[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Sat Oct 30 15:35:29 EDT 2010
changeset 03014c28e3e2 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=03014c28e3e2
summary: Boost is mandatory now - bring original implementation of random byte generator based on Boost.Random.
changeset e1c899bc4a6f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=e1c899bc4a6f
summary: Renamed bigtest.cpp to bigtest.c
diffstat:
apps/CMakeLists.txt | 4 +-
apps/bigtest.c | 55 +++++++++++++++++++++++++++++++
apps/bigtest.cpp | 55 -------------------------------
include/liblas/detail/private_utility.hpp | 13 -------
include/liblas/guid.hpp | 25 +++++++++++++-
5 files changed, 81 insertions(+), 71 deletions(-)
diffs (211 lines):
diff -r b7e2421634c4 -r e1c899bc4a6f apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Sat Oct 30 17:54:55 2010 +0100
+++ b/apps/CMakeLists.txt Sat Oct 30 20:33:49 2010 +0100
@@ -44,7 +44,7 @@
set(LIBLAS_UTILITIES
${LASINFO_OLD} ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
- ${LAS2OGR} ${LAS2OCI} ${LAS2LAS} ${LAS2LAS_OLD} ${LASBLOCK} ${TS2LAS} )
+ ${LAS2OGR} ${LAS2OCI} ${LAS2LAS} ${LAS2LAS_OLD} ${LASBLOCK} ${TS2LAS})
# TODO: Experimental and requires testing --mloskot
# Generate user-specific settings for Visual Studio project
@@ -142,7 +142,7 @@
endif()
if(BIGFILE_TEST)
- add_executable(${BIGFILE_TEST} bigtest.cpp)
+ add_executable(${BIGFILE_TEST} bigtest.c)
target_link_libraries(${BIGFILE_TEST} ${LIBLAS_C_LIB_NAME})
endif()
diff -r b7e2421634c4 -r e1c899bc4a6f apps/bigtest.c
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/apps/bigtest.c Sat Oct 30 20:33:49 2010 +0100
@@ -0,0 +1,55 @@
+#include <liblas.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+void dumperror (const char * appmsg)
+ printf("\n%s.\n\tMessage: %s\n\tMethod: %s",appmsg, LASError_GetLastErrorMsg(), LASError_GetLastErrorMethod());
+int main()
+ LASHeaderH header = NULL;
+ LASWriterH writer = NULL;
+ LASReaderH reader = NULL;
+ LASError err;
+ // Limitation about seeking past 4GB output size. At 20 bytes / record, we
+ // can successfully write 204 million records, but not 205.
+ const unsigned long nMillionPoints = 205;
+ const unsigned long NPOINTS = 1024*1024*nMillionPoints ;
+ const char * OutputName = "Issue147.las";
+ // Write a LAS file and after the points are in, update the header.
+ header = LASHeader_Create();
+ writer = LASWriter_Create(OutputName, header, LAS_MODE_WRITE);
+ for (unsigned long i = 0; i < NPOINTS; i++)
+ double percentDone = ((double)i)/NPOINTS * 100.0;
+ if (i % 1000 == 0)
+ printf("\b\b\b\b\b\b\b%6.2f%%", percentDone);
+ LASPointH pt = LASPoint_Create();
+ err = LASPoint_SetX(pt, 0);
+ if (err) printf ("For point %lu, failed to set point value X\n", i);
+ err = LASPoint_SetY(pt, 0);
+ if (err) printf ("For point %lu, failed to set point value Y\n", i);
+ err = LASPoint_SetZ(pt, 0);
+ if (err) printf ("For point %lu, failed to set point value Z\n", i);
+ err = LASWriter_WritePoint(writer, pt);
+ if (err) printf ("For point %lu, failed to WritePoint\n", i);
+ LASPoint_Destroy(pt);
+ err = LASHeader_SetPointRecordsCount(header, NPOINTS);
+ if (err) dumperror ("Failed to LASHeader_SetPointRecordsCount\n");
+ err = LASWriter_WriteHeader(writer, header);
+ if (err) dumperror ("Failed to LASWriter_WriteHeader");
+ LASWriter_Destroy(writer);
+ LASHeader_Destroy(header);
+ // Read the file we just wrote and check the header data.
+ reader = LASReader_Create(OutputName);
+ header = LASReader_GetHeader(reader);
+ unsigned long npoints = LASHeader_GetPointRecordsCount(header);
+ printf ("\n\nWrote %lu, Read %lu (testing %lu Million (1024 x 1024) Points)\n", NPOINTS, npoints, nMillionPoints);
diff -r b7e2421634c4 -r e1c899bc4a6f apps/bigtest.cpp
--- a/apps/bigtest.cpp Sat Oct 30 17:54:55 2010 +0100
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,55 +0,0 @@
-#include <liblas.h>
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-void dumperror (const char * appmsg)
- printf("\n%s.\n\tMessage: %s\n\tMethod: %s",appmsg, LASError_GetLastErrorMsg(), LASError_GetLastErrorMethod());
-int main()
- LASHeaderH header = NULL;
- LASWriterH writer = NULL;
- LASReaderH reader = NULL;
- LASError err;
- // Limitation about seeking past 4GB output size. At 20 bytes / record, we
- // can successfully write 204 million records, but not 205.
