[Liblas-commits] hg: 5 new changesets
liblas-commits at liblas.org
Sat Oct 9 23:37:08 EDT 2010
changeset c3acfa1a75ec in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c3acfa1a75ec
summary: rename m_format_data to m_data
changeset ebc2212ae196 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ebc2212ae196
summary: cleanup, move term_progress to kernel for reuse
changeset 31b0383b2743 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=31b0383b2743
summary: cleanups
changeset 0e4a8bfc5206 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0e4a8bfc5206
summary: inline methods, add some docs
changeset 1b4e0a36cdd8 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1b4e0a36cdd8
summary: update SetHeaderPtr to do some accounting when the schema appears to change
diffstat:
apps/las2las2.cpp | 41 -----------
apps/laskernel.cpp | 30 ++++++++
apps/laskernel.hpp | 1 +
include/liblas/lasdimension.hpp | 61 +++++++++-------
include/liblas/laspoint.hpp | 7 +-
src/laspoint.cpp | 145 +++++++++++++++++++++++++++------------
src/lasschema.cpp | 50 ++-----------
7 files changed, 176 insertions(+), 159 deletions(-)
diffs (truncated from 752 to 300 lines):
diff -r 684912262acb -r 1b4e0a36cdd8 apps/las2las2.cpp
--- a/apps/las2las2.cpp Sat Oct 09 21:36:25 2010 -0500
+++ b/apps/las2las2.cpp Sat Oct 09 22:36:54 2010 -0500
@@ -15,52 +15,11 @@
#include <boost/cstdint.hpp>
#include <boost/foreach.hpp>
-typedef boost::tokenizer<boost::char_separator<char> > tokenizer;
namespace po = boost::program_options;
using namespace liblas;
using namespace std;
-#ifdef _WIN32
-#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
-#else
-#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
-#endif
-bool term_progress(std::ostream& os, double complete)
- static int lastTick = -1;
- int tick = static_cast<int>(complete * 40.0);
- tick = std::min(40, std::max(0, tick));
- // Have we started a new progress run?
- if (tick < lastTick && lastTick >= 39)
- lastTick = -1;
- if (tick <= lastTick)
- return true;
- while (tick > lastTick)
- lastTick++;
- if (lastTick % 4 == 0)
- os << (lastTick / 4) * 10;
- else
- os << ".";
- if( tick == 40 )
- os << " - done.\n";
- else
- os.flush();
- return true;
liblas::Writer* start_writer( std::ofstream* strm,
std::string const& output,
liblas::Header const& header)
diff -r 684912262acb -r 1b4e0a36cdd8 apps/laskernel.cpp
--- a/apps/laskernel.cpp Sat Oct 09 21:36:25 2010 -0500
+++ b/apps/laskernel.cpp Sat Oct 09 22:36:54 2010 -0500
@@ -56,6 +56,36 @@
+bool term_progress(std::ostream& os, double complete)
+ static int lastTick = -1;
+ int tick = static_cast<int>(complete * 40.0);
+ tick = std::min(40, std::max(0, tick));
+ // Have we started a new progress run?
