[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Oct 12 13:15:59 EDT 2010
changeset 65a0e377811e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=65a0e377811e
summary: Tweaked binary data access to not to calculate position of iterator but pointer in continuous memory block.
changeset 2dcb73ca71fd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2dcb73ca71fd
summary: merge
diffstat:
 apps/CMakeLists.txt                                                         |    36 +-
 apps/las2las-old.c                                                          |  1163 ++++++++++
 apps/las2las.c                                                              |  1163 ----------
 apps/las2las.cpp                                                            |   348 ++
 apps/las2las2.cpp                                                           |   348 --
 apps/lasinfo-old.c                                                          |   418 +++
 apps/lasinfo.c                                                              |   418 ---
 apps/lasinfo.cpp                                                            |   241 ++
 apps/lasinfo2.cpp                                                           |   205 -
 doc/utilities/index.txt                                                     |     3 +-
 doc/utilities/las2las-old.txt                                               |   159 +
 doc/utilities/las2las.txt                                                   |   315 ++-
 doc/utilities/las2las2.txt                                                  |   354 ---
 doc/utilities/lasinfo-old.txt                                               |   138 +
 doc/utilities/lasinfo.txt                                                   |   183 +-
 include/liblas/detail/binary.hpp                                            |     1 +
 include/liblas/detail/private_utility.hpp                                   |     8 +-
 include/liblas/external/property_tree/detail/xml_parser_writer_settings.hpp |    12 +-
 include/liblas/lasdimension.hpp                                             |     4 +-
 src/lasdimension.cpp                                                        |    45 +
 src/lasheader.cpp                                                           |     2 +
 src/lasschema.cpp                                                           |    39 +-
 src/utility.cpp                                                             |   178 +-
 23 files changed, 3062 insertions(+), 2719 deletions(-)
diffs (truncated from 6111 to 300 lines):
diff -r 5c3ee7cacba8 -r 2dcb73ca71fd apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Tue Oct 12 17:02:41 2010 +0100
+++ b/apps/CMakeLists.txt	Tue Oct 12 18:16:59 2010 +0100
@@ -14,13 +14,13 @@
 # Collect programs to build
+set(LASINFO_OLD lasinfo-old)
 set(LASINFO lasinfo)
 set(LASMERGE lasmerge)
 set(LAS2LAS las2las)
+set(LAS2LAS_OLD las2las-old)
 set(LAS2TXT las2txt)
 set(TXT2LAS txt2las)
-set(LAS2LAS2 las2las2 )
-set(LASINFO2 lasinfo2)
 set(LASBLOCK lasblock )
 set(BIGFILE_TEST bigfile_test)
@@ -42,8 +42,8 @@
 endif()
 set(LIBLAS_UTILITIES
-    ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
-    ${LAS2OGR}  ${LAS2OCI} ${LAS2LAS2} ${LASBLOCK} ${LASINFO2})
+    ${LASINFO_OLD} ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
+    ${LAS2OGR}  ${LAS2OCI} ${LAS2LAS} ${LAS2LAS_OLD} ${LASBLOCK} )
 # TODO: Experimental and requires testing --mloskot
 # Generate user-specific settings for Visual Studio project
@@ -72,27 +72,27 @@
 link_directories(${Boost_LIBRARY_DIRS})
 # Build lasinfo
-if(LASINFO)
-    set(LASINFO_SRC lascommon.c ${LASINFO}.c)
-    add_executable(${LASINFO} ${LASINFO_SRC})
-    target_link_libraries(${LASINFO} ${LIBLAS_C_LIB_NAME})
+if(LASINFO_OLD)
+    set(LASINFO_OLD_SRC lascommon.c ${LASINFO_OLD}.c)
+    add_executable(${LASINFO_OLD} ${LASINFO_OLD_SRC})
+    target_link_libraries(${LASINFO_OLD} ${LIBLAS_C_LIB_NAME})
 endif()
 # Build las2las
-if(LAS2LAS)
-    set(LAS2LAS_SRC lascommon.c ${LAS2LAS}.c)
