[Liblas-commits] hg: use detail::compare instead of doing
float/double direction ...
liblas-commits at liblas.org
Sat Oct 9 23:44:37 EDT 2010
changeset 78a0c6ee1dab in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=78a0c6ee1dab
summary: use detail::compare instead of doing float/double direction comparisons
diffstat:
src/lasschema.cpp | 4 ++--
1 files changed, 2 insertions(+), 2 deletions(-)
diffs (14 lines):
diff -r b0dc48696c07 -r 78a0c6ee1dab src/lasschema.cpp
--- a/src/lasschema.cpp Sat Oct 09 22:37:59 2010 -0500
+++ b/src/lasschema.cpp Sat Oct 09 22:44:31 2010 -0500
@@ -476,8 +476,8 @@
dim.put("required", static_cast<boost::uint32_t>(t.IsRequired()));
if (t.IsNumeric()) {
- // FIXME use detail::compare
- if (t.GetMinimum() != t.GetMaximum() && t.GetMaximum() != 0)
+ if (! (detail::compare_distance(t.GetMinimum(), t.GetMaximum() )
+ && detail::compare_distance(0.0, t.GetMaximum())))
dim.put("minimum", t.GetMinimum());
dim.put("maximum", t.GetMaximum());
More information about the Liblas-commits