+ if (tick < lastTick && lastTick >= 39)
+ lastTick = -1;
+ if (tick <= lastTick)
+ return true;
+ while (tick > lastTick)
+ lastTick++;
+ if (lastTick % 4 == 0)
+ os << (lastTick / 4) * 10;
+ else
+ os << ".";
+ if( tick == 40 )
+ os << " - done.\n";
+ else
+ os.flush();
+ return true;
bool IsDualRangeFilter(std::string parse_string)
diff -r 684912262acb -r 1b4e0a36cdd8 apps/laskernel.hpp
--- a/apps/laskernel.hpp Sat Oct 09 21:36:25 2010 -0500
+++ b/apps/laskernel.hpp Sat Oct 09 22:36:54 2010 -0500
@@ -94,5 +94,6 @@
std::istream* OpenInput(std::string filename, bool bEnd);
std::string TryReadFileData(std::string filename);
std::vector<char> TryReadRawFileData(std::string filename);
+bool term_progress(std::ostream& os, double complete);
#endif // LIBLAS_ITERATOR_HPP_INCLUDED
diff -r 684912262acb -r 1b4e0a36cdd8 include/liblas/lasdimension.hpp
--- a/include/liblas/lasdimension.hpp Sat Oct 09 21:36:25 2010 -0500
+++ b/include/liblas/lasdimension.hpp Sat Oct 09 22:36:54 2010 -0500
@@ -121,59 +121,68 @@
/// Is this dimension required by PointFormatName
- bool IsRequired() const { return m_required; }
- void IsRequired(bool v) { m_required = v; }
+ inline bool IsRequired() const { return m_required; }
+ inline void IsRequired(bool v) { m_required = v; }
/// Is this dimension being used. A dimension with
/// IsActive false may exist as a placeholder in PointFormatName-specified
/// dimensions, but have their IsActive flag set to false. In this
/// case, those values may be disregarded.
- bool IsActive() const { return m_active; }
- void IsActive(bool v) { m_active = v; }
+ inline bool IsActive() const { return m_active; }
+ inline void IsActive(bool v) { m_active = v; }
- std::string GetDescription() const { return m_description; }
- void SetDescription(std::string const& v) { m_description = v; }
+ inline std::string GetDescription() const { return m_description; }
+ inline void SetDescription(std::string const& v) { m_description = v; }
/// Is this dimension a numeric dimension. Dimensions with IsNumeric == false
/// are considered generic bit/byte fields/
- bool IsNumeric() const { return m_numeric ; }
- void IsNumeric(bool v) { m_numeric = v; }
+ inline bool IsNumeric() const { return m_numeric ; }
+ inline void IsNumeric(bool v) { m_numeric = v; }
/// Does this dimension have a sign? Only applicable to dimensions with
/// IsNumeric == true.
- bool IsSigned() const { return m_signed; }
- void IsSigned(bool v) { m_signed = v; }
+ inline bool IsSigned() const { return m_signed; }
+ inline void IsSigned(bool v) { m_signed = v; }
/// Does this dimension interpret to an integer? Only applicable to dimensions
/// with IsNumeric == true.
- bool IsInteger() const { return m_integer; }
- void IsInteger(bool v) { m_integer = v; }
+ inline bool IsInteger() const { return m_integer; }
+ inline void IsInteger(bool v) { m_integer = v; }
/// The minimum value of this dimension as a double
- double GetMinimum() const { return m_min; }
- void SetMinimum(double min) { m_min = min; }
+ inline double GetMinimum() const { return m_min; }
+ inline void SetMinimum(double min) { m_min = min; }
/// The maximum value of this dimension as a double
- double GetMaximum() const { return m_max; }
- void SetMaximum(double max) { m_max = max; }
+ inline double GetMaximum() const { return m_max; }
+ inline void SetMaximum(double max) { m_max = max; }
- boost::uint32_t GetPosition() const { return m_position; }
- void SetPosition(boost::uint32_t v) { m_position = v; }
+ /// The index position of the index. In a standard ePointFormat0
+ /// data record, the X dimension would have a position of 0, while
+ /// the Y dimension would have a position of 1, for example.
+ inline boost::uint32_t GetPosition() const { return m_position; }
+ inline void SetPosition(boost::uint32_t v) { m_position = v; }
- double GetScale() const { return m_scale; }
- void SetScale(double v) { m_scale = v; }
+ /// The scaling value for this dimension as a double. This should
+ /// be positive or negative powers of ten.
+ inline double GetScale() const { return m_scale; }
+ inline void SetScale(double v) { m_scale = v; }
- double GetOffset() const { return m_offset; }
- void SetOffset(double v) { m_offset = v; }
+ /// The offset value for this dimension. Usually zero, but it
+ /// can be set to any value in combination with the scale to
+ /// allow for more expressive ranges.