-    add_executable(${LAS2LAS} ${LAS2LAS_SRC})
-    target_link_libraries(${LAS2LAS} ${LIBLAS_C_LIB_NAME})
+if(LAS2LAS_OLD)
+    set(LAS2LAS_OLD_SRC lascommon.c ${LAS2LAS_OLD}.c)
+    add_executable(${LAS2LAS_OLD} ${LAS2LAS_OLD_SRC})
+    target_link_libraries(${LAS2LAS_OLD} ${LIBLAS_C_LIB_NAME})
 endif()
-if(LAS2LAS2)
-    add_executable(${LAS2LAS2} las2las2.cpp laskernel.cpp)
-    target_link_libraries(${LAS2LAS2} ${APPS_CPP_DEPENDENCIES} ${Boost_LIBRARIES})
+if(LAS2LAS)
+    add_executable(${LAS2LAS} las2las.cpp laskernel.cpp)
+    target_link_libraries(${LAS2LAS} ${APPS_CPP_DEPENDENCIES} ${Boost_LIBRARIES})
 endif()
-if(LASINFO2)
-    add_executable(${LASINFO2} lasinfo2.cpp laskernel.cpp)
-    target_link_libraries(${LASINFO2} ${APPS_CPP_DEPENDENCIES} ${Boost_LIBRARIES})
+if(LASINFO)
+    add_executable(${LASINFO} lasinfo.cpp laskernel.cpp)
+    target_link_libraries(${LASINFO} ${APPS_CPP_DEPENDENCIES} ${Boost_LIBRARIES})
 endif()
 # Build las2txt
diff -r 5c3ee7cacba8 -r 2dcb73ca71fd apps/las2las-old.c
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/apps/las2las-old.c	Tue Oct 12 18:16:59 2010 +0100
@@ -0,0 +1,1163 @@
+ * $Id$
+ * $Date$
+ * Project: libLAS -- C/C++ read/write library for LAS LIDAR data
+ * Purpose: LAS translation with optional configuration
+ * Author:  Martin Isenburg isenburg at cs.unc.edu
+ * Copyright (c) 2007, Martin Isenburg isenburg at cs.unc.edu
+ * See LICENSE.txt in this source distribution for more information.
+#include "liblas.h"
+/* std */
+#include <assert.h>
+#include <time.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#ifdef _WIN32
+#define compare_no_case(a,b,n)  _strnicmp( (a), (b), (n) )
+#else
+#define compare_no_case(a,b,n)  strncasecmp( (a), (b), (n) )
+#endif
+LASPointSummary* SummarizePoints(LASReaderH reader);
+void print_point_summary(FILE *file, LASPointSummary* summary, LASHeaderH header);
+void print_point(FILE *file, LASPointH point);
+void print_header(FILE *file, LASHeaderH header, const char* file_name, int bSkipVLR);
+void repair_header(FILE *file, LASHeaderH header, LASPointSummary* summary) ;
+#define LAS_FORMAT_10 0
+#define LAS_FORMAT_11 1
+#define LAS_FORMAT_12 2
+void do_bulk_copy(const char* infile, size_t in_start_point, const char* outfile)
+    /* bulk copy assumes that the header has already been written to outfile
+       as it is supposed to be, and that we're just going to copy all of the
+       points in infile as they are.
+    FILE* file_out = 0;
+    FILE* file_in = 0;
+    size_t read = 0;
+    size_t written = 0;
+    size_t size = 1000;
+    char *buffer = 0;
+    buffer = (char*) malloc(size * sizeof(char));
+    if (buffer == 0) {
+        LASError_Print("unable to allocate buffer copy");
+        exit(1);
+    file_in = fopen(infile, "rb");
+    fseek(file_in, in_start_point, SEEK_SET);
+    if (file_in == 0) {
+        LASError_Print("input filename not valid for bulk copy");
+        exit(1);
+    file_out = fopen(outfile, "ab+");
+    if (file_out == 0) {
+        LASError_Print("output filename not valid for bulk copy");
+        exit(1);
+    while (feof(file_in) == 0) {
+        read = fread(buffer, 1, size, file_in);
+        written = fwrite(buffer, 1, read, file_out);
+        if (read != written) {
+            LASError_Print("unable to write data in bulk copy");
+            exit(1);
+    fclose(file_in);
+    fclose(file_out);
+    free(buffer);
+void usage()
+    fprintf(stderr,"----------------------------------------------------------\n");
+    fprintf(stderr,"    las2las-old (version %s) usage:\n", LAS_GetFullVersion());
+    fprintf(stderr,"\n");
+    fprintf(stderr,"Clip las file to a bounding box, throwing out points that have invalid data:\n");
+    fprintf(stderr,"  las2las-old -i in.las -clip 63000000 483450000 63050000 483500000 -o out.las --skip_invalid\n");
+    fprintf(stderr,"Read from stdin, eliminate intensities below 2000, and write to stdout:\n");