- const unsigned long nMillionPoints = 205;
- const unsigned long NPOINTS = 1024*1024*nMillionPoints ;
- const char * OutputName = "Issue147.las";
- // Write a LAS file and after the points are in, update the header.
- header = LASHeader_Create();
- writer = LASWriter_Create(OutputName, header, LAS_MODE_WRITE);
- for (unsigned long i = 0; i < NPOINTS; i++)
- double percentDone = ((double)i)/NPOINTS * 100.0;
- if (i % 1000 == 0)
- printf("\b\b\b\b\b\b\b%6.2f%%", percentDone);
- LASPointH pt = LASPoint_Create();
- err = LASPoint_SetX(pt, 0);
- if (err) printf ("For point %lu, failed to set point value X\n", i);
- err = LASPoint_SetY(pt, 0);
- if (err) printf ("For point %lu, failed to set point value Y\n", i);
- err = LASPoint_SetZ(pt, 0);
- if (err) printf ("For point %lu, failed to set point value Z\n", i);
- err = LASWriter_WritePoint(writer, pt);
- if (err) printf ("For point %lu, failed to WritePoint\n", i);
- LASPoint_Destroy(pt);
- err = LASHeader_SetPointRecordsCount(header, NPOINTS);
- if (err) dumperror ("Failed to LASHeader_SetPointRecordsCount\n");
- err = LASWriter_WriteHeader(writer, header);
- if (err) dumperror ("Failed to LASWriter_WriteHeader");
- LASWriter_Destroy(writer);
- LASHeader_Destroy(header);
- // Read the file we just wrote and check the header data.
- reader = LASReader_Create(OutputName);
- header = LASReader_GetHeader(reader);
- unsigned long npoints = LASHeader_GetPointRecordsCount(header);
- printf ("\n\nWrote %lu, Read %lu (testing %lu Million (1024 x 1024) Points)\n", NPOINTS, npoints, nMillionPoints);
diff -r b7e2421634c4 -r e1c899bc4a6f include/liblas/detail/private_utility.hpp
--- a/include/liblas/detail/private_utility.hpp Sat Oct 30 17:54:55 2010 +0100
+++ b/include/liblas/detail/private_utility.hpp Sat Oct 30 20:33:49 2010 +0100
@@ -223,19 +223,6 @@
// return (!lhs.equal(rhs));
-template <typename T>
-inline T generate_random_byte()
- // Requires pseudo-random numbers generator to be initialized
- // in create_random_based() function - a poor man solution.
- T const rmin = (std::numeric_limits<T>::min)();
- T const rmax = (std::numeric_limits<T>::max)();
- unsigned int const rnd = std::rand() % rmax + rmin;
- assert(rnd <= 255);
- return static_cast<T>(rnd);
bool compare_distance(const T& actual, const T& expected)
diff -r b7e2421634c4 -r e1c899bc4a6f include/liblas/guid.hpp
--- a/include/liblas/guid.hpp Sat Oct 30 17:54:55 2010 +0100
+++ b/include/liblas/guid.hpp Sat Oct 30 20:33:49 2010 +0100
@@ -64,6 +64,7 @@
// boost
#include <boost/array.hpp>
#include <boost/cstdint.hpp>
+#include <boost/random.hpp>
// std
#include <iosfwd>
#include <iomanip>
@@ -79,6 +80,28 @@
namespace liblas {
+namespace detail {
+ inline uint8_t random_byte()
+ // Change seed to something better?
+ typedef boost::mt19937 engine_t;
+ typedef boost::uniform_int<unsigned long> distribution_t;
+ typedef boost::variate_generator<engine_t, distribution_t> generator_t;
+ static generator_t generator(
+ engine_t(static_cast<engine_t::result_type>( std::time(0) )),
+ // this line should work and does, but it produces lots of warnings
+ // thus we will use unsigned long and cast it to a uint8_t
+ //distribution_t((std::numeric_limits<uint8_t>::min)(), (std::numeric_limits<uint8_t>::max)()));
+ distribution_t((std::numeric_limits<unsigned long>::min)(), (std::numeric_limits<unsigned long>::max)()));
+ return static_cast<uint8_t>(generator() & 0xFF);
+} // namespace detail
/// Definition of Globally Unique Identifier type.
/// The GUID is a 16-byte (128-bit) number.
/// This class is used to represent value stored as Project Identifier
@@ -418,7 +441,7 @@
for (size_t i = 0; i < result.data_.size(); i++)
- result.data_[i] = detail::generate_random_byte<boost::uint8_t>();
+ result.data_[i] = detail::random_byte();
// set variant
More information about the Liblas-commits
