[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Oct 26 10:46:46 EDT 2010
changeset fdc33fcd75bc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=fdc33fcd75bc
summary: silence issues with _fseeki64 and #ifdef it to only be used on _MSC_VER
changeset 974aab1b8277 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=974aab1b8277
summary: clean up some warnings and add some error checking to color filter
diffstat:
 apps/laskernel.cpp |  26 ++++++++++++++++++++++----
 src/lasindex.cpp   |  28 ++++++++++++++++++++++++----
 2 files changed, 46 insertions(+), 8 deletions(-)
diffs (145 lines):
diff -r 973726947c23 -r 974aab1b8277 apps/laskernel.cpp
--- a/apps/laskernel.cpp	Tue Oct 26 07:31:35 2010 -0600
+++ b/apps/laskernel.cpp	Tue Oct 26 09:46:37 2010 -0500
@@ -153,7 +153,7 @@
                       tree.get<double>("summary.points.maximum.y"),
                       tree.get<double>("summary.points.maximum.z"));
-    }     catch (liblas::property_tree::ptree_bad_path const& e)
+    }     catch (liblas::property_tree::ptree_bad_path const& )
         std::cerr << "Unable to write header bounds info.  Does the outputted file have any points?";
         return;
@@ -175,7 +175,7 @@
             header.SetPointRecordsByReturnCount(i-1, count);
         std::cerr << "Unable to write header point return count info.  Does the outputted file have any points?";
         return;
@@ -585,7 +585,16 @@
             std::vector<liblas::Color::value_type> rgb;
             for(tokenizer::iterator c = rgbs.begin(); c != rgbs.end(); ++c)
-                rgb.push_back(atoi((*c).c_str()));
+                int color_val = atoi((*c).c_str());
+                if (color_val < std::numeric_limits<boost::uint16_t>::min() ||
+                    color_val > std::numeric_limits<boost::uint16_t>::max())
+                    ostringstream oss;
+                    oss << "Color value must be between 0-65536, not " << color_val;
+                    throw std::runtime_error( oss.str() );
+                rgb.push_back(static_cast<boost::uint16_t>(color_val));
             liblas::Color color(rgb[0], rgb[1], rgb[2]);
             colors.push_back(color);
@@ -611,7 +620,16 @@
diff -r 973726947c23 -r 974aab1b8277 src/lasindex.cpp
--- a/src/lasindex.cpp	Tue Oct 26 07:31:35 2010 -0600
+++ b/src/lasindex.cpp	Tue Oct 26 09:46:37 2010 -0500
@@ -914,7 +914,7 @@
 			// seek and read
 			assert(static_cast<boost::uint32_t>(PointID) < m_pointRecordsCount);
-			PtRead = (m_reader->seek(PointID) && m_reader->ReadNextPoint());
+			PtRead = (m_reader->seek(PointID) && m_reader->ReadNextPoint());
 		} // if
 		if (PtRead)
@@ -957,7 +957,7 @@
 					// seek and read
 				} // if
 				if (PtRead)
@@ -1001,7 +1001,7 @@
 					// seek and read
 				} // if
 				if (PtRead)
@@ -1190,7 +1190,7 @@
 								// get the actual point from the las file
 								assert(MapIt->first < m_pointRecordsCount);
-								if (m_reader->seek(MapIt->first) && m_reader->ReadNextPoint())
+								if (m_reader->seek(MapIt->first) && m_reader->ReadNextPoint())
 									boost::uint32_t FirstPt = 0, LastCellZ = static_cast<boost::uint32_t>(~0);
 									boost::uint32_t LastSubCell = static_cast<boost::uint32_t>(~0);
@@ -1412,13 +1412,22 @@
 					liblas::detail::TempFileOffsetType LastWriteLocation = CellBlock[x][y].GetFileOffset();
 					if (LastWriteLocation == 0)
 						LastWriteLocation = (x * m_cellsY + y) * sizeof(liblas::detail::TempFileOffsetType);
+#ifdef _MSC_VER
 					_fseeki64(m_tempFile, LastWriteLocation, SEEK_SET);
+#else
+					fseek(m_tempFile, LastWriteLocation, SEEK_SET);
+#endif
 					if (fwrite(&m_tempFileWrittenBytes, sizeof(liblas::detail::TempFileOffsetType), 1, m_tempFile) < 1)
 						return (FileError("Index::PurgePointsToTempFile"));
 					CellBlock[x][y].SetFileOffset(m_tempFileWrittenBytes);
 					// seek to end of file where next block of data will be written
+#ifdef _MSC_VER
 					_fseeki64(m_tempFile, 0, SEEK_END);
+#else
+					fseek(m_tempFile, 0, SEEK_END);
+#endif
 					// write a blank space for later placement of next file block for this cell
 					if (fwrite(&EmptyOffset, sizeof(liblas::detail::TempFileOffsetType), 1, m_tempFile) < 1)
@@ -1468,14 +1477,25 @@
 	// load the cell as it was written
 	// read the first offset for this cell
+#ifdef _MSC_VER
 	if (_fseeki64(m_tempFile, (CurCellX * m_cellsY + CurCellY) * sizeof (liblas::detail::TempFileOffsetType), SEEK_SET))
+#else
+	if (fseek(m_tempFile, (CurCellX * m_cellsY + CurCellY) * sizeof (liblas::detail::TempFileOffsetType), SEEK_SET))
+#endif
 		return (FileError("Index::LoadCellFromTempFile"));
 	if (fread(&FileOffset, sizeof (liblas::detail::TempFileOffsetType), 1, m_tempFile) < 1)
 	while (FileOffset > 0)
 		// jump to the first block for this cell, read the next offset
+#ifdef _MSC_VER
 		if (_fseeki64(m_tempFile, FileOffset, SEEK_SET))
+#else
+		if (fseek(m_tempFile, FileOffset, SEEK_SET))
+#endif
More information about the Liblas-commits mailing list
