[Liblas-commits] hg: Index support for very large files of 1
billion points or mo...
liblas-commits at liblas.org
Mon Oct 25 14:03:18 EDT 2010
changeset 397aeabc3e2e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=397aeabc3e2e
summary: Index support for very large files of 1 billion points or more. 64 bit numeric values used for temporary file offsets.
diffstat:
include/liblas/detail/index/indexcell.hpp | 7 ++--
include/liblas/lasindex.hpp | 3 +-
src/detail/index/indexcell.cpp | 4 +-
src/lasindex.cpp | 43 +++++++++++++++---------------
4 files changed, 29 insertions(+), 28 deletions(-)
diffs (201 lines):
diff -r 02df82d848f4 -r 397aeabc3e2e include/liblas/detail/index/indexcell.hpp
--- a/include/liblas/detail/index/indexcell.hpp Mon Oct 25 10:40:08 2010 -0500
+++ b/include/liblas/detail/index/indexcell.hpp Mon Oct 25 12:02:28 2010 -0600
@@ -55,6 +55,7 @@
typedef boost::uint8_t ConsecPtAccumulator;
typedef std::map<boost::uint32_t, ConsecPtAccumulator> IndexCellData;
typedef std::map<boost::uint32_t, IndexCellData> IndexSubCellData;
+typedef boost::uint64_t TempFileOffsetType;
class IndexCell
@@ -62,7 +63,7 @@
IndexCell();
private:
- boost::uint32_t m_FileOffset;
+ TempFileOffsetType m_FileOffset;
boost::uint32_t m_NumPoints;
ElevExtrema m_MinZ, m_MaxZ;
IndexCellData m_PtRecords;
@@ -70,9 +71,9 @@
IndexSubCellData m_SubCellRecords;
public:
- void SetFileOffset(boost::uint32_t fos);
+ void SetFileOffset(TempFileOffsetType fos);
void SetNumPoints(boost::uint32_t nmp);
- boost::uint32_t GetFileOffset(void) const;
+ TempFileOffsetType GetFileOffset(void) const;
boost::uint32_t GetNumRecords(void) const;
boost::uint32_t GetNumPoints(void) const;
boost::uint32_t GetNumSubCellRecords(void) const;
diff -r 02df82d848f4 -r 397aeabc3e2e include/liblas/lasindex.hpp
--- a/include/liblas/lasindex.hpp Mon Oct 25 10:40:08 2010 -0500
+++ b/include/liblas/lasindex.hpp Mon Oct 25 12:02:28 2010 -0600
@@ -140,7 +140,8 @@
int m_debugOutputLevel;
boost::uint8_t m_versionMajor, m_versionMinor;
boost::uint32_t m_pointRecordsCount, m_maxMemoryUsage, m_cellsX, m_cellsY, m_cellsZ, m_totalCells,
- m_tempFileWrittenBytes, m_DataVLR_ID;
+ m_DataVLR_ID;
+ liblas::detail::TempFileOffsetType m_tempFileWrittenBytes;
double m_rangeX, m_rangeY, m_rangeZ, m_cellSizeZ, m_cellSizeX, m_cellSizeY;
std::string m_tempFileName;
std::string m_indexAuthor;
diff -r 02df82d848f4 -r 397aeabc3e2e src/detail/index/indexcell.cpp
--- a/src/detail/index/indexcell.cpp Mon Oct 25 10:40:08 2010 -0500
+++ b/src/detail/index/indexcell.cpp Mon Oct 25 12:02:28 2010 -0600
@@ -57,7 +57,7 @@
} // IndexCell::IndexCell
-void IndexCell::SetFileOffset(boost::uint32_t fos)
+void IndexCell::SetFileOffset(TempFileOffsetType fos)
m_FileOffset = fos;
} // IndexCell::SetFileOffset
@@ -67,7 +67,7 @@
m_NumPoints = nmp;
} // IndexCell::SetNumPoints
-boost::uint32_t IndexCell::GetFileOffset(void) const
+TempFileOffsetType IndexCell::GetFileOffset(void) const
return(m_FileOffset);
} // IndexCell::GetFileOffset
diff -r 02df82d848f4 -r 397aeabc3e2e src/lasindex.cpp
--- a/src/lasindex.cpp Mon Oct 25 10:40:08 2010 -0500
+++ b/src/lasindex.cpp Mon Oct 25 12:02:28 2010 -0600
@@ -122,7 +122,8 @@
m_DataVLR_ID = 43;
m_maxMemoryUsage = LIBLAS_INDEX_MAXMEMDEFAULT;
m_rangeX = m_rangeY = m_rangeZ = m_cellSizeZ = m_cellSizeX = m_cellSizeY =
- m_pointRecordsCount = m_maxMemoryUsage = m_cellsX = m_cellsY = m_cellsZ = m_totalCells = m_tempFileWrittenBytes = 0;
+ m_pointRecordsCount = m_maxMemoryUsage = m_cellsX = m_cellsY = m_cellsZ = m_totalCells = 0;
+ m_tempFileWrittenBytes = 0;
m_indexBuilt = m_tempFileStarted = m_readerCreated = false;
} // Index::SetValues
@@ -1025,8 +1026,7 @@
m_versionMinor = LIBLAS_INDEX_VERSIONMINOR;
// reset to beginning of point data records in case points had been examined before index is built
- m_reader->Reset();
+ m_reader->seek(0);
// need the header to get number of point records
m_pointRecordsCount = m_pointheader.GetPointRecordsCount();
// get the bounds of the data and scale factors in case they are needed for point translation
@@ -1164,11 +1164,9 @@
// If a cell contains too many points, subdivide the cell and save sub-cells within the cell structure
// If Z-binning is desired, define the bounds of each Z zone and subdivide sort each cell's points into Z bins
// Save Z bins within the cell structure.