+    fprintf(stderr,"  las2las-old --eliminate_intensity_below 2000 --stdin --stdout < in.las > out.las \n");
+    fprintf(stderr,"Eliminate return number two:\n");
+    fprintf(stderr,"  las2las-old -i in.las -eliminate_return 2 -o out.las\n");
+    fprintf(stderr,"Eliminate scan angles above 15:\n");
+    fprintf(stderr,"  las2las-old -i in.las -eliminate_scan_angle_above 15 -o out.las\n");
+    fprintf(stderr,"Eliminate intensities below 1000:\n");
+    fprintf(stderr,"  las2las-old -i in.las -eliminate_intensity_below 1000 --stdout > out.las\n");
+    fprintf(stderr,"Eliminate intensities below 1000 and classifications that equal 2 (ground):\n");
+    fprintf(stderr,"  las2las-old -i in.las --eliminate_class 2 --out out.las\n");
+    fprintf(stderr,"Capture only first returns and clip to bounding box:\n");
+    fprintf(stderr,"  las2las-old -i in.las -first_only -clip 63000000 483450000 63050000 483500000 -o out.las\n");
+    fprintf(stderr,"Capture only last returns, eliminate intensities below 2000, and write to stdout:\n");
+    fprintf(stderr,"  las2las-old --input in.las --last_only --eliminate_intensity_below 2000 --stdout > out.las\n");
+    fprintf(stderr,"Reproject the data (requires GDAL support):\n");
+    fprintf(stderr,"  las2las-old -v in.las output.las -xyz_offset 0 0 0 "
+                   "-t_srs EPSG:4326 --xyz_scale 0.0000001 0.0000001 0.0000001"
+                   "-s_srs EPSG:26915\n");
+    fprintf(stderr, "\nFor more information, see the full documentation for las2las-old at:\n"
+                    " http://liblas.org/utilities/las2las-old.html\n");
+void ptime(const char *const msg)
+  float t= ((float)clock())/CLOCKS_PER_SEC;
+  fprintf(stderr, "cumulative CPU time thru %s = %f\n", msg, t);
+int main(int argc, char *argv[])
+    int i;
+    int verbose = FALSE;
+    int use_stdin = FALSE;
+    int use_stdout = FALSE;
+    char* file_name_in = 0;
+    char* file_name_out = 0;
+    char* proj4_text = NULL;
+    double *clip_xy_min = NULL;
+    double *clip_xy_max = NULL;
+    int clip = FALSE;
+    int remove_extra_header = FALSE;
+    int elim_return = 0;
+    int elim_scan_angle_above = 0;
+    int elim_intensity_below = 0;
+    int elim_class = 0;
+    int clsidx = 0;
+    int first_only = FALSE;
+    int last_only = FALSE;
+    int skip_invalid = FALSE;
+    int format = LAS_FORMAT_12;
+    int bulk_copy = FALSE;
+    LASReaderH reader = NULL;
+    LASHeaderH header = NULL;
+    LASHeaderH surviving_header = NULL;
+    LASPointH p = NULL;
+    LASWriterH writer = NULL;
+    LASSRSH in_srs = NULL;
+    LASSRSH out_srs = NULL;
+    int use_min_offset = FALSE;
+    int do_reprojection = FALSE;
+    int do_set_offset = FALSE;
+    int do_set_scale = FALSE;
+    int do_pad_header = FALSE;
+    int header_pad = 0;
+    int first_surviving_point = TRUE;
+    unsigned int surviving_number_of_point_records = 0;
+    unsigned int surviving_number_of_points_by_return[] = {0,0,0,0,0,0,0,0};
+    LASPointH surviving_point_min = NULL;
+    LASPointH surviving_point_max = NULL;
+    double surviving_gps_time_min;
+    double surviving_gps_time_max;
+    int verticalCSType = -1, verticalDatum = -1, verticalUnits = 9001;
+    const char *verticalCitation = "";
+    int clipped = 0;
+    int eliminated_return = 0;
+    int eliminated_scan_angle = 0;
+    int eliminated_intensity = 0;
+    int eliminated_class = 0;
+    int eliminated_first_only = 0;
+    int eliminated_last_only = 0;
+    int thinned = 0;
+    int bThin = FALSE;
+    int nThin = 0;
+    double xyz_scale[3] = {0.0, 0.0, 0.0};
+    double xyz_offset[3] = {0.0, 0.0, 0.0};
+    double minx, maxx, miny, maxy, minz, maxz;
+    LASPointSummary* summary = NULL;
+    int ret = 0;
+    for (i = 1; i < argc; i++) {
+        if (    strcmp(argv[i],"-h") == 0 ||
+                strcmp(argv[i],"--help") == 0
+            usage();
+            exit(0);
+        else if (   strcmp(argv[i],"-v") == 0 ||
More information about the Liblas-commits mailing list
