[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Tue Oct 12 15:36:18 EDT 2010
changeset 0beda68ff2cf in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0beda68ff2cf
summary: use dash instead of underscore for generating-software and system-identifier options
changeset de7c5780d98b in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=de7c5780d98b
diffstat:
apps/laskernel.cpp | 12 ++++++------
doc/utilities/las2las.txt | 4 ++--
2 files changed, 8 insertions(+), 8 deletions(-)
diffs (53 lines):
diff -r 2dcb73ca71fd -r de7c5780d98b apps/laskernel.cpp
--- a/apps/laskernel.cpp Tue Oct 12 18:16:59 2010 +0100
+++ b/apps/laskernel.cpp Tue Oct 12 14:36:10 2010 -0500
@@ -303,8 +303,8 @@
("add-schema", po::value<bool>()->zero_tokens(), "Add the liblas.org schema VLR record to the file.")
("delete-vlr", po::value<std::vector<std::string> >()->multitoken(), "Removes VLRs with the given name and id combination. --delete-vlr LASF_Projection 34737")
("add-vlr", po::value<std::vector<std::string> >()->multitoken(), "Add VLRs with the given name and id combination. --add-vlr hobu 1234 \"Description of the VLR\" \"filename.ext\"")
- ("system_identifier", po::value<std::string>(), "Set the SystemID for the file. --system_identifier \"MODIFICATION\"")
- ("generating_software", po::value<std::string>(), "Set the SoftwareID for the file. --generating_software \"liblas.org\"")
+ ("system-identifier", po::value<std::string>(), "Set the SystemID for the file. --system_identifier \"MODIFICATION\"")
+ ("generating-software", po::value<std::string>(), "Set the SoftwareID for the file. --generating_software \"liblas.org\"")
@@ -1040,9 +1040,9 @@
header.AddVLR(v);
- if (vm.count("generating_software"))
+ if (vm.count("generating-software"))
- std::string software = vm["generating_software"].as< std::string >();
+ std::string software = vm["generating-software"].as< std::string >();
if (verbose)
@@ -1051,9 +1051,9 @@
header.SetSoftwareId(software);
- if (vm.count("system_identifier"))
+ if (vm.count("system-identifier"))
- std::string id = vm["system_identifier"].as< std::string >();
+ std::string id = vm["system-identifier"].as< std::string >();
if (verbose)
diff -r 2dcb73ca71fd -r de7c5780d98b doc/utilities/las2las.txt
--- a/doc/utilities/las2las.txt Tue Oct 12 18:16:59 2010 +0100
+++ b/doc/utilities/las2las.txt Tue Oct 12 14:36:10 2010 -0500
@@ -285,9 +285,9 @@
--add-vlr arg Add VLRs with the given name and id combination.
--add-vlr hobu 1234 "Description of the VLR"
"filename.ext"
- --system_identifier arg Set the SystemID for the file. --system_identifier
+ --system-identifier arg Set the SystemID for the file. --system_identifier
"MODIFICATION"
- --generating_software arg Set the SoftwareID for the file.
+ --generating-software arg Set the SoftwareID for the file.
--generating_software "liblas.org"
Transformation options:
More information about the Liblas-commits
