[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Tue Oct 26 15:38:17 EDT 2010
changeset 97ec40efc346 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=97ec40efc346
summary: remove SVN tracking files
changeset db448f962223 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=db448f962223
summary: use unsigned integer to return sizes for Schema
diffstat:
include/liblas/capi/liblas.h | 4 +-
include/liblas/external/property_tree/.svn/all-wcprops | 71 -
include/liblas/external/property_tree/.svn/entries | 405 -
include/liblas/external/property_tree/.svn/prop-base/exceptions.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/prop-base/id_translator.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/prop-base/info_parser.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/prop-base/ini_parser.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/prop-base/json_parser.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/prop-base/ptree.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/prop-base/ptree_fwd.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/prop-base/ptree_serialization.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/prop-base/stream_translator.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/prop-base/string_path.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/prop-base/xml_parser.hpp.svn-base | 13 -
include/liblas/external/property_tree/.svn/text-base/exceptions.hpp.svn-base | 84 -
include/liblas/external/property_tree/.svn/text-base/id_translator.hpp.svn-base | 51 -
include/liblas/external/property_tree/.svn/text-base/info_parser.hpp.svn-base | 151 -
include/liblas/external/property_tree/.svn/text-base/ini_parser.hpp.svn-base | 309 -
include/liblas/external/property_tree/.svn/text-base/json_parser.hpp.svn-base | 139 -
include/liblas/external/property_tree/.svn/text-base/ptree.hpp.svn-base | 517 --
include/liblas/external/property_tree/.svn/text-base/ptree_fwd.hpp.svn-base | 143 -
include/liblas/external/property_tree/.svn/text-base/ptree_serialization.hpp.svn-base | 102 -
include/liblas/external/property_tree/.svn/text-base/stream_translator.hpp.svn-base | 221 -
include/liblas/external/property_tree/.svn/text-base/string_path.hpp.svn-base | 272 -
include/liblas/external/property_tree/.svn/text-base/xml_parser.hpp.svn-base | 153 -
include/liblas/external/property_tree/detail/.svn/all-wcprops | 119 -
include/liblas/external/property_tree/detail/.svn/entries | 674 --
include/liblas/external/property_tree/detail/.svn/prop-base/exception_implementation.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/file_parser_error.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/info_parser_error.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/info_parser_read.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/info_parser_utils.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/info_parser_write.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/info_parser_writer_settings.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/json_parser_error.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/json_parser_read.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/json_parser_write.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/ptree_implementation.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/ptree_utils.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/rapidxml.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/xml_parser_error.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/xml_parser_flags.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/xml_parser_read_rapidxml.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/xml_parser_utils.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/xml_parser_write.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/prop-base/xml_parser_writer_settings.hpp.svn-base | 13 -
include/liblas/external/property_tree/detail/.svn/text-base/exception_implementation.hpp.svn-base | 83 -
include/liblas/external/property_tree/detail/.svn/text-base/file_parser_error.hpp.svn-base | 88 -
include/liblas/external/property_tree/detail/.svn/text-base/info_parser_error.hpp.svn-base | 32 -
include/liblas/external/property_tree/detail/.svn/text-base/info_parser_read.hpp.svn-base | 380 -
include/liblas/external/property_tree/detail/.svn/text-base/info_parser_utils.hpp.svn-base | 32 -
include/liblas/external/property_tree/detail/.svn/text-base/info_parser_write.hpp.svn-base | 147 -
