[Liblas-commits] hg: remove SetDataRecordLength,
which didn't exist in 1.2, so no...
liblas-commits at liblas.org
Wed Sep 1 10:23:07 EDT 2010
changeset 3dc0e60ff216 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=3dc0e60ff216
summary: remove SetDataRecordLength, which didn't exist in 1.2, so no consequence API-wise. If you want to increase the data record length, you must add dimensions to a liblas::Schema
diffstat:
include/liblas/lasheader.hpp | 13 +++++++------
src/lasheader.cpp | 31 +------------------------------
2 files changed, 8 insertions(+), 36 deletions(-)
diffs (77 lines):
diff -r 0a9071b292e9 -r 3dc0e60ff216 include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp Tue Aug 31 21:19:25 2010 -0500
+++ b/include/liblas/lasheader.hpp Wed Sep 01 09:23:01 2010 -0500
@@ -233,13 +233,14 @@
/// Set identifier of point data (record) format.
void SetDataFormatId(PointFormatName v);
- /// \todo To be documented
+ /// The length in bytes of each point. All points in the file are
+ /// considered to be fixed in size, and the PointFormatName is used
+ /// to determine the fixed portion of the dimensions in the point. Any
+ /// other byte space in the point record beyond the liblas::Schema::GetBaseByteSize()
+ /// can be used for other, optional, dimensions. If no schema is
+ /// available for the file in the form of a liblas.org VLR schema record,
+ /// These extra bytes are available via liblas::Point::GetExtraData().
boost::uint16_t GetDataRecordLength() const;
- // /// Set the length of the point format. Evidently, there are
- // /// LAS files in the wild that contain point formats of sizes that
- // /// are different than the prescribed set specified in the specification.
- // void SetDataRecordLength(boost::uint16_t v);
/// Get total number of point records stored in the LAS file.
boost::uint32_t GetPointRecordsCount() const;
diff -r 0a9071b292e9 -r 3dc0e60ff216 src/lasheader.cpp
--- a/src/lasheader.cpp Tue Aug 31 21:19:25 2010 -0500
+++ b/src/lasheader.cpp Wed Sep 01 09:23:01 2010 -0500
@@ -382,37 +382,12 @@
liblas::PointFormatName Header::GetDataFormatId() const
return m_format.GetDataFormatId();
- // if (ePointFormat0 == m_dataFormatId)
- // return ePointFormat0;
- // else if (ePointFormat1 == m_dataFormatId)
- // return ePointFormat1;
- // else if (ePointFormat2 == m_dataFormatId)
- // return ePointFormat2;
- // else
- // return ePointFormat3;
void Header::SetDataFormatId(liblas::PointFormatName v)
m_format.SetDataFormatId(v);
- // m_dataFormatId = static_cast<uint8_t>(v);
- // UpdateSchema();
- // SetDataRecordLength(ePointSize0);
- // SetDataRecordLength(ePointSize1);
- // SetDataRecordLength(ePointSize2);
- // else if (ePointFormat3 == m_dataFormatId)
- // SetDataRecordLength(ePointSize3);
- // else
uint16_t Header::GetDataRecordLength() const
@@ -420,10 +395,6 @@
return m_format.GetByteSize();
-// void Header::SetDataRecordLength( uint16_t v )
-// // m_format.SetByteSize(v);
uint32_t Header::GetPointRecordsCount() const
return m_pointRecordsCount;
More information about the Liblas-commits
