[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org
Tue Oct 26 09:19:41 EDT 2010
changeset 28f6ea8e4304 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=28f6ea8e4304
summary: remove _SECURE_SCL=0 definition, as this was causing Release builds to crash that had program_options in them
changeset 8d8c80718147 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=8d8c80718147
summary: Rejigger to use OSGeo4W's OCI client
changeset 51de9d42769f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=51de9d42769f
summary: merge
diffstat:
CMakeLists.txt | 1 -
apps/lasindex_test.cpp | 27 +++++++++++++-----
hobu-config.bat | 9 +++--
include/liblas/detail/index/indexcell.hpp | 7 ++--
include/liblas/lasindex.hpp | 3 +-
src/detail/index/indexcell.cpp | 4 +-
src/lasindex.cpp | 43 +++++++++++++++---------------
7 files changed, 53 insertions(+), 41 deletions(-)
diffs (298 lines):
diff -r 02df82d848f4 -r 51de9d42769f CMakeLists.txt
--- a/CMakeLists.txt Mon Oct 25 10:40:08 2010 -0500
+++ b/CMakeLists.txt Tue Oct 26 07:19:19 2010 -0600
@@ -82,7 +82,6 @@
add_definitions(-D_CRT_SECURE_NO_WARNINGS)
add_definitions(-D_CRT_NONSTDC_NO_WARNING)
add_definitions(-D_SCL_SECURE_NO_WARNINGS)
- add_definitions(-D_SECURE_SCL=0)
endif()
if(CMAKE_CXX_FLAGS MATCHES "/W[0-4]")
diff -r 02df82d848f4 -r 51de9d42769f apps/lasindex_test.cpp
--- a/apps/lasindex_test.cpp Mon Oct 25 10:40:08 2010 -0500
+++ b/apps/lasindex_test.cpp Tue Oct 26 07:19:19 2010 -0600
@@ -263,8 +263,8 @@
/*----------------------------build index-----------------------------------
const char* arggv[] = {"foo", "-t", "C:\\LibLAS\\Mount St Helens Oct 4 2004.tmp",
"-i", "C:\\LibLAS\\Samples\\Mount St Helens Oct 4 2004.las", "-a", SAMPLE_AUTHOR, "-c", SAMPLE_COMMENT, "-d", SAMPLE_DATE,
- "-o", "C:\\LibLAS\\Samples\\Mount St Helens Oct 4 2004_idx.las"};
- argc = 13;
+ "-o", "C:\\LibLAS\\Samples\\Mount St Helens Oct 4 2004_idx.las", "-b", "100"};
+ argc = 15;
/*------------------filter with embedded index------------------------------
@@ -295,12 +295,23 @@
"-i", "C:\\LibLAS\\Samples\\flatDataset_idx.las", "-r"};
argc = 4;
- ///*------------filter with embedded index using iterator---------------------
+ /*------------filter with embedded index using iterator---------------------
- "-i", "C:\\LibLAS\\Samples\\flatDataset_idx.las", "-r", "-it", "5"};
+ "-i", "C:\\LibLAS\\Samples\\flatDataset_idx.las", "-r", "-it", "25"};
argc = 6;
+ /*---------------------------billion_points-------------------------------*/
+ /*-----------------build index in standalone file---------------------------
+ const char* arggv[] = {"foo", "-t", "K:\\FME\\billion_points.tmp",
+ "-i", "D:\\Zips\\FME\\billion_points.las", "-a", SAMPLE_AUTHOR, "-c", SAMPLE_COMMENT, "-d", SAMPLE_DATE,
+ "-o", "K:\\FME\\billion_points_idx.ldx", "-s", "-it", "5000000"};
+ argc = 16;
+ /*-------------------filter from standalone file using iterator---------------
+ const char* arggv[] = {"foo", "-i", "D:\\Zips\\FME\\billion_points.las",
+ "-n", "K:\\FME\\billion_points_idx.ldx", "-r", "-it", "5000000"};
+ argc = 8;
for (int i = 1; i < argc; i++)
@@ -478,7 +489,7 @@
IndexIterator *indexIt2 = index.Filter(ParamSrc2, chunkSize);
if (indexIt && indexIt2)
- for (boost::uint32_t step = 0; step < 3; ++step)
+ for (boost::uint32_t step = 0; step < 1000; ++step)
// use any of these to begin the vector with the next point that fits the filter criteria
// that hasn't been scanned yet.