include/liblas/external/property_tree/detail/.svn/text-base/info_parser_writer_settings.hpp.svn-base | 40 -
include/liblas/external/property_tree/detail/.svn/text-base/json_parser_error.hpp.svn-base | 33 -
include/liblas/external/property_tree/detail/.svn/text-base/json_parser_read.hpp.svn-base | 328 -
include/liblas/external/property_tree/detail/.svn/text-base/json_parser_write.hpp.svn-base | 170 -
include/liblas/external/property_tree/detail/.svn/text-base/ptree_implementation.hpp.svn-base | 904 ---
include/liblas/external/property_tree/detail/.svn/text-base/ptree_utils.hpp.svn-base | 106 -
include/liblas/external/property_tree/detail/.svn/text-base/rapidxml.hpp.svn-base | 2571 ----------
include/liblas/external/property_tree/detail/.svn/text-base/xml_parser_error.hpp.svn-base | 33 -
include/liblas/external/property_tree/detail/.svn/text-base/xml_parser_flags.hpp.svn-base | 31 -
include/liblas/external/property_tree/detail/.svn/text-base/xml_parser_read_rapidxml.hpp.svn-base | 144 -
include/liblas/external/property_tree/detail/.svn/text-base/xml_parser_utils.hpp.svn-base | 136 -
include/liblas/external/property_tree/detail/.svn/text-base/xml_parser_write.hpp.svn-base | 194 -
include/liblas/external/property_tree/detail/.svn/text-base/xml_parser_writer_settings.hpp.svn-base | 62 -
src/las_c_api.cpp | 10 +-
66 files changed, 6 insertions(+), 9323 deletions(-)
diffs (truncated from 9616 to 300 lines):
diff -r 1f98e719e1d3 -r db448f962223 include/liblas/capi/liblas.h
--- a/include/liblas/capi/liblas.h Tue Oct 26 09:59:08 2010 -0600
+++ b/include/liblas/capi/liblas.h Tue Oct 26 14:37:53 2010 -0500
@@ -1154,8 +1154,8 @@
LAS_DLL void LASString_Free(char* string);
-LAS_DLL unsigned short LASSchema_GetByteSize( LASSchemaH hFormat);
-LAS_DLL unsigned short LASSchema_GetBaseByteSize( LASSchemaH hFormat);
+LAS_DLL unsigned int LASSchema_GetByteSize( LASSchemaH hFormat);
+LAS_DLL unsigned int LASSchema_GetBaseByteSize( LASSchemaH hFormat);
diff -r 1f98e719e1d3 -r db448f962223 include/liblas/external/property_tree/.svn/all-wcprops
--- a/include/liblas/external/property_tree/.svn/all-wcprops Tue Oct 26 09:59:08 2010 -0600
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,71 +0,0 @@
-K 25
-svn:wc:ra_dav:version-url
-V 51
-/svn/boost/!svn/ver/63428/trunk/boost/property_tree
-END
-ini_parser.hpp
-K 25
-V 66
-/svn/boost/!svn/ver/56121/trunk/boost/property_tree/ini_parser.hpp
-END
-ptree_serialization.hpp
-K 25
-V 75
-/svn/boost/!svn/ver/55966/trunk/boost/property_tree/ptree_serialization.hpp
-END
-xml_parser.hpp
-K 25
-V 66
-/svn/boost/!svn/ver/56000/trunk/boost/property_tree/xml_parser.hpp
-END
-ptree.hpp
-K 25
-V 61
-/svn/boost/!svn/ver/55966/trunk/boost/property_tree/ptree.hpp
-END
-ptree_fwd.hpp
-K 25
-V 65
-/svn/boost/!svn/ver/61604/trunk/boost/property_tree/ptree_fwd.hpp
-END
-exceptions.hpp
-K 25
-V 66
-/svn/boost/!svn/ver/55966/trunk/boost/property_tree/exceptions.hpp
-END
-string_path.hpp
-K 25
-V 67
-/svn/boost/!svn/ver/61604/trunk/boost/property_tree/string_path.hpp
-END
-stream_translator.hpp
-K 25
-V 73
-/svn/boost/!svn/ver/56092/trunk/boost/property_tree/stream_translator.hpp
-END
-json_parser.hpp
-K 25
-V 67
-/svn/boost/!svn/ver/59739/trunk/boost/property_tree/json_parser.hpp
-END
-id_translator.hpp
-K 25
-V 69
-/svn/boost/!svn/ver/55966/trunk/boost/property_tree/id_translator.hpp
-END
-info_parser.hpp
-K 25
-V 67
-/svn/boost/!svn/ver/55966/trunk/boost/property_tree/info_parser.hpp
-END
diff -r 1f98e719e1d3 -r db448f962223 include/liblas/external/property_tree/.svn/entries
--- a/include/liblas/external/property_tree/.svn/entries Tue Oct 26 09:59:08 2010 -0600
@@ -1,405 +0,0 @@
-10
-dir
-64982
-http://svn.boost.org/svn/boost/trunk/boost/property_tree
-2010-06-29T13:59:30.440854Z
-63428
-cornedbee
-b8fc166d-592f-0410-95f2-cb63ce0dd405
-ini_parser.hpp
-file
-2009-09-23T14:27:24.952556Z
-93a03eedded67c6784ef8d8492396160
-2009-09-09T12:08:33.739368Z
-56121
-cornedbee
-has-props
-12296
-detail
-dir
-file
-2009-09-23T14:27:24.969558Z
-84edbd6e21ef26dac80a242c91f28ab2
-2009-09-01T21:27:45.485076Z
-55966
-cornedbee
-has-props
-4407
-xml_parser.hpp
-file
-2009-09-23T14:27:24.996560Z
-a94d1c68aae1f0de152f9bd9842c22ac
-2009-09-03T17:37:36.598926Z
-56000
-cornedbee
-has-props
-6691
-ptree.hpp
-file
-2009-09-23T14:27:25.003561Z
-9de13cc1f88ca4ad477ddf9c2be1cfd0
-55966
-cornedbee
-has-props
-21294
-ptree_fwd.hpp
-file
-2010-07-15T14:03:19.811678Z
-20ad03f3313a036040770974b9f485db
-2010-04-27T08:49:25.388185Z
-61604
-cornedbee
-has-props
-4778
-exceptions.hpp
-file
More information about the Liblas-commits
