[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Sat Oct 23 20:18:53 EDT 2010
changeset 4ddd36c5b69d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=4ddd36c5b69d
summary: Added emacs temp files to .hgignore
changeset 557cadae16a1 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=557cadae16a1
summary: Re-style CMakeLists.txt according to CMake common.
diffstat:
.hgignore | 3 +-
CMakeLists.txt | 268 ++++++++++++++++++++++++++++----------------------------
2 files changed, 137 insertions(+), 134 deletions(-)
diffs (truncated from 403 to 300 lines):
diff -r dcf89ead4b25 -r 557cadae16a1 .hgignore
--- a/.hgignore Thu Oct 21 14:04:36 2010 +0100
+++ b/.hgignore Sun Oct 24 01:18:25 2010 +0100
@@ -1,5 +1,6 @@
syntax: glob
*.bak
*.dll
*.dll.manifest
@@ -94,4 +95,4 @@
README.txt
osgeo4w/
test/data/Autzen_Stadium/
-DartConfiguration.tcl
\ No newline at end of file
+DartConfiguration.tcl
diff -r dcf89ead4b25 -r 557cadae16a1 CMakeLists.txt
--- a/CMakeLists.txt Thu Oct 21 14:04:36 2010 +0100
+++ b/CMakeLists.txt Sun Oct 24 01:18:25 2010 +0100
@@ -9,18 +9,17 @@
project(libLAS)
if(WIN32)
- # Name of C++ library
- set(LIBLAS_LIB_NAME liblas)
+ # Name of C++ library
+ set(LIBLAS_LIB_NAME liblas)
- # Name of C library
- set(LIBLAS_C_LIB_NAME liblas_c)
+ # Name of C library
+ set(LIBLAS_C_LIB_NAME liblas_c)
else()
- set(LIBLAS_LIB_NAME las)
- set(LIBLAS_C_LIB_NAME las_c)
+ set(LIBLAS_LIB_NAME las)
+ set(LIBLAS_C_LIB_NAME las_c)
endif()
# Name of test suite runner
@@ -35,7 +34,7 @@
# Enable CTest and submissions to libLAS dashboard at CDash
# http://my.cdash.org/index.php?project=libLAS
set(ENABLE_CTEST FALSE CACHE BOOL
- "Enable CTest to support submissions of results to CDash at http://cdash.org")
+ "Enable CTest to support submissions of results to CDash at http://cdash.org")
# CMake settings
@@ -55,7 +54,7 @@
# Default to release mode
if(NOT MSVC_IDE)
set(CMAKE_BUILD_TYPE Release CACHE STRING
- "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel")
+ "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel")
endif()
# TODO: Still testing the output paths --mloskot
@@ -77,47 +76,48 @@
# Platform and compiler specific settings
if(WIN32)
- if (MSVC)
- if (MSVC80 OR MSVC90 OR MSVC10)
- add_definitions(-D_CRT_SECURE_NO_DEPRECATE)
- add_definitions(-D_CRT_SECURE_NO_WARNINGS)
- add_definitions(-D_CRT_NONSTDC_NO_WARNING)
- add_definitions(-D_SCL_SECURE_NO_WARNINGS)
- add_definitions(-D_SECURE_SCL=0)
- endif()
- if(CMAKE_CXX_FLAGS MATCHES "/W[0-4]")
- string(REGEX REPLACE "/W[0-4]" "/W4"
- CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS}")
- else()
- set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
- endif()
+ if (MSVC)
+ if (MSVC80 OR MSVC90 OR MSVC10)
+ add_definitions(-D_CRT_SECURE_NO_DEPRECATE)
+ add_definitions(-D_CRT_SECURE_NO_WARNINGS)
+ add_definitions(-D_CRT_NONSTDC_NO_WARNING)
+ add_definitions(-D_SCL_SECURE_NO_WARNINGS)
