[Liblas-commits] hg: set an argv/argc so it will compile
liblas-commits at liblas.org
Tue Oct 26 09:31:57 EDT 2010
changeset 973726947c23 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=973726947c23
summary: set an argv/argc so it will compile
diffstat:
apps/lasindex_test.cpp | 4 ++--
1 files changed, 2 insertions(+), 2 deletions(-)
diffs (19 lines):
diff -r 51de9d42769f -r 973726947c23 apps/lasindex_test.cpp
--- a/apps/lasindex_test.cpp Tue Oct 26 07:19:19 2010 -0600
+++ b/apps/lasindex_test.cpp Tue Oct 26 07:31:35 2010 -0600
@@ -235,13 +235,13 @@
"-n", "C:\\LibLAS\\Samples\\N1440375_idx.ldx", "-r"};
argc = 6;
- /*-----------------build embedded index, filter with user bounds------------
+ /*-----------------build embedded index, filter with user bounds------------ */
const char* arggv[] = {"foo", "-t", "C:\\LibLAS\\Samples\\N1440375.tmp",
"-i", "C:\\LibLAS\\Samples\\N1440375.las", "-a", SAMPLE_AUTHOR, "-c", SAMPLE_COMMENT, "-d", SAMPLE_DATE,
"-o", "C:\\LibLAS\\Samples\\N1440375_idx.las",
"-x", "1443000.00", "1444000.00", "-y", "376000.02", "379000.00", "-z", "850.00", "950.00"};
argc = 22;
/*------------filter with embedded index using iterator---------------------
"-i", "C:\\LibLAS\\Samples\\N1440375_idx.las", "-r", "-it", "20000"};
More information about the Liblas-commits
