[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Oct 25 11:40:20 EDT 2010
changeset 6d1f843f300b in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6d1f843f300b
summary: keep stream buffer setting experiment
changeset 02df82d848f4 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=02df82d848f4
summary: ignore unused
diffstat:
 apps/las2las.cpp |  70 +++++++++++++++++++++++++++++++++++++++++++++++++------
 src/laspoint.cpp |   2 +-
 2 files changed, 63 insertions(+), 9 deletions(-)
diffs (151 lines):
diff -r e5200e060709 -r 02df82d848f4 apps/las2las.cpp
--- a/apps/las2las.cpp	Mon Oct 25 08:44:40 2010 -0600
+++ b/apps/las2las.cpp	Mon Oct 25 10:40:08 2010 -0500
@@ -20,6 +20,50 @@
 using namespace liblas;
 using namespace std;
+// 0, 4, 16, 64, 256
+//std::size_t const default_buffer_size = 0;
+//std::size_t const default_buffer_size = 4 * 1024;
+//std::size_t const default_buffer_size = 16 * 1024;
+//std::size_t const default_buffer_size = 64 * 1024;
+//std::size_t const default_buffer_size = 256 * 1024;
+std::size_t const default_buffer_size = 1024 * 1024;
+std::vector<char> ofs_buffer;
+std::vector<char> ifs_buffer;
+std::ofstream& set_ofstream_buffer(std::ofstream& ofs, std::size_t buffer_size)
+    char* buffer = 0; // unbuffered;
+    if (buffer_size > 0)
+        std::vector<char>(buffer_size).swap(ofs_buffer);
+        buffer = &ofs_buffer[0];
+    std::streambuf* sb = ofs.rdbuf()->pubsetbuf(buffer, buffer_size);
+    if (0 != buffer && 0 == sb)
+        throw std::runtime_error("failed to attach non-null buffer to input file stream");
+    return ofs;
+std::ifstream& set_ifstream_buffer(std::ifstream& ifs, std::size_t buffer_size)
+        std::vector<char>(buffer_size).swap(ifs_buffer);
+        buffer = &ifs_buffer[0];
+    std::streambuf* sb = ifs.rdbuf()->pubsetbuf(buffer, buffer_size);
+    return ifs;
 liblas::Writer* start_writer(   std::ofstream* strm,
                                 std::string const& output,
                                 liblas::Header const& header)
@@ -30,13 +74,15 @@
         std::ostringstream oss;
         oss << "Cannot create " << output << "for write.  Exiting...";
         throw std::runtime_error(oss.str());
+    // set_ofstream_buffer(*strm, default_buffer_size);
     liblas::Writer* writer = new liblas::Writer(*strm, header);
     return writer;
 bool process(   std::string const& input,
                 liblas::Header & header,
@@ -48,14 +94,14 @@
                 bool min_offset)
     std::ifstream ifs;
     if (!liblas::Open(ifs, input.c_str()))
         std::cerr << "Cannot open " << input << "for read.  Exiting...";
         return false;
+    // set_ifstream_buffer(ifs, default_buffer_size);
     liblas::Reader reader(ifs);
     liblas::Summary* summary = new liblas::Summary;
@@ -74,9 +120,11 @@
                              tree.get<double>("minimum.z"));
-        }     catch (liblas::property_tree::ptree_bad_path const& e)
+        catch (liblas::property_tree::ptree_bad_path const& e)
             std::cerr << "Unable to write minimum header info.  Does the outputted file have any points?";
+            e.what();
             return false;
         if (verbose)
@@ -287,14 +335,18 @@
         if (vm.count("input"))
             input = vm["input"].as< string >();
-            std::ifstream ifs;
             if (verbose)
                 std::cout << "Opening " << input << " to fetch Header" << std::endl;
+            std::ifstream ifs;
                 return 1;
             header = reader.GetHeader();
         } else {
@@ -332,11 +384,13 @@
-    catch(std::exception& e) {
+    catch(std::exception& e)
         std::cerr << "error: " << e.what() << "\n";
         return 1;
-    catch(...) {
+    catch(...)
         std::cerr << "Exception of unknown type!\n";
diff -r e5200e060709 -r 02df82d848f4 src/laspoint.cpp
--- a/src/laspoint.cpp	Mon Oct 25 08:44:40 2010 -0600
+++ b/src/laspoint.cpp	Mon Oct 25 10:40:08 2010 -0500
@@ -866,8 +866,8 @@
 boost::any Point::GetValue(Dimension const& d) const
     boost::any output;
+    boost::ignore_unused_variable_warning(d);
     return output;
More information about the Liblas-commits mailing list
