[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org
Sun Oct 10 01:18:22 EDT 2010
changeset 02935c527273 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=02935c527273
summary: remove VLR summary from header output. User should loop through the VLRs and output them to the ostream if they want
changeset 32dbaa0b26ac in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=32dbaa0b26ac
summary: support setting SystemID and SoftwareID, move a few functions into kernel
changeset 6d082929d60e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6d082929d60e
summary: start on lasinfo2
diffstat:
apps/CMakeLists.txt | 8 +-
apps/las2las2.cpp | 85 --------------
apps/lasinfo2.cpp | 205 +++++++++++++++++++++++++++++++++++
apps/laskernel.cpp | 113 +++++++++++++++++++-
apps/laskernel.hpp | 3 +
include/liblas/lasvariablerecord.hpp | 3 +
include/liblas/utility.hpp | 11 +-
src/lasheader.cpp | 48 ++++----
src/lasvariablerecord.cpp | 18 +++
src/utility.cpp | 51 ++++++++
10 files changed, 429 insertions(+), 116 deletions(-)
diffs (truncated from 697 to 300 lines):
diff -r 78a0c6ee1dab -r 6d082929d60e apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Sat Oct 09 22:44:31 2010 -0500
+++ b/apps/CMakeLists.txt Sun Oct 10 00:18:09 2010 -0500
@@ -20,6 +20,7 @@
set(LAS2TXT las2txt)
set(TXT2LAS txt2las)
set(LAS2LAS2 las2las2 )
+set(LASINFO2 lasinfo2)
set(LASBLOCK lasblock )
set(BIGFILE_TEST bigfile_test)
@@ -42,7 +43,7 @@
set(LIBLAS_UTILITIES
${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
- ${LAS2OGR} ${LAS2OCI} ${LAS2LAS2} ${LASBLOCK})
+ ${LAS2OGR} ${LAS2OCI} ${LAS2LAS2} ${LASBLOCK} ${LASINFO2})
# TODO: Experimental and requires testing --mloskot
# Generate user-specific settings for Visual Studio project
@@ -89,6 +90,11 @@
target_link_libraries(${LAS2LAS2} ${APPS_CPP_DEPENDENCIES} ${Boost_LIBRARIES})
endif()
+if(LASINFO2)
+ add_executable(${LASINFO2} lasinfo2.cpp laskernel.cpp)
+ target_link_libraries(${LASINFO2} ${APPS_CPP_DEPENDENCIES} ${Boost_LIBRARIES})
+endif()
# Build las2txt
if(LAS2TXT)
set(LAS2TXT_SRC lascommon.c ${LAS2TXT}.c)
diff -r 78a0c6ee1dab -r 6d082929d60e apps/las2las2.cpp
--- a/apps/las2las2.cpp Sat Oct 09 22:44:31 2010 -0500
+++ b/apps/las2las2.cpp Sun Oct 10 00:18:09 2010 -0500
@@ -37,91 +37,6 @@
-void RepairHeader(liblas::Summary const& summary, std::string const& filename)
- std::ifstream ifs;
- if (!liblas::Open(ifs, filename.c_str()))
- std::ostringstream oss;
- oss << "Cannot open " << filename << "for read. Exiting...";
- throw std::runtime_error(oss.str());
- liblas::Reader reader(ifs);
- liblas::Header header = reader.GetHeader();
- ifs.close();
- for (boost::uint32_t i = 0; i < 5; i++)
- header.SetPointRecordsByReturnCount(i, 0);
- std::ios::openmode m = std::ios::out | std::ios::in | std::ios::binary | std::ios::ate;
- // Write a blank PointRecordsByReturnCount first
- std::ofstream ofs(filename.c_str(), m);
- liblas::Writer writer(ofs, header);
- ofs.close();
- liblas::property_tree::ptree tree = summary.GetPTree();
- try
- header.SetMin(tree.get<double>("minimum.x"),
- tree.get<double>("minimum.y"),
- tree.get<double>("minimum.z"));
- header.SetMax(tree.get<double>("maximum.x"),
- tree.get<double>("maximum.y"),
- tree.get<double>("maximum.z"));
- } catch (liblas::property_tree::ptree_bad_path const& e)
- std::cerr << "Unable to write header bounds info. Does the outputted file have any points?";
- return;
- try
- BOOST_FOREACH(ptree::value_type &v,
- tree.get_child("points_by_return"))
- boost::uint32_t i = v.second.get<boost::uint32_t>("id");
- boost::uint32_t count = v.second.get<boost::uint32_t>("count");
- header.SetPointRecordsByReturnCount(i-1, count);
- std::cerr << "Unable to write header point return count info. Does the outputted file have any points?";
- return;
- // Write our updated header with summary info
- std::ofstream ofs2(filename.c_str(), m);
- liblas::Writer writer2(ofs2, header);
- ofs2.close();
-void SetStreamPrecision(std::ostream& os, double scale)
- os.setf(std::ios_base::fixed, std::ios_base::floatfield);
- double frac = 0;
- double integer = 0;
- frac = std::modf(scale, &integer);
- boost::uint32_t prec = static_cast<boost::uint32_t>(std::fabs(std::floor(std::log10(frac))));
- os.precision(prec);
bool process( std::string const& input,
std::string const& output,
liblas::Header & header,
diff -r 78a0c6ee1dab -r 6d082929d60e apps/lasinfo2.cpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/apps/lasinfo2.cpp Sun Oct 10 00:18:09 2010 -0500
@@ -0,0 +1,205 @@
+ * Project: libLAS -- C/C++ read/write library for LAS LIDAR data
+ * Purpose: LAS information with optional configuration
+ * Author: Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler, hobu.inc at gmail.com
+ * See LICENSE.txt in this source distribution for more information.
