[Liblas-commits] hg: Made bigtest.c ANSI C program
liblas-commits at liblas.org
Sat Oct 30 15:53:44 EDT 2010
changeset b701def97f83 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=b701def97f83
summary: Made bigtest.c ANSI C program
diffstat:
apps/bigtest.c | 13 ++++++++-----
1 files changed, 8 insertions(+), 5 deletions(-)
diffs (42 lines):
diff -r e1c899bc4a6f -r b701def97f83 apps/bigtest.c
--- a/apps/bigtest.c Sat Oct 30 20:33:49 2010 +0100
+++ b/apps/bigtest.c Sat Oct 30 20:53:30 2010 +0100
@@ -13,23 +13,26 @@
LASHeaderH header = NULL;
LASWriterH writer = NULL;
LASReaderH reader = NULL;
+ LASPointH pt = NULL;
LASError err;
// Limitation about seeking past 4GB output size. At 20 bytes / record, we
// can successfully write 204 million records, but not 205.
const unsigned long nMillionPoints = 205;
const unsigned long NPOINTS = 1024*1024*nMillionPoints ;
const char * OutputName = "Issue147.las";
+ unsigned long i = 0;
+ unsigned long npoints = 0;
// Write a LAS file and after the points are in, update the header.
header = LASHeader_Create();
writer = LASWriter_Create(OutputName, header, LAS_MODE_WRITE);
- for (unsigned long i = 0; i < NPOINTS; i++)
+ for (i = 0; i < NPOINTS; i++)
- double percentDone = ((double)i)/NPOINTS * 100.0;
if (i % 1000 == 0)
- printf("\b\b\b\b\b\b\b%6.2f%%", percentDone);
+ printf("\b\b\b\b\b\b\b%6.2f%%", ((double)i)/NPOINTS * 100.0);
- LASPointH pt = LASPoint_Create();
+ pt = LASPoint_Create();
err = LASPoint_SetX(pt, 0);
if (err) printf ("For point %lu, failed to set point value X\n", i);
err = LASPoint_SetY(pt, 0);
@@ -50,6 +53,6 @@
// Read the file we just wrote and check the header data.
reader = LASReader_Create(OutputName);
header = LASReader_GetHeader(reader);
- unsigned long npoints = LASHeader_GetPointRecordsCount(header);
+ npoints = LASHeader_GetPointRecordsCount(header);
printf ("\n\nWrote %lu, Read %lu (testing %lu Million (1024 x 1024) Points)\n", NPOINTS, npoints, nMillionPoints);
More information about the Liblas-commits