@@ -527,7 +538,7 @@
const std::vector<boost::uint32_t>& FilterResult5 = (*indexIt)+6;
if (!ReportIteratorResults(debugger, FilterResult5.size(), index.GetPointRecordsCount(), step))
break;
} // for
} // if
else
diff -r 02df82d848f4 -r 51de9d42769f hobu-config.bat
--- a/hobu-config.bat Mon Oct 25 10:40:08 2010 -0500
+++ b/hobu-config.bat Tue Oct 26 07:19:19 2010 -0600
@@ -4,9 +4,9 @@
set LIBLAS=D:\liblas
set OSGEO4W=C:\OSGeo4W
set BOOST=D:\boost\boost_1_44
-set ORACLE_HOME=D:\instantclient_11_1
+set ORACLE_HOME=%OSGEO4W%
-set PATH=%ORACLE_HOME%;%OSGEO4W%\apps\gdal-dev\bin;%OSGEO4W%\bin;%PATH%
+set PATH=%OSGEO4W%\apps\gdal-dev\bin;%OSGEO4W%\bin;%PATH%
cmake -G %G% ^
-DBOOST_INCLUDEDIR=%BOOST% ^
@@ -19,6 +19,7 @@
-DGEOTIFF_LIBRARY=%OSGEO4W%\lib\geotiff_i.lib ^
-DGDAL_INCLUDE_DIR=%OSGEO4W%\apps\gdal-dev\include ^
-DGDAL_LIBRARY=%OSGEO4W%\apps\gdal-dev\lib\gdal_i.lib ^
- -DORACLE_INCLUDE_DIR=%ORACLE_HOME%\sdk\include ^
- -DORACLE_OCI_LIBRARY=%ORACLE_HOME%\sdk\lib\msvc\oci.lib ^
+ -DORACLE_INCLUDE_DIR=%ORACLE_HOME%\include ^
+ -DORACLE_OCI_LIBRARY=%ORACLE_HOME%\lib\oci.lib ^
+ -DCMAKE_BUILD_TYPE=RelWithDebInfo ^
%LIBLAS%
\ No newline at end of file
diff -r 02df82d848f4 -r 51de9d42769f include/liblas/detail/index/indexcell.hpp
--- a/include/liblas/detail/index/indexcell.hpp Mon Oct 25 10:40:08 2010 -0500
+++ b/include/liblas/detail/index/indexcell.hpp Tue Oct 26 07:19:19 2010 -0600
@@ -55,6 +55,7 @@
typedef boost::uint8_t ConsecPtAccumulator;
typedef std::map<boost::uint32_t, ConsecPtAccumulator> IndexCellData;
typedef std::map<boost::uint32_t, IndexCellData> IndexSubCellData;
+typedef boost::uint64_t TempFileOffsetType;
class IndexCell
@@ -62,7 +63,7 @@
IndexCell();
private:
- boost::uint32_t m_FileOffset;
+ TempFileOffsetType m_FileOffset;
boost::uint32_t m_NumPoints;
ElevExtrema m_MinZ, m_MaxZ;
IndexCellData m_PtRecords;
@@ -70,9 +71,9 @@
IndexSubCellData m_SubCellRecords;
public:
- void SetFileOffset(boost::uint32_t fos);
+ void SetFileOffset(TempFileOffsetType fos);
void SetNumPoints(boost::uint32_t nmp);
- boost::uint32_t GetFileOffset(void) const;
+ TempFileOffsetType GetFileOffset(void) const;
boost::uint32_t GetNumRecords(void) const;
boost::uint32_t GetNumPoints(void) const;
boost::uint32_t GetNumSubCellRecords(void) const;
diff -r 02df82d848f4 -r 51de9d42769f include/liblas/lasindex.hpp
--- a/include/liblas/lasindex.hpp Mon Oct 25 10:40:08 2010 -0500
+++ b/include/liblas/lasindex.hpp Tue Oct 26 07:19:19 2010 -0600
