[Liblas-commits] hg: Changes to support testing of index iterator
	on large LAS fi...
    liblas-commits at liblas.org
    Mon Oct 25 14:08:53 EDT 2010
changeset 2a1c3cdda974 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2a1c3cdda974
summary: Changes to support testing of index iterator on large LAS files.
diffstat:
 apps/lasindex_test.cpp |  27 +++++++++++++++++++--------
 1 files changed, 19 insertions(+), 8 deletions(-)
diffs (60 lines):
diff -r 397aeabc3e2e -r 2a1c3cdda974 apps/lasindex_test.cpp
--- a/apps/lasindex_test.cpp	Mon Oct 25 12:02:28 2010 -0600
+++ b/apps/lasindex_test.cpp	Mon Oct 25 12:08:25 2010 -0600
@@ -263,8 +263,8 @@
 	/*----------------------------build index-----------------------------------
 	const char* arggv[] = {"foo", "-t", "C:\\LibLAS\\Mount St Helens Oct 4 2004.tmp",
 		 "-i", "C:\\LibLAS\\Samples\\Mount St Helens Oct 4 2004.las", "-a", SAMPLE_AUTHOR, "-c", SAMPLE_COMMENT, "-d", SAMPLE_DATE,
-		 "-o", "C:\\LibLAS\\Samples\\Mount St Helens Oct 4 2004_idx.las"};
-	argc = 13;
+		 "-o", "C:\\LibLAS\\Samples\\Mount St Helens Oct 4 2004_idx.las", "-b", "100"};
+	argc = 15;
 	/*------------------filter with embedded index------------------------------
@@ -295,12 +295,23 @@
 		 "-i", "C:\\LibLAS\\Samples\\flatDataset_idx.las", "-r"};
 	argc = 4;
-	///*------------filter with embedded index using iterator---------------------
+	/*------------filter with embedded index using iterator---------------------
-		 "-i", "C:\\LibLAS\\Samples\\flatDataset_idx.las", "-r", "-it", "5"};
+		 "-i", "C:\\LibLAS\\Samples\\flatDataset_idx.las", "-r", "-it", "25"};
 	argc = 6;
+	/*---------------------------billion_points-------------------------------*/
+	/*-----------------build index in standalone file---------------------------
+	const char* arggv[] = {"foo", "-t", "K:\\FME\\billion_points.tmp",
+		 "-i", "D:\\Zips\\FME\\billion_points.las", "-a", SAMPLE_AUTHOR, "-c", SAMPLE_COMMENT, "-d", SAMPLE_DATE,
+		 "-o", "K:\\FME\\billion_points_idx.ldx", "-s", "-it", "5000000"};
+	argc = 16;
+	/*-------------------filter from standalone file using iterator---------------
+	const char* arggv[] = {"foo", "-i", "D:\\Zips\\FME\\billion_points.las",
+		 "-n", "K:\\FME\\billion_points_idx.ldx", "-r", "-it", "5000000"};
+	argc = 8;
 	for (int i = 1; i < argc; i++)
@@ -478,7 +489,7 @@
 										IndexIterator *indexIt2 = index.Filter(ParamSrc2, chunkSize);
 										if (indexIt && indexIt2)
-											for (boost::uint32_t step = 0; step < 3; ++step)
+											for (boost::uint32_t step = 0; step < 1000; ++step)
 												// use any of these to begin the vector with the next point that fits the filter criteria
 												// that hasn't been scanned yet.
@@ -527,7 +538,7 @@
 												const std::vector<boost::uint32_t>& FilterResult5 = (*indexIt)+6;
 												if (!ReportIteratorResults(debugger, FilterResult5.size(), index.GetPointRecordsCount(), step))
 													break;
 											} // for
 										} // if
 										else
More information about the Liblas-commits