+ add_definitions(-D_SECURE_SCL=0)
+ endif()
+ if(CMAKE_CXX_FLAGS MATCHES "/W[0-4]")
+ string(REGEX REPLACE "/W[0-4]" "/W4"
+ CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS}")
+ else()
+ set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
+ endif()
- # Generate dot-user file with user-specific settings for Visual Studio project
- set(MSVC_ENVIRONMENT_PATH "" CACHE STRING
- "Custom PATH for Environment property in Visual Studio project configuration")
- mark_as_advanced(MSVC_ENVIRONMENT_PATH)
- set(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG "${ENVIRONMENT_PATH}")
- mark_as_advanced(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG)
+ # Generate dot-user file with user-specific settings for
+ # Visual Studio project
+ set(MSVC_ENVIRONMENT_PATH "" CACHE STRING
+ "Custom PATH for Environment property in Visual Studio for project")
+ mark_as_advanced(MSVC_ENVIRONMENT_PATH)
+ set(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG "${ENVIRONMENT_PATH}")
+ mark_as_advanced(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG)
+ endif()
+else()
+ if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
+ set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fPIC -Wall -Wno-long-long -ansi")
+ if (CMAKE_COMPILER_IS_GNUCXX)
+ set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++98")
endif()
-else()
- if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
- set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fPIC -Wall -Wno-long-long -ansi")
- if (CMAKE_COMPILER_IS_GNUCXX)
- set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++98")
- endif()
- endif()
+ endif()
endif(WIN32)
if (APPLE)
- set(SO_EXT dylib)
- set(CMAKE_FIND_FRAMEWORK "LAST")
+ set(SO_EXT dylib)
+ set(CMAKE_FIND_FRAMEWORK "LAST")
elseif(WIN32)
- set(SO_EXT dll)
+ set(SO_EXT dll)
else()
- set(SO_EXT so)
+ set(SO_EXT so)
endif(APPLE)
@@ -143,109 +143,112 @@
set(WITH_GEOTIFF FALSE CACHE BOOL "Choose if GeoTIFF support should be built")
if(WITH_GEOTIFF)
- find_package(GeoTIFF 1.2.5)
+ find_package(GeoTIFF 1.2.5)
- if(GEOTIFF_FOUND)
+ if(GEOTIFF_FOUND)
- # Confirm required API is available
- include(CheckFunctionExists)
- set(CMAKE_REQUIRED_LIBRARIES ${GEOTIFF_LIBRARY})
-# check_function_exists(ST_Create HAVE_ST_CREATE)
+ # Confirm required API is available
+ include(CheckFunctionExists)
+ set(CMAKE_REQUIRED_LIBRARIES ${GEOTIFF_LIBRARY})
+ # check_function_exists(ST_Create HAVE_ST_CREATE)
-# if(NOT HAVE_ST_CREATE)
-# set(GEOTIFF_FOUND) # Reset to NOT found for GeoTIFF
-# message(FATAL_ERROR "GeoTIFF support requires libgeotiff 1.2.5 or newer.")
-# else()
- include_directories(${GEOTIFF_INCLUDE_DIR})
- add_definitions(-DHAVE_LIBGEOTIFF=1)
-# endif()
+ # if(NOT HAVE_ST_CREATE)
+ # set(GEOTIFF_FOUND) # Reset to NOT found for GeoTIFF
+ # message(FATAL_ERROR "GeoTIFF support requires libgeotiff 1.2.5 or newer.")
