespace liblas {
-typedef boost::array<std::size_t, 4> SizesArray;
/// Dimension definition
class Dimension
public:
- Dimension(std::string const& name, boost::uint32_t size_in_bits);
+ Dimension(std::string const& name, std::size_t size_in_bits);
Dimension& operator=(Dimension const& rhs);
Dimension(Dimension const& other);
virtual ~Dimension() {};
- std::string const& GetName() const { return m_name; }
+ inline std::string const& GetName() const { return m_name; }
- /// bits, logical size of point record
- std::size_t GetBitSize() const
+ /// bits, total logical size of point record, including any custom
+ /// dimensions
+ inline std::size_t GetBitSize() const
return m_bit_size;
@@ -93,6 +92,34 @@
/// bytes, physical/serialisation size of record
std::size_t GetByteSize() const;
+ /// The byte location to start reading/writing
+ /// point data from in a composited schema. liblas::Schema
+ /// will set these values for you when liblas::Dimension are
+ /// added to the liblas::Schema.
+ inline std::size_t GetByteOffset() const
+ return m_byte_offset;
+ inline void SetByteOffset(std::size_t v)
+ m_byte_offset = v;
+ /// The bit location within the byte to start reading data. liblas::Schema
+ /// added to the liblas::Schema. This value will be 0 for dimensions
+ /// that are composed of entire bytes.
+ inline std::size_t GetBitOffset() const
+ return m_bit_offset;
+ inline void SetBitOffset(std::size_t v)
+ m_bit_offset = v;
/// Is this dimension required by PointFormatName
bool IsRequired() const { return m_required; }
void IsRequired(bool v) { m_required = v; }
@@ -151,12 +178,10 @@
return m_position > dim.m_position;
- SizesArray const& GetSizes() const { return m_sizes; }
- void SetSizes(SizesArray const& a) { m_sizes = a; }
private:
std::string m_name;
- boost::uint32_t m_bit_size;
+ std::size_t m_bit_size;
bool m_required;
bool m_active;
std::string m_description;
@@ -169,7 +194,8 @@
double m_scale;
bool m_precise;
double m_offset;
- SizesArray m_sizes;
+ std::size_t m_byte_offset;
+ std::size_t m_bit_offset;
diff -r 2fe4df7bda66 -r 684912262acb include/liblas/lasschema.hpp
--- a/include/liblas/lasschema.hpp Sat Oct 09 18:17:39 2010 -0500
+++ b/include/liblas/lasschema.hpp Sat Oct 09 21:36:25 2010 -0500
@@ -75,8 +75,6 @@
namespace liblas {
typedef std::vector<Dimension> DimensionArray;
-typedef boost::unordered_map<std::string, SizesArray> SizesMap;
using namespace boost::multi_index;
@@ -132,7 +130,7 @@
void AddDimension(Dimension const& dim);
Dimension const& GetDimension(std::string const& n) const;
- // Dimension& GetDimension(std::string const& n);
+ Dimension const& GetDimension(index_by_index::size_type t) const;
// DimensionPtr GetDimension(std::size_t index) const;
void RemoveDimension(Dimension const& dim);
@@ -142,8 +140,6 @@
std::vector<std::string> GetDimensionNames() const;
IndexMap const& GetDimensions() const { return m_index; }
liblas::property_tree::ptree GetPTree() const;
- SizesArray const& GetSizes(std::string const& n) const;
- SizesArray const& GetSizes(std::size_t pos) const;
boost::uint16_t GetSchemaVersion() const { return m_schemaversion; }
void SetSchemaVersion(boost::uint16_t v) { m_schemaversion = v; }
diff -r 2fe4df7bda66 -r 684912262acb src/las_c_api.cpp
--- a/src/las_c_api.cpp Sat Oct 09 18:17:39 2010 -0500
+++ b/src/las_c_api.cpp Sat Oct 09 21:36:25 2010 -0500
@@ -666,7 +666,14 @@
try {
((liblas::Point*) hPoint)->SetTime(value);
- } catch (std::exception const& e)
+ catch (std::runtime_error const&)
+ // drop the value on the floor. If the point has a schema that
+ // doesn't have time, the user needs to change the point's header.
