[Liblas-commits] hg: Make liblas::Reader::SetFilters and
liblas::Reader::SetTrans...
liblas-commits at liblas.org
Wed Sep 1 10:44:17 EDT 2010
changeset 1a800948d1ca in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1a800948d1ca
summary: Make liblas::Reader::SetFilters and liblas::Reader::SetTransforms take in shared_ptr's instead of raw pointers
diffstat:
apps/las2las2.cpp | 12 ++----
apps/las2oci.cpp | 14 +------
apps/laskernel.cpp | 84 ++++++++++++++++++++++----------------------
apps/laskernel.hpp | 18 ++++----
include/liblas/lasfilter.hpp | 3 +
include/liblas/lasreader.hpp | 11 +++--
include/liblas/lasschema.hpp | 50 --------------------------
src/lasreader.cpp | 22 +++++-----
8 files changed, 77 insertions(+), 137 deletions(-)
diffs (truncated from 608 to 300 lines):
diff -r 3dc0e60ff216 -r 1a800948d1ca apps/las2las2.cpp
--- a/apps/las2las2.cpp Wed Sep 01 09:23:01 2010 -0500
+++ b/apps/las2las2.cpp Wed Sep 01 09:44:06 2010 -0500
@@ -99,8 +99,8 @@
bool process( std::string const& input,
std::string const& output,
liblas::Header const& header,
- std::vector<liblas::FilterI*>& filters,
- std::vector<liblas::TransformI*>& transforms,
+ std::vector<liblas::FilterPtr>& filters,
+ std::vector<liblas::TransformPtr>& transforms,
boost::uint32_t split_size,
bool verbose)
@@ -184,10 +184,6 @@
delete writer;
delete ofs;
- for(std::vector<liblas::FilterI*>::iterator i=filters.begin(); i!=filters.end(); i++)
- delete *i;
return true;
@@ -209,8 +205,8 @@
std::string output;
bool verbose = false;
- std::vector<liblas::FilterI*> filters;
- std::vector<liblas::TransformI*> transforms;
+ std::vector<liblas::FilterPtr> filters;
+ std::vector<liblas::TransformPtr> transforms;
liblas::Header header;
diff -r 3dc0e60ff216 -r 1a800948d1ca apps/las2oci.cpp
--- a/apps/las2oci.cpp Wed Sep 01 09:23:01 2010 -0500
+++ b/apps/las2oci.cpp Wed Sep 01 09:44:06 2010 -0500
@@ -741,8 +741,8 @@
bool debug = false;
@@ -1279,16 +1279,6 @@
con->Commit();
- delete *i;
- for(std::vector<liblas::TransformI*>::iterator i=transforms.begin(); i!=transforms.end(); i++)
- delete *i;
delete reader2;
delete istrm2;
diff -r 3dc0e60ff216 -r 1a800948d1ca apps/laskernel.cpp
--- a/apps/laskernel.cpp Wed Sep 01 09:23:01 2010 -0500
+++ b/apps/laskernel.cpp Wed Sep 01 09:44:06 2010 -0500
@@ -12,7 +12,7 @@
return false;
-liblas::FilterI* MakeReturnFilter(std::string return_string, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeReturnFilter(std::string return_string, liblas::FilterI::FilterType ftype)
boost::char_separator<char> sep(SEPARATORS);
@@ -24,11 +24,11 @@
liblas::ReturnFilter* return_filter = new liblas::ReturnFilter(returns, false);
return_filter->SetType(ftype);
- return return_filter;
+ return liblas::FilterPtr(return_filter);
-liblas::FilterI* MakeClassFilter(std::string class_string, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeClassFilter(std::string class_string, liblas::FilterI::FilterType ftype)
@@ -40,10 +40,10 @@
liblas::ClassificationFilter* class_filter = new liblas::ClassificationFilter(classes);
class_filter->SetType(ftype);
- return class_filter;
+ return liblas::FilterPtr(class_filter);
-liblas::FilterI* MakeBoundsFilter(std::string bounds_string, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeBoundsFilter(std::string bounds_string, liblas::FilterI::FilterType ftype)
std::vector<double> vbounds;
@@ -74,38 +74,38 @@
liblas::BoundsFilter* bounds_filter = new liblas::BoundsFilter(bounds);
bounds_filter->SetType(ftype);
- return bounds_filter;
+ return liblas::FilterPtr(bounds_filter);
-liblas::FilterI* MakeIntensityFilter(std::string intensities, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeIntensityFilter(std::string intensities, liblas::FilterI::FilterType ftype)
liblas::ContinuousValueFilter<boost::uint16_t>::filter_func f = &liblas::Point::GetIntensity;
