[Liblas-commits] hg: Keep track of total points scanned in current
VLR. Fixes bug...
liblas-commits at liblas.org
Tue Oct 19 16:53:39 EDT 2010
changeset 2909b0841902 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2909b0841902
summary: Keep track of total points scanned in current VLR. Fixes bug when using iterator functions on multi-VLR indexes.
diffstat:
include/liblas/lasindex.hpp | 3 ++-
src/lasindex.cpp | 32 +++++++++++++++++++-------------
2 files changed, 21 insertions(+), 14 deletions(-)
diffs (131 lines):
diff -r 5a4f88cb6a8f -r 2909b0841902 include/liblas/lasindex.hpp
--- a/include/liblas/lasindex.hpp Mon Oct 18 11:32:32 2010 -0500
+++ b/include/liblas/lasindex.hpp Tue Oct 19 14:52:24 2010 -0600
@@ -471,7 +471,8 @@
IndexData m_indexData;
Index *m_index;
boost::uint32_t m_chunkSize, m_advance;
- boost::uint32_t m_curVLR, m_curCellStartPos, m_curCellX, m_curCellY, m_totalPointsScanned, m_ptsScannedCurCell;
+ boost::uint32_t m_curVLR, m_curCellStartPos, m_curCellX, m_curCellY, m_totalPointsScanned, m_ptsScannedCurCell,
+ m_ptsScannedCurVLR;
boost::uint32_t m_conformingPtsFound;
public:
diff -r 5a4f88cb6a8f -r 2909b0841902 src/lasindex.cpp
--- a/src/lasindex.cpp Mon Oct 18 11:32:32 2010 -0500
+++ b/src/lasindex.cpp Tue Oct 19 14:52:24 2010 -0600
@@ -300,15 +300,15 @@
break;
if (ParamSrc.m_iterator)
+ if (VLRDone)
+ ParamSrc.m_iterator->m_curCellStartPos = ParamSrc.m_iterator->m_ptsScannedCurCell =
+ ParamSrc.m_iterator->m_ptsScannedCurVLR = 0;
// if we've filled our quota break out of loop
if (m_filterResult.size() >= ParamSrc.m_iterator->m_chunkSize)
// if we've scanned the entire VLR
if (VLRDone)
++i; // increment i so that next iteration starts on next VLR
- ParamSrc.m_iterator->m_curCellStartPos = ParamSrc.m_iterator->m_ptsScannedCurCell = 0;
- } // if
else if (i != HeadVLR) // if VLR's are linked FilterOneVLR() will have incremented i
i = HeadVLR; // put back i so that the right VLR is loaded first next iteration
break;
@@ -508,7 +508,7 @@
boost::uint32_t ReadPos = 0;
boost::uint32_t MinCellX, MinCellY, MaxCellX, MaxCellY, PointsThisRecord = 0, PointsThisCell = 0, DataRecordSize = 0,
- PointsScanned = 0, PointsToIgnore = 0;
+ PointsScannedThisTime = 0, PointsScannedCurVLR = 0, PointsToIgnore = 0;
IndexVLRData CompositeData;
try {
@@ -557,6 +557,7 @@
ReadPos = ParamSrc.m_iterator->m_curCellStartPos;
PointsToIgnore = ParamSrc.m_iterator->m_ptsScannedCurCell;
+ PointsScannedCurVLR = ParamSrc.m_iterator->m_ptsScannedCurVLR;
} // if
// translate the data for this VLR
while (ReadPos + sizeof (boost::uint32_t) < DataRecordSize)
@@ -606,12 +607,12 @@
ReadVLRData_n(ConsecutivePts, CompositeData, ReadPos);
if (TestPointsInThisCell && ZCellInteresting(ZCellID, ParamSrc))
- FilterPointSeries(PointID, PointsScanned, PointsToIgnore, x, y, ZCellID,
+ FilterPointSeries(PointID, PointsScannedThisTime, PointsToIgnore, x, y, ZCellID,
ConsecutivePts, ParamSrc.m_iterator, ParamSrc);
} // if
else
- PointsScanned += ConsecutivePts;
+ PointsScannedThisTime += ConsecutivePts;
ParamSrc.m_iterator->m_ptsScannedCurCell += ConsecutivePts;
} // else
@@ -638,12 +639,12 @@
if (TestPointsInThisCell && SubCellInteresting(SubCellID, x, y, ParamSrc))
- FilterPointSeries(PointID, PointsScanned, PointsToIgnore, x, y, 0,
+ FilterPointSeries(PointID, PointsScannedThisTime, PointsToIgnore, x, y, 0,
} // if
else
} // else
@@ -665,12 +666,12 @@
if (TestPointsInThisCell)
} // if
else
} // else
@@ -681,10 +682,14 @@
if (ParamSrc.m_iterator && (m_filterResult.size() >= ParamSrc.m_iterator->m_chunkSize))
break;
} // while
- if (PointsScanned >= PointsThisRecord)
+ PointsScannedCurVLR += PointsScannedThisTime;
+ if (PointsScannedCurVLR >= PointsThisRecord)
VLRDone = true;
- ParamSrc.m_iterator->m_totalPointsScanned += PointsScanned;
+ ParamSrc.m_iterator->m_totalPointsScanned += PointsScannedThisTime;
+ ParamSrc.m_iterator->m_ptsScannedCurVLR = PointsScannedCurVLR;
+ } // if
} // if
else if (ParamSrc.m_iterator)
@@ -2080,6 +2085,7 @@
m_curCellY = other.m_curCellY;
m_totalPointsScanned = other.m_totalPointsScanned;
m_ptsScannedCurCell = other.m_ptsScannedCurCell;
+ m_ptsScannedCurVLR = other.m_ptsScannedCurVLR;
m_conformingPtsFound = other.m_conformingPtsFound;
} // if
} // IndexIterator::Copy
@@ -2087,7 +2093,7 @@
void IndexIterator::ResetPosition(void)
m_curVLR = m_curCellStartPos = m_curCellX = m_curCellY = 0;
- m_totalPointsScanned = m_ptsScannedCurCell = 0;
+ m_totalPointsScanned = m_ptsScannedCurCell = m_ptsScannedCurVLR = 0;
m_conformingPtsFound = 0;
} // IndexIterator::ResetPosition
More information about the Liblas-commits