+#include <liblas/liblas.hpp>
+#include "laskernel.hpp"
+#include <boost/cstdint.hpp>
+#include <boost/foreach.hpp>
+using namespace liblas;
+using namespace std;
+liblas::Summary check_points( liblas::Reader& reader,
+ std::vector<liblas::FilterPtr>& filters,
+ std::vector<liblas::TransformPtr>& transforms,
+ bool verbose)
+ liblas::Summary summary;
+ reader.SetFilters(filters);
+ reader.SetTransforms(transforms);
+ if (verbose)
+ std::cout << "Scanning points:"
+ << "\n - : "
+ << std::endl;
+ // Translation of points cloud to features set
+ boost::uint32_t i = 0;
+ boost::uint32_t const size = reader.GetHeader().GetPointRecordsCount();
+ while (reader.ReadNextPoint())
+ liblas::Point const& p = reader.GetPoint();
+ summary.AddPoint(p);
+ if (verbose)
+ term_progress(std::cout, (i + 1) / static_cast<double>(size));
+ i++;
+ if (verbose)
+ std::cout << std::endl;
+ return summary;
+void OutputHelp( std::ostream & oss, po::options_description const& options)
+ oss << "--------------------------------------------------------------------\n";
+ oss << " lasinfo2 (" << GetFullVersion() << ")\n";
+ oss << options;
+ oss <<"\nFor more information, see the full documentation for lasinfo2 at:\n";
+ oss << " http://liblas.org/utilities/lasinfo2.html\n";
+ oss << "----------------------------------------------------------\n";
+void PrintVLRs(std::ostream& os, liblas::Header& header)
+ if (!header.GetRecordsCount())
+ return ;
+ os << "---------------------------------------------------------" << std::endl;
+ os << " VLR Summary" << std::endl;
+ typedef std::vector<VariableRecord>::size_type size_type;
+ for(size_type i = 0; i < header.GetRecordsCount(); i++) {
+ liblas::VariableRecord const& v = header.GetVLR(i);
+ os << v;
+ os << std::endl;
+int main(int argc, char* argv[])
+ std::string input;
+ bool verbose = false;
+ bool check = true;
+ bool show_vlrs = true;
+ std::vector<liblas::FilterPtr> filters;
+ std::vector<liblas::TransformPtr> transforms;
+ liblas::Header header;
+ try {
+ po::options_description file_options("lasinfo2 options");
+ po::options_description filtering_options = GetFilteringOptions();
+ po::options_description header_options = GetHeaderOptions();
+ po::positional_options_description p;
+ p.add("input", 1);
+ p.add("output", 1);
+ file_options.add_options()
+ ("help,h", "produce help message")
+ ("input,i", po::value< string >(), "input LAS file")
+ ("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Verbose message output")
+ ("no-vlrs", po::value<bool>(&show_vlrs)->zero_tokens()->implicit_value(false), "Don't show VLRs")
+ ("no-check", po::value<bool>(&check)->zero_tokens()->implicit_value(false), "Don't scan points")
+ po::variables_map vm;
+ po::options_description options;
+ options.add(file_options).add(filtering_options);
+ po::store(po::command_line_parser(argc, argv).
+ options(options).positional(p).run(), vm);
+ po::notify(vm);
+ if (vm.count("help"))
+ OutputHelp(std::cout, options);
+ return 1;
+ if (vm.count("input"))
+ input = vm["input"].as< string >();
+ std::ifstream ifs;
+ if (verbose)
+ std::cout << "Opening " << input << " to fetch Header" << std::endl;
+ if (!liblas::Open(ifs, input.c_str()))
+ std::cerr << "Cannot open " << input << "for read. Exiting...";
+ return 1;
+ liblas::Reader reader(ifs);
+ header = reader.GetHeader();
+ } else {
+ std::cerr << "Input LAS file not specified!\n";
+ return 1;
+ filters = GetFilters(vm, verbose);
More information about the Liblas-commits
