[Liblas-commits] hg: Removed dead code wrapped with always-false
condition.
liblas-commits at liblas.org
Tue Oct 26 16:07:51 EDT 2010
changeset 368181fe207c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=368181fe207c
summary: Removed dead code wrapped with always-false condition.
diffstat:
src/detail/writer/point.cpp | 9 +++------
1 files changed, 3 insertions(+), 6 deletions(-)
diffs (19 lines):
diff -r db448f962223 -r 368181fe207c src/detail/writer/point.cpp
--- a/src/detail/writer/point.cpp Tue Oct 26 14:37:53 2010 -0500
+++ b/src/detail/writer/point.cpp Tue Oct 26 21:07:21 2010 +0100
@@ -77,12 +77,9 @@
// that we can write into the file as necessary. We make it
// here instead of at each ::write() invocation to save the
// allocation and writing of the array
- if (m_format.GetByteSize() != m_format.GetBaseByteSize()) {
- std::size_t size = m_format.GetByteSize() - m_format.GetBaseByteSize();
- if (size < 0) {
- throw std::runtime_error("ByteSize of format was less than BaseByteSize, this cannot happen!");
+ if (m_format.GetByteSize() != m_format.GetBaseByteSize())
+ std::size_t const size = m_format.GetByteSize() - m_format.GetBaseByteSize();
m_blanks.resize(size);
m_blanks.assign(size, 0);
More information about the Liblas-commits
