[Liblas-commits] hg: Point::SetPoint and GetPoint now use binary
unrolled-loop ut...
liblas-commits at liblas.org
Thu Oct 21 09:04:56 EDT 2010
changeset dcf89ead4b25 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=dcf89ead4b25
summary: Point::SetPoint and GetPoint now use binary unrolled-loop utils. Tests pass. To be tested on big-endian.
diffstat:
src/laspoint.cpp | 94 +++++++++++++++----------------------------------------
1 files changed, 26 insertions(+), 68 deletions(-)
diffs (199 lines):
diff -r 5a272a57945c -r dcf89ead4b25 src/laspoint.cpp
--- a/src/laspoint.cpp Thu Oct 21 01:28:06 2010 +0100
+++ b/src/laspoint.cpp Thu Oct 21 14:04:36 2010 +0100
@@ -43,6 +43,7 @@
#include <liblas/lasheader.hpp>
#include <liblas/lasschema.hpp>
#include <liblas/exception.hpp>
+#include <liblas/detail/binary.hpp>
#include <liblas/detail/pointrecord.hpp>
// boost
#include <boost/array.hpp>
@@ -95,7 +96,6 @@
return *this;
void Point::SetCoordinates(double const& x, double const& y, double const& z)
SetX(x);
@@ -103,7 +103,6 @@
SetZ(z);
bool Point::equal(Point const& other) const
// TODO - mloskot: Default epsilon is too small.
@@ -184,7 +183,6 @@
if (this->GetReturnNumber() > 0x07)
return false;
return true;
@@ -230,24 +228,17 @@
SetUserData(p.GetUserData());
SetPointSourceID(p.GetPointSourceID());
- try {
+ try
SetTime(p.GetTime());
- } catch (std::runtime_error const&)
+ SetColor(p.GetColor());
+ catch (std::runtime_error const&)
- try {
- SetColor(p.GetColor());
// FIXME: copy other custom dimensions here? resetting the
// headerptr can be catastrophic in a lot of cases.
m_header = header;
@@ -722,14 +713,11 @@
return output;
void Point::SetPointSourceID(boost::uint16_t const& id)
// "Point Source ID" is always the 12th dimension
std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(11);
- liblas::detail::intToBits<boost::uint16_t>(id,
- m_data,
- pos);
+ liblas::detail::intToBits<boost::uint16_t>(id, m_data, pos);
void Point::SetTime(double const& t)
@@ -753,54 +741,40 @@
std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(index_pos);
- const boost::uint8_t* x_b = reinterpret_cast<const boost::uint8_t*>(&t);
-#if defined(LIBLAS_BIG_ENDIAN)
- for (boost::int32_t n = sizeof( double )-1; n >= 0; n--)
-#else
- for (boost::uint32_t n = 0; n < sizeof( double ); n++)
-#endif
- m_data[pos+n] = x_b[n];
+ detail::binary::endian_value<double> value(t);
+ value.store<detail::binary::little_endian_tag>(&m_data[0] + pos);
double Point::GetTime() const
- // "Time" is the 13th dimension if it exists
- std::size_t index_pos = 12;
PointFormatName f;
- if (m_header) {
+ if (m_header)
f = m_header->GetDataFormatId();
- } else {
+ else
f = m_default_header.GetDataFormatId();
- if ( f == ePointFormat0 || f == ePointFormat2 ) {
+ if (f == ePointFormat0 || f == ePointFormat2)
// std::ostringstream msg;
// msg << "Point::GetTime - Unable to get time for ePointFormat0 or ePointFormat2, "
// << "no Time dimension exists on this format";
// throw std::runtime_error(msg.str());
return 0.0;
+ // "Time" is the 13th dimension if it exists
+ std::size_t const index_pos = 12;
- boost::uint8_t* data = new boost::uint8_t[8];
-#else
-#endif
- data[n] = m_data[pos+n];
- const double* output = reinterpret_cast<const double*>(data);
- double out = *output;
- delete[] data;
- return out;
+ detail::binary::endian_value<double> value;
+ value.load<detail::binary::little_endian_tag>(&m_data[0] + pos);
+ return value;
Color Point::GetColor() const
boost::uint16_t red(0);
@@ -868,23 +842,14 @@
std::vector<boost::uint8_t>::size_type green_pos = GetDimensionBytePosition(index_pos + 1);
std::vector<boost::uint8_t>::size_type blue_pos = GetDimensionBytePosition(index_pos + 2);
std::vector<boost::uint8_t>::size_type red_pos = GetDimensionBytePosition(index_pos);
assert(red_pos + sizeof(Color::value_type) <= m_data.size());
intToBits<boost::uint16_t>(value.GetRed(), m_data, red_pos);
- intToBits<boost::uint16_t>(value.GetGreen(),
- m_data,
- green_pos);
- intToBits<boost::uint16_t>(value.GetBlue(),
- m_data,
- blue_pos);
+ intToBits<boost::uint16_t>(value.GetGreen(), m_data, green_pos);
+ intToBits<boost::uint16_t>(value.GetBlue(), m_data, blue_pos);
std::vector<boost::uint8_t>::size_type Point::GetDimensionBytePosition(std::size_t dim_pos) const
std::size_t output = 0;
@@ -898,19 +863,12 @@
return output;
boost::any Point::GetValue(Dimension const& d) const
boost::any output;
return output;
} // namespace liblas
More information about the Liblas-commits