@@ -140,7 +140,8 @@
int m_debugOutputLevel;
boost::uint8_t m_versionMajor, m_versionMinor;
boost::uint32_t m_pointRecordsCount, m_maxMemoryUsage, m_cellsX, m_cellsY, m_cellsZ, m_totalCells,
- m_tempFileWrittenBytes, m_DataVLR_ID;
+ m_DataVLR_ID;
+ liblas::detail::TempFileOffsetType m_tempFileWrittenBytes;
double m_rangeX, m_rangeY, m_rangeZ, m_cellSizeZ, m_cellSizeX, m_cellSizeY;
std::string m_tempFileName;
std::string m_indexAuthor;
diff -r 02df82d848f4 -r 51de9d42769f src/detail/index/indexcell.cpp
--- a/src/detail/index/indexcell.cpp Mon Oct 25 10:40:08 2010 -0500
+++ b/src/detail/index/indexcell.cpp Tue Oct 26 07:19:19 2010 -0600
@@ -57,7 +57,7 @@
} // IndexCell::IndexCell
-void IndexCell::SetFileOffset(boost::uint32_t fos)
+void IndexCell::SetFileOffset(TempFileOffsetType fos)
m_FileOffset = fos;
} // IndexCell::SetFileOffset
@@ -67,7 +67,7 @@
m_NumPoints = nmp;
} // IndexCell::SetNumPoints
-boost::uint32_t IndexCell::GetFileOffset(void) const
+TempFileOffsetType IndexCell::GetFileOffset(void) const
return(m_FileOffset);
} // IndexCell::GetFileOffset
diff -r 02df82d848f4 -r 51de9d42769f src/lasindex.cpp
--- a/src/lasindex.cpp Mon Oct 25 10:40:08 2010 -0500
+++ b/src/lasindex.cpp Tue Oct 26 07:19:19 2010 -0600
@@ -122,7 +122,8 @@
m_DataVLR_ID = 43;
m_maxMemoryUsage = LIBLAS_INDEX_MAXMEMDEFAULT;
m_rangeX = m_rangeY = m_rangeZ = m_cellSizeZ = m_cellSizeX = m_cellSizeY =
- m_pointRecordsCount = m_maxMemoryUsage = m_cellsX = m_cellsY = m_cellsZ = m_totalCells = m_tempFileWrittenBytes = 0;
+ m_pointRecordsCount = m_maxMemoryUsage = m_cellsX = m_cellsY = m_cellsZ = m_totalCells = 0;
+ m_tempFileWrittenBytes = 0;
m_indexBuilt = m_tempFileStarted = m_readerCreated = false;
} // Index::SetValues
@@ -1025,8 +1026,7 @@
m_versionMinor = LIBLAS_INDEX_VERSIONMINOR;
// reset to beginning of point data records in case points had been examined before index is built
- m_reader->Reset();
+ m_reader->seek(0);
// need the header to get number of point records
m_pointRecordsCount = m_pointheader.GetPointRecordsCount();
// get the bounds of the data and scale factors in case they are needed for point translation
@@ -1164,11 +1164,9 @@
// If a cell contains too many points, subdivide the cell and save sub-cells within the cell structure
// If Z-binning is desired, define the bounds of each Z zone and subdivide sort each cell's points into Z bins
// Save Z bins within the cell structure.