+ catch (std::exception const& e)
LASError_PushError(LE_Failure, e.what(), "LASPoint_SetTime");
return LE_Failure;
@@ -680,7 +687,14 @@
VALIDATE_LAS_POINTER1(hPoint, "LASPoint_GetTime", 0.0);
- double value = ((liblas::Point*) hPoint)->GetTime();
+ double value = 0.0;
+ try {
+ value = ((liblas::Point*) hPoint)->GetTime();
+ } catch (std::runtime_error const&)
return value;
@@ -1790,7 +1804,14 @@
LAS_DLL LASColorH LASPoint_GetColor(const LASPointH hPoint) {
VALIDATE_LAS_POINTER1(hPoint, "LASPoint_GetColor", 0);
- liblas::Color color = ((liblas::Point*) hPoint)->GetColor();
+ liblas::Color color;
+ try {
+ color = ((liblas::Point*) hPoint)->GetColor();
return (LASColorH) new liblas::Color(color);
@@ -1802,6 +1823,12 @@
try {
((liblas::Point*) hPoint)->SetColor(*((liblas::Color*)hColor));
+ // doesn't have color, the user needs to change the point's header.
catch (std::exception const& e) {
LASError_PushError(LE_Failure, e.what(), "LASPoint_SetColor");
return LE_Failure;
diff -r 2fe4df7bda66 -r 684912262acb src/lasdimension.cpp
--- a/src/lasdimension.cpp Sat Oct 09 18:17:39 2010 -0500
+++ b/src/lasdimension.cpp Sat Oct 09 21:36:25 2010 -0500
@@ -62,7 +62,7 @@
namespace liblas {
-Dimension::Dimension(std::string const& name, boost::uint32_t size_in_bits) :
+Dimension::Dimension(std::string const& name, std::size_t size_in_bits) :
m_name(name),
m_bit_size(size_in_bits),
m_required(false),
@@ -73,14 +73,15 @@
m_numeric(false),
m_signed(false),
m_integer(false),
- m_position(0)
+ m_position(0),
+ m_byte_offset(0),
+ m_bit_offset(0)
if (size_in_bits == 0) {
std::ostringstream oss;
oss << "The bit size of the dimension is 0, the dimension is invalid.";
throw std::runtime_error(oss.str());
- m_sizes.assign(0);
/// copy constructor
@@ -96,7 +97,8 @@
, m_signed(other.m_signed)
, m_integer(other.m_integer)
, m_position(other.m_position)
- , m_sizes(other.m_sizes)
+ , m_byte_offset(other.m_byte_offset)
+ , m_bit_offset(other.m_bit_offset)
@@ -116,7 +118,8 @@
m_signed = rhs.m_signed;
m_integer = rhs.m_integer;
m_position = rhs.m_position;
- m_sizes = rhs.m_sizes;
+ m_byte_offset = rhs.m_byte_offset;
+ m_bit_offset = rhs.m_bit_offset;
return *this;
diff -r 2fe4df7bda66 -r 684912262acb src/laspoint.cpp
--- a/src/laspoint.cpp Sat Oct 09 18:17:39 2010 -0500
+++ b/src/laspoint.cpp Sat Oct 09 21:36:25 2010 -0500
@@ -822,13 +822,15 @@
std::vector<boost::uint8_t>::size_type Point::GetDimensionBytePosition(std::size_t dim_pos) const
- SizesArray s;
+ std::size_t output = 0;
if (m_header) {
- s = m_header->GetSchema().GetSizes(dim_pos);
+ Dimension const& d = m_header->GetSchema().GetDimension(dim_pos);
+ output = d.GetByteOffset();
} else {
- s = m_default_header.GetSchema().GetSizes(dim_pos);
+ Dimension const& d = m_default_header.GetSchema().GetDimension(dim_pos);
- return s[0];
+ return output;
diff -r 2fe4df7bda66 -r 684912262acb src/lasschema.cpp
--- a/src/lasschema.cpp Sat Oct 09 18:17:39 2010 -0500
+++ b/src/lasschema.cpp Sat Oct 09 21:36:25 2010 -0500
@@ -609,13 +609,6 @@
return false;
-SizesArray const& Schema::GetSizes(std::size_t pos) const
- index_by_index const& idx = m_index.get<index>();
- Dimension const& dim = idx.at(pos);
- return dim.GetSizes();
void Schema::CalculateSizes()
@@ -624,8 +617,8 @@
index_by_position& position_index = m_index.get<position>();
- std::size_t index_position = 0;
- std::size_t bit_position = 0;
+ std::size_t byte_offset = 0;
+ std::size_t bit_offset = 0;
for (index_by_position::iterator i = position_index.begin();
i != position_index.end();
@@ -634,26 +627,21 @@
Dimension t = (*i);
m_bit_size += t.GetBitSize();
- std::size_t byte_size = 0;
- bit_position = bit_position + (t.GetBitSize() % 8);
+ bit_offset = bit_offset + (t.GetBitSize() % 8);
// std::cout << "position : " << t->GetPosition() << " index_position: " << index_position;
// std::cout << " d: " << t->GetName() << " bit_position: " << bit_position<<std::endl;
// std::cout << "bit_size: " << t->GetBitSize() << std::endl;
- SizesArray a;
- a[0] = index_position;
More information about the Liblas-commits
