[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Tue Oct 26 11:59:27 EDT 2010
changeset 67b84bdf17bd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=67b84bdf17bd
summary: A cast that Mateusz wouldn't approve of in a function that Mateusz doesn't approve of :)
changeset 1f98e719e1d3 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1f98e719e1d3
summary: BUILT_TYPE define
diffstat:
apps/laskernel.cpp | 4 ++--
hobu-config.bat | 5 ++++-
2 files changed, 6 insertions(+), 3 deletions(-)
diffs (42 lines):
diff -r 83a42a40ae96 -r 1f98e719e1d3 apps/laskernel.cpp
--- a/apps/laskernel.cpp Tue Oct 26 10:29:51 2010 -0500
+++ b/apps/laskernel.cpp Tue Oct 26 09:59:08 2010 -0600
@@ -30,7 +30,7 @@
std::vector<char> data = TryReadRawFileData(filename);
// FIXME: What is this construction supposed to grab? --mloskot
- return std::string(data.front(), (std::size_t) data.size());
+ return std::string((const char*)data.front(), data.size());
std::vector<char> TryReadRawFileData(std::string filename)
@@ -1044,7 +1044,7 @@
throw std::runtime_error(oss.str());
- v.SetRecordId(id);
+ v.SetRecordId(static_cast<boost::uint16_t>(id));
std::vector<boost::uint8_t> data;
diff -r 83a42a40ae96 -r 1f98e719e1d3 hobu-config.bat
--- a/hobu-config.bat Tue Oct 26 10:29:51 2010 -0500
+++ b/hobu-config.bat Tue Oct 26 09:59:08 2010 -0600
@@ -5,6 +5,9 @@
set OSGEO4W=C:\OSGeo4W
set BOOST=D:\boost\boost_1_44
set ORACLE_HOME=%OSGEO4W%
+# set BUILD_TYPE=RelWithDebInfo
+set BUILD_TYPE=Debug
+# set BUILD_TYPE=Release
set PATH=%OSGEO4W%\apps\gdal-dev\bin;%OSGEO4W%\bin;%PATH%
@@ -21,5 +24,5 @@
-DGDAL_LIBRARY=%OSGEO4W%\apps\gdal-dev\lib\gdal_i.lib ^
-DORACLE_INCLUDE_DIR=%ORACLE_HOME%\include ^
-DORACLE_OCI_LIBRARY=%ORACLE_HOME%\lib\oci.lib ^
- -DCMAKE_BUILD_TYPE=RelWithDebInfo ^
+ -DCMAKE_BUILD_TYPE=%BUILD_TYPE% ^
%LIBLAS%
\ No newline at end of file
More information about the Liblas-commits
