[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Tue Oct 26 19:43:16 EDT 2010
changeset ed2f36704a24 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ed2f36704a24
summary: Use stringstream instead of printf with GCC-specific flags.
changeset 1a64145ea9c5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1a64145ea9c5
summary: Removed declaration of IndexCell that does not declare anything
diffstat:
apps/lasindex_test.cpp | 28 ++++++++++++----------------
include/liblas/lasindex.hpp | 1 -
2 files changed, 12 insertions(+), 17 deletions(-)
diffs (63 lines):
diff -r a03892d12365 -r 1a64145ea9c5 apps/lasindex_test.cpp
--- a/apps/lasindex_test.cpp Tue Oct 26 23:18:37 2010 +0100
+++ b/apps/lasindex_test.cpp Wed Oct 27 00:43:04 2010 +0100
@@ -559,13 +559,11 @@
if (FilterResult.size())
// do something with the list of points
- #ifdef VISUAL_8
- fprintf(debugger, "Points within filter area %d of %d, %s\n", FilterResult.size(),
- index.GetPointRecordsCount(), "User-defined filter bounds");
- #else // VISUAL_8
- fprintf(debugger, "Points within filter area %zu of %d, %s\n", FilterResult.size(),
- #endif // VISUAL_8
+ std::ostringstream oss;
+ oss << "Points within filter area " << FilterResult.size()
+ << " of " << index.GetPointRecordsCount()
+ << ",\nUser-defined filter bounds" << std::endl;
+ fprintf(debugger, "%s", oss.str().c_str());
else
IndexFilterNoPoints(debugger);
@@ -660,13 +658,11 @@
- #ifdef VISUAL_8
- index.GetPointRecordsCount(), CovgStr);
- #else // VISUAL_8
+ << ", " << CovgStr << std::endl;
else
@@ -693,8 +689,8 @@
if (static_cast<std::ifstream&>(*idxstrm))
static_cast<std::ifstream&>(*idxstrm).close();
} // if
- if (idxreader)
- delete idxreader;
+ delete idxreader;
delete reader;
} // if reader
diff -r a03892d12365 -r 1a64145ea9c5 include/liblas/lasindex.hpp
--- a/include/liblas/lasindex.hpp Tue Oct 26 23:18:37 2010 +0100
+++ b/include/liblas/lasindex.hpp Wed Oct 27 00:43:04 2010 +0100
@@ -75,7 +75,6 @@
typedef std::vector<liblas::detail::IndexCell> IndexCellRow;
typedef std::vector<IndexCellRow> IndexCellDataBlock;
-class liblas::detail::IndexCell;
class IndexData;
class IndexIterator;
More information about the Liblas-commits
