[Liblas-commits] hg: Do not use stringstream where not not necessary. Mark some v...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Oct 26 19:45:11 EDT 2010
changeset 4c84ffb7b8d5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=4c84ffb7b8d5
summary: Do not use stringstream where not not necessary. Mark some values ast constants to make them optimisation-friendly. Tidy up.
diffstat:
 src/lasdimension.cpp |  28 +++++++++++++---------------
 1 files changed, 13 insertions(+), 15 deletions(-)
diffs (71 lines):
diff -r 1a64145ea9c5 -r 4c84ffb7b8d5 src/lasdimension.cpp
--- a/src/lasdimension.cpp	Wed Oct 27 00:43:04 2010 +0100
+++ b/src/lasdimension.cpp	Wed Oct 27 00:44:58 2010 +0100
@@ -77,12 +77,11 @@
     m_byte_offset(0),
     m_bit_offset(0)
-     if (size_in_bits == 0) {
-        std::ostringstream oss;
-        oss << "The bit size of the dimension is 0, the dimension is invalid.";
-        throw std::runtime_error(oss.str());
+     if (0 == size_in_bits)
+        throw std::runtime_error("The bit size of the dimension is 0, the dimension is invalid.");
 /// copy constructor
 Dimension::Dimension(Dimension const& other) :
@@ -101,8 +100,8 @@
     , m_bit_offset(other.m_bit_offset)
-// // assignment constructor
+/// assignment operator
 Dimension& Dimension::operator=(Dimension const& rhs)
     if (&rhs != this)
@@ -127,9 +126,9 @@
 std::size_t Dimension::GetByteSize() const
-    std::size_t bit_position = m_bit_size % 8;
-    if (bit_position > 0) {
+    std::size_t const bit_position = m_bit_size % 8;
+    if (bit_position > 0)
         // For dimensions that are not byte aligned,
         // we need to determine how many bytes they
         // will take.  We have to read at least one byte if the
@@ -160,9 +159,10 @@
     dim.put("bitoffset" , GetBitOffset());
     dim.put("bytesize", GetByteSize());
-   if (IsNumeric()) {
+   if (IsNumeric())
        if (! (detail::compare_distance(GetMinimum(), GetMaximum() )
-            && detail::compare_distance(0.0, GetMaximum())))
+           && detail::compare_distance(0.0, GetMaximum())))
            dim.put("minimum", GetMinimum());
            dim.put("maximum", GetMaximum());
@@ -174,12 +174,10 @@
 std::ostream& operator<<(std::ostream& os, liblas::Dimension const& d)
     using liblas::property_tree::ptree;
     ptree tree = d.GetPTree();
-    std::string name = tree.get<std::string>("name");
+    std::string const name = tree.get<std::string>("name");
     os << "'" << name << "'" << " -- ";
     os << " size: " << tree.get<boost::uint32_t>("size");
More information about the Liblas-commits mailing list