+ inline double GetOffset() const { return m_offset; }
+ inline void SetOffset(double v) { m_offset = v; }
- bool IsFinitePrecision() const { return m_precise; }
- void IsFinitePrecision(bool v) { m_precise = v; }
+ /// If true, this dimension uses scale/offset values
+ inline bool IsFinitePrecision() const { return m_precise; }
+ inline void IsFinitePrecision(bool v) { m_precise = v; }
- bool operator < (Dimension const& dim) const
+ inline bool operator < (Dimension const& dim) const
return m_position < dim.m_position;
- bool operator > (Dimension const& dim) const
+ inline bool operator > (Dimension const& dim) const
return m_position > dim.m_position;
diff -r 684912262acb -r 1b4e0a36cdd8 include/liblas/laspoint.hpp
--- a/include/liblas/laspoint.hpp Sat Oct 09 21:36:25 2010 -0500
+++ b/include/liblas/laspoint.hpp Sat Oct 09 22:36:54 2010 -0500
@@ -196,8 +196,8 @@
bool IsValid() const;
- std::vector<boost::uint8_t> const& GetData() const {return m_format_data; }
- void SetData(std::vector<boost::uint8_t> const& v) { m_format_data = v;}
+ std::vector<boost::uint8_t> const& GetData() const {return m_data; }
+ void SetData(std::vector<boost::uint8_t> const& v) { m_data = v;}
void SetHeaderPtr(HeaderPtr header);
HeaderPtr GetHeaderPtr() const;
@@ -208,8 +208,7 @@
private:
- detail::PointRecord m_record;
- std::vector<boost::uint8_t> m_format_data;
+ std::vector<boost::uint8_t> m_data;
std::vector<boost::uint8_t>::size_type GetDimensionBytePosition(std::size_t dim_pos) const;
HeaderPtr m_header;
diff -r 684912262acb -r 1b4e0a36cdd8 src/laspoint.cpp
--- a/src/laspoint.cpp Sat Oct 09 21:36:25 2010 -0500
+++ b/src/laspoint.cpp Sat Oct 09 22:36:54 2010 -0500
@@ -56,6 +56,7 @@
#include <vector>
#include <iosfwd>
#include <algorithm>
+#include <numeric>
using namespace boost;
@@ -65,20 +66,20 @@
: m_header(HeaderPtr())
, m_default_header(DefaultHeader::get())
- m_format_data.resize(ePointSize3);
- m_format_data.assign(ePointSize3, 0);
+ m_data.resize(ePointSize3);
+ m_data.assign(ePointSize3, 0);
Point::Point(HeaderPtr hdr)
: m_header(hdr)
Point::Point(Point const& other)
- : m_format_data(other.m_format_data)
+ : m_data(other.m_data)
, m_header(other.m_header)
@@ -88,7 +89,7 @@
if (&rhs != this)
- m_format_data = rhs.m_format_data;
+ m_data = rhs.m_data;
m_header = rhs.m_header;
return *this;
@@ -189,6 +190,58 @@
void Point::SetHeaderPtr(HeaderPtr header)
+ boost::uint16_t length;
+ if (m_header)
+ length = m_header->GetDataRecordLength();
+ else
+ length = m_default_header.GetDataRecordLength();
+ // This is hopefully faster than copying everything if we don't have
+ // any data set and nothing to worry about.
+ boost::uint32_t sum = std::accumulate(m_data.begin(), m_data.end(), 0);
+ if (length != m_data.size() || sum != 0)
+ // Manually copy everything but the header ptr
+ // We can't just copy the raw data because its
+ // layout is likely changing as a result of the
+ // schema change.
+ Point p(*this);
+ m_data.resize(length);
+ m_data.assign(length, 0);
+ SetX(p.GetX());
More information about the Liblas-commits