- // reset Reader to beginning of point data records in case points had been examined before index is built
if (IndexOut.InitiateOutput())
for (boost::uint32_t x = 0; x < m_cellsX; ++x)
for (boost::uint32_t y = 0; y < m_cellsY; ++y)
@@ -1384,7 +1382,7 @@
if (m_tempFile || OpenTempFile())
- boost::uint32_t EmptyOffset = 0; // this might not be large enough
+ liblas::detail::TempFileOffsetType EmptyOffset = 0; // this might not be large enough
if (! m_tempFileStarted)
@@ -1392,12 +1390,12 @@
// write out a block of file offsets the size of the number of cells
for (boost::uint32_t i = 0; i < m_totalCells; ++i)
- if (fwrite(&EmptyOffset, sizeof(boost::uint32_t), 1, m_tempFile) < 1)
+ if (fwrite(&EmptyOffset, sizeof(liblas::detail::TempFileOffsetType), 1, m_tempFile) < 1)
return (FileError("Index::PurgePointsToTempFile"));
} // if error
} // for
- m_tempFileWrittenBytes = m_totalCells * sizeof(boost::uint32_t);
+ m_tempFileWrittenBytes = m_totalCells * sizeof(liblas::detail::TempFileOffsetType);
m_tempFileStarted = true;
} // if
@@ -1411,20 +1409,20 @@
// if cell block header is 0 write the current file location in the file header
// otherwise write the current file location at the file location specified in the
// cell block header
- boost::uint32_t LastWriteLocation = CellBlock[x][y].GetFileOffset();
+ liblas::detail::TempFileOffsetType LastWriteLocation = CellBlock[x][y].GetFileOffset();
if (LastWriteLocation == 0)
- LastWriteLocation = (x * m_cellsY + y) * sizeof(boost::uint32_t);
- fseek(m_tempFile, LastWriteLocation, SEEK_SET);
- if (fwrite(&m_tempFileWrittenBytes, sizeof(boost::uint32_t), 1, m_tempFile) < 1)
+ LastWriteLocation = (x * m_cellsY + y) * sizeof(liblas::detail::TempFileOffsetType);
+ _fseeki64(m_tempFile, LastWriteLocation, SEEK_SET);
+ if (fwrite(&m_tempFileWrittenBytes, sizeof(liblas::detail::TempFileOffsetType), 1, m_tempFile) < 1)
CellBlock[x][y].SetFileOffset(m_tempFileWrittenBytes);
// seek to end of file where next block of data will be written
- fseek(m_tempFile, 0, SEEK_END);
+ _fseeki64(m_tempFile, 0, SEEK_END);
// write a blank space for later placement of next file block for this cell
- m_tempFileWrittenBytes += sizeof(boost::uint32_t);
+ m_tempFileWrittenBytes += sizeof(liblas::detail::TempFileOffsetType);
// write the number of records stored in this section
if (fwrite(&RecordsToWrite, sizeof(boost::uint32_t), 1, m_tempFile) < 1)
@@ -1462,23 +1460,24 @@
boost::uint32_t CurCellX, boost::uint32_t CurCellY)
- boost::uint32_t FileOffset, RecordsToRead, FormerNumPts, NewNumPts = 0;
+ boost::uint32_t RecordsToRead, FormerNumPts, NewNumPts = 0;
+ liblas::detail::TempFileOffsetType FileOffset;
FormerNumPts = CellBlock->GetNumPoints();
CellBlock->SetNumPoints(0);
// load the cell as it was written
// read the first offset for this cell
- if (fseek(m_tempFile, (CurCellX * m_cellsY + CurCellY) * sizeof (boost::uint32_t), SEEK_SET))
+ if (_fseeki64(m_tempFile, (CurCellX * m_cellsY + CurCellY) * sizeof (liblas::detail::TempFileOffsetType), SEEK_SET))
return (FileError("Index::LoadCellFromTempFile"));
- if (fread(&FileOffset, sizeof (boost::uint32_t), 1, m_tempFile) < 1)
+ if (fread(&FileOffset, sizeof (liblas::detail::TempFileOffsetType), 1, m_tempFile) < 1)
while (FileOffset > 0)
// jump to the first block for this cell, read the next offset
- if (fseek(m_tempFile, FileOffset, SEEK_SET))
+ if (_fseeki64(m_tempFile, FileOffset, SEEK_SET))
// read the data for the cell in this block
// first is the number of items to read now
@@ -1534,7 +1533,7 @@
try {
Writer writer(*m_ofs, m_idxheader);
while (m_reader->ReadNextPoint())
Point CurPt = m_reader->GetPoint();
@@ -1553,7 +1552,7 @@
try {
/* test block - uncommenting this makes it just like above version with included points
More information about the Liblas-commits