- // reset Reader to beginning of point data records in case points had been examined before index is built
if (IndexOut.InitiateOutput())
for (boost::uint32_t x = 0; x < m_cellsX; ++x)
for (boost::uint32_t y = 0; y < m_cellsY; ++y)
@@ -1384,7 +1382,7 @@
if (m_tempFile || OpenTempFile())
- boost::uint32_t EmptyOffset = 0; // this might not be large enough
+ liblas::detail::TempFileOffsetType EmptyOffset = 0; // this might not be large enough
if (! m_tempFileStarted)
@@ -1392,12 +1390,12 @@
// write out a block of file offsets the size of the number of cells
for (boost::uint32_t i = 0; i < m_totalCells; ++i)
- if (fwrite(&EmptyOffset, sizeof(boost::uint32_t), 1, m_tempFile) < 1)
+ if (fwrite(&EmptyOffset, sizeof(liblas::detail::TempFileOffsetType), 1, m_tempFile) < 1)
return (FileError("Index::PurgePointsToTempFile"));
} // if error
} // for
- m_tempFileWrittenBytes = m_totalCells * sizeof(boost::uint32_t);
+ m_tempFileWrittenBytes = m_totalCells * sizeof(liblas::detail::TempFileOffsetType);
m_tempFileStarted = true;
} // if
@@ -1411,20 +1409,20 @@
// if cell block header is 0 write the current file location in the file header
// otherwise write the current file location at the file location specified in the
// cell block header
- boost::uint32_t LastWriteLocation = CellBlock[x][y].GetFileOffset();
+ liblas::detail::TempFileOffsetType LastWriteLocation = CellBlock[x][y].GetFileOffset();
if (LastWriteLocation == 0)
- LastWriteLocation = (x * m_cellsY + y) * sizeof(boost::uint32_t);
- fseek(m_tempFile, LastWriteLocation, SEEK_SET);
- if (fwrite(&m_tempFileWrittenBytes, sizeof(boost::uint32_t), 1, m_tempFile) < 1)
+ LastWriteLocation = (x * m_cellsY + y) * sizeof(liblas::detail::TempFileOffsetType);
+ _fseeki64(m_tempFile, LastWriteLocation, SEEK_SET);
+ if (fwrite(&m_tempFileWrittenBytes, sizeof(liblas::detail::TempFileOffsetType), 1, m_tempFile) < 1)
CellBlock[x][y].SetFileOffset(m_tempFileWrittenBytes);
// seek to end of file where next block of data will be written
- fseek(m_tempFile, 0, SEEK_END);
+ _fseeki64(m_tempFile, 0, SEEK_END);
// write a blank space for later placement of next file block for this cell
- m_tempFileWrittenBytes += sizeof(boost::uint32_t);
+ m_tempFileWrittenBytes += sizeof(liblas::detail::TempFileOffsetType);
// write the number of records stored in this section
if (fwrite(&RecordsToWrite, sizeof(boost::uint32_t), 1, m_tempFile) < 1)
@@ -1462,23 +1460,24 @@
boost::uint32_t CurCellX, boost::uint32_t CurCellY)
- boost::uint32_t FileOffset, RecordsToRead, FormerNumPts, NewNumPts = 0;
+ boost::uint32_t RecordsToRead, FormerNumPts, NewNumPts = 0;
+ liblas::detail::TempFileOffsetType FileOffset;
FormerNumPts = CellBlock->GetNumPoints();
CellBlock->SetNumPoints(0);
// load the cell as it was written
// read the first offset for this cell
- if (fseek(m_tempFile, (CurCellX * m_cellsY + CurCellY) * sizeof (boost::uint32_t), SEEK_SET))
+ if (_fseeki64(m_tempFile, (CurCellX * m_cellsY + CurCellY) * sizeof (liblas::detail::TempFileOffsetType), SEEK_SET))
return (FileError("Index::LoadCellFromTempFile"));
- if (fread(&FileOffset, sizeof (boost::uint32_t), 1, m_tempFile) < 1)
+ if (fread(&FileOffset, sizeof (liblas::detail::TempFileOffsetType), 1, m_tempFile) < 1)
while (FileOffset > 0)
// jump to the first block for this cell, read the next offset
- if (fseek(m_tempFile, FileOffset, SEEK_SET))
+ if (_fseeki64(m_tempFile, FileOffset, SEEK_SET))
// read the data for the cell in this block
// first is the number of items to read now
@@ -1534,7 +1533,7 @@
try {
Writer writer(*m_ofs, m_idxheader);
while (m_reader->ReadNextPoint())
Point CurPt = m_reader->GetPoint();
@@ -1553,7 +1552,7 @@
try {
/* test block - uncommenting this makes it just like above version with included points
More information about the Liblas-commits