+ # else()
+ include_directories(${GEOTIFF_INCLUDE_DIR})
+ add_definitions(-DHAVE_LIBGEOTIFF=1)
+ # endif()
+ endif()
+ # Determine libTIFF availability, required
+ if (GEOTIFF_FOUND)
+ find_package(TIFF)
+ mark_as_advanced(CLEAR TIFF_INCLUDE_DIR)
+ mark_as_advanced(CLEAR TIFF_LIBRARIES)
+ if (TIFF_FOUND)
+ include_directories(${TIFF_INCLUDE_DIR})
endif()
- # Determine libTIFF availability, required
- if (GEOTIFF_FOUND)
- find_package(TIFF)
- mark_as_advanced(CLEAR TIFF_INCLUDE_DIR)
- mark_as_advanced(CLEAR TIFF_LIBRARIES)
- if (TIFF_FOUND)
- include_directories(${TIFF_INCLUDE_DIR})
- endif()
- endif()
+ endif()
endif()
# GDAL/OGR support - optional, default=OFF
set(WITH_GDAL FALSE CACHE BOOL "Choose if GDAL support should be built")
if(WITH_GDAL)
- if (NOT GEOTIFF_FOUND)
- message(FATAL_ERROR "GDAL support requires GeoTIFF library which was not selected")
+ if (NOT GEOTIFF_FOUND)
+ message(FATAL_ERROR
+ "GDAL support requires GeoTIFF library which was not selected")
+ endif()
+ find_package(GDAL 1.6.0)
+ if(GDAL_FOUND)
+ set(CMAKE_REQUIRED_LIBRARIES ${GDAL_LIBRARY})
+ check_function_exists(OSRSetEquirectangular2 HAVE_OSRSETEQUIRECTANGULAR2)
+ if(NOT HAVE_OSRSETEQUIRECTANGULAR2)
+ # Reset to NOT found for GDAL/OGR
+ set(GDAL_FOUND)
+ "Unable to find OSRSetEquirectangular2 within GDAL library at ${GDAL_INCLUDE_DIR} ${GDAL_LIBRARY}")
+ else()
+ include_directories(${GDAL_INCLUDE_DIR})
+ add_definitions(-DHAVE_GDAL=1)
endif()
- find_package(GDAL 1.6.0)
- if(GDAL_FOUND)
- set(CMAKE_REQUIRED_LIBRARIES ${GDAL_LIBRARY})
- check_function_exists(OSRSetEquirectangular2 HAVE_OSRSETEQUIRECTANGULAR2)
- if(NOT HAVE_OSRSETEQUIRECTANGULAR2)
- # Reset to NOT found for GDAL/OGR
- set(GDAL_FOUND)
- message(FATAL_ERROR "Unable to find OSRSetEquirectangular2 within GDAL library at ${GDAL_INCLUDE_DIR} ${GDAL_LIBRARY}")
- else()
- include_directories(${GDAL_INCLUDE_DIR})
- add_definitions(-DHAVE_GDAL=1)
- endif()
- endif()
+ endif()
endif()
# Oracle support - optional, default=OFF
set(WITH_ORACLE FALSE CACHE BOOL "Choose if Oracle support should be built")
if(WITH_ORACLE)
- find_package(Oracle)
+ find_package(Oracle)
- if(ORACLE_FOUND)
- include_directories(${ORACLE_INCLUDE_DIR})
- add_definitions(-DHAVE_ORACLE=1)
- endif()
+ if(ORACLE_FOUND)
+ include_directories(${ORACLE_INCLUDE_DIR})
+ add_definitions(-DHAVE_ORACLE=1)
+ endif()
endif()
# Installation settings
if(WIN32)
- set(DEFAULT_LIB_SUBDIR lib)
- set(DEFAULT_DATA_SUBDIR .)
- set(DEFAULT_INCLUDE_SUBDIR include)
+ set(DEFAULT_LIB_SUBDIR lib)
+ set(DEFAULT_DATA_SUBDIR .)
+ set(DEFAULT_INCLUDE_SUBDIR include)
- if (MSVC)
- set(DEFAULT_BIN_SUBDIR bin)
- else()
- set(DEFAULT_BIN_SUBDIR .)
- endif()
+ if (MSVC)
+ set(DEFAULT_BIN_SUBDIR bin)
+ else()
+ set(DEFAULT_BIN_SUBDIR .)
+ endif()
else()
- # Common locatoins for Unix and Mac OS X
- set(DEFAULT_DATA_SUBDIR share/liblas)
+ # Common locatoins for Unix and Mac OS X
More information about the Liblas-commits
