[Liblas-commits] hg: more error checking and appropriate casting of
shorts
liblas-commits at liblas.org
Tue Oct 26 11:29:56 EDT 2010
changeset 83a42a40ae96 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=83a42a40ae96
summary: more error checking and appropriate casting of shorts
diffstat:
apps/laskernel.cpp | 30 ++++++++++++++++++++++++++----
1 files changed, 26 insertions(+), 4 deletions(-)
diffs (61 lines):
diff -r 6c885263069c -r 83a42a40ae96 apps/laskernel.cpp
--- a/apps/laskernel.cpp Tue Oct 26 10:22:26 2010 -0500
+++ b/apps/laskernel.cpp Tue Oct 26 10:29:51 2010 -0500
@@ -974,7 +974,7 @@
if (vlrs.size() % 2 != 0) {
ostringstream err;
- err << "VLR descriptions must be in pairs of 2";
+ err << "VLR descriptions must be in pairs of 2 -- A name and an ID";
throw std::runtime_error(err.str());
ostringstream oss;
@@ -993,7 +993,17 @@
for (std::vector<std::string>::size_type i = 0; i < vlrs.size(); i=i+2)
- header.DeleteVLRs(vlrs[i], atoi(vlrs[i+1].c_str()));
+ boost::int32_t id = atoi(vlrs[i+1].c_str());
+ if (id < 0)
+ throw std::runtime_error("VLR ID must be > 0");
+ if (id > std::numeric_limits<boost::uint16_t>::max()) {
+ ostringstream oss;
+ oss << "ID must be less than "<< std::numeric_limits<boost::uint16_t>::max() <<", not " << id;
+ throw std::runtime_error(oss.str());
+ header.DeleteVLRs(vlrs[i], static_cast<boost::uint16_t>(id));
@@ -1022,7 +1032,19 @@
liblas::VariableRecord v;
v.SetUserId(vlrs[0]);
- v.SetRecordId(atoi(vlrs[1].c_str()));
+ boost::int32_t id = atoi(vlrs[1].c_str());
+ if (id < 0)
+ v.SetRecordId(id);
std::vector<boost::uint8_t> data;
@@ -1067,7 +1089,7 @@
v.SetData(data);
- v.SetRecordLength(data.size());
+ v.SetRecordLength(static_cast<boost::uint16_t>(data.size()));
header.AddVLR(v);
More information about the Liblas-commits
