[Liblas-commits] hg: clean up some new warnings in the latest
indexing code
liblas-commits at liblas.org
Mon Oct 18 12:32:38 EDT 2010
changeset 5a4f88cb6a8f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5a4f88cb6a8f
summary: clean up some new warnings in the latest indexing code
diffstat:
apps/lasindex_test.cpp | 2 +-
src/detail/index/indexoutput.cpp | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diffs (26 lines):
diff -r 3a8fdb46138e -r 5a4f88cb6a8f apps/lasindex_test.cpp
--- a/apps/lasindex_test.cpp Mon Oct 18 17:08:11 2010 +0100
+++ b/apps/lasindex_test.cpp Mon Oct 18 11:32:32 2010 -0500
@@ -177,7 +177,7 @@
fprintf(debugger, "Points within filter area %d of %d, step %d, %s\n", resultSize,
pointCount, step, "Using iterator");
#else // VISUAL_8
- fprintf(debugger, "Points within filter area %zu of %d, step %d, %s\n", resultSize,
+ fprintf(debugger, "Points within filter area %d of %d, step %d, %s\n", resultSize,
#endif // VISUAL_8
return true;
diff -r 3a8fdb46138e -r 5a4f88cb6a8f src/detail/index/indexoutput.cpp
--- a/src/detail/index/indexoutput.cpp Mon Oct 18 17:08:11 2010 +0100
+++ b/src/detail/index/indexoutput.cpp Mon Oct 18 11:32:32 2010 -0500
@@ -51,9 +51,9 @@
m_index(indexsource),
m_VLRCommonDataSize(6 * sizeof(boost::uint32_t)),
m_VLRDataSizeLocation(4 * sizeof(boost::uint32_t)),
- m_VLRPointCountLocation(5 * sizeof(boost::uint32_t)),
m_FirstCellLocation(0),
m_LastCellLocation(sizeof(boost::uint32_t) * 2),
+ m_VLRPointCountLocation(5 * sizeof(boost::uint32_t)),
m_DataPointsThisVLR(0)
} // IndexOutput::IndexOutput
More information about the Liblas-commits