liblas::ContinuousValueFilter<boost::uint16_t>* intensity_filter = new liblas::ContinuousValueFilter<boost::uint16_t>(f, intensities);
intensity_filter->SetType(ftype);
- return intensity_filter;
+ return liblas::FilterPtr(intensity_filter);
-liblas::FilterI* MakeTimeFilter(std::string times, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeTimeFilter(std::string times, liblas::FilterI::FilterType ftype)
liblas::ContinuousValueFilter<double>::filter_func f = &liblas::Point::GetTime;
liblas::ContinuousValueFilter<double>* time_filter = new liblas::ContinuousValueFilter<double>(f, times);
time_filter->SetType(ftype);
- return time_filter;
+ return liblas::FilterPtr(time_filter);
-liblas::FilterI* MakeScanAngleFilter(std::string intensities, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeScanAngleFilter(std::string intensities, liblas::FilterI::FilterType ftype)
liblas::ContinuousValueFilter<boost::int8_t>::filter_func f = &liblas::Point::GetScanAngleRank;
liblas::ContinuousValueFilter<boost::int8_t>* intensity_filter = new liblas::ContinuousValueFilter<boost::int8_t>(f, intensities);
-liblas::FilterI* MakeColorFilter(liblas::Color const& low, liblas::Color const& high, liblas::FilterI::FilterType ftype)
+liblas::FilterPtr MakeColorFilter(liblas::Color const& low, liblas::Color const& high, liblas::FilterI::FilterType ftype)
liblas::ColorFilter* filter = new liblas::ColorFilter(low, high);
- return filter;
+ return liblas::FilterPtr(filter);
po::options_description* GetFilteringOptions()
@@ -152,9 +152,9 @@
return transform_options;
-std::vector<liblas::FilterI*> GetFilters(po::variables_map vm, bool verbose)
+std::vector<liblas::FilterPtr> GetFilters(po::variables_map vm, bool verbose)
if (vm.count("keep-classes"))
@@ -162,7 +162,7 @@
if (verbose)
std::cout << "Keeping classes with the values: " << classes << std::endl;
- liblas::FilterI* class_filter = MakeClassFilter( classes,
+ liblas::FilterPtr class_filter = MakeClassFilter( classes,
liblas::FilterI::eInclusion);
filters.push_back(class_filter);
@@ -173,7 +173,7 @@
if (verbose)
std::cout << "Dropping classes with the values: " << classes << std::endl;
liblas::FilterI::eExclusion);
@@ -184,7 +184,7 @@
if (verbose)
std::cout << "Keeping returns with the values: " << returns << std::endl;
- liblas::FilterI* return_filter = MakeReturnFilter( returns,
+ liblas::FilterPtr return_filter = MakeReturnFilter( returns,
filters.push_back(return_filter);
@@ -195,7 +195,7 @@
if (verbose)
std::cout << "Dropping returns with the values: " << returns << std::endl;
@@ -205,7 +205,7 @@
std::string bounds = vm["extent"].as< string >();
if (verbose)
std::cout << "Clipping file to the extent : " << bounds << std::endl;
- liblas::FilterI* bounds_filter = MakeBoundsFilter(bounds, liblas::FilterI::eInclusion);
+ liblas::FilterPtr bounds_filter = MakeBoundsFilter(bounds, liblas::FilterI::eInclusion);
filters.push_back(bounds_filter);
@@ -221,12 +221,12 @@
std::string low = intensities.substr(0,dash);
std::string high = intensities.substr(dash+1, intensities.size());
- liblas::FilterI* lt_filter = MakeIntensityFilter(">="+low, liblas::FilterI::eInclusion);
+ liblas::FilterPtr lt_filter = MakeIntensityFilter(">="+low, liblas::FilterI::eInclusion);
filters.push_back(lt_filter);
- liblas::FilterI* gt_filter = MakeIntensityFilter("<="+high, liblas::FilterI::eInclusion);
+ liblas::FilterPtr gt_filter = MakeIntensityFilter("<="+high, liblas::FilterI::eInclusion);
filters.push_back(gt_filter);
} else {
- liblas::FilterI* intensity_filter = MakeIntensityFilter(intensities, liblas::FilterI::eInclusion);
+ liblas::FilterPtr intensity_filter = MakeIntensityFilter(intensities, liblas::FilterI::eInclusion);
filters.push_back(intensity_filter);
@@ -240,7 +240,7 @@
if (IsDualRangeFilter(intensities)) {
throw std::runtime_error("Range filters are not supported for drop-intensity");
} else {
- liblas::FilterI* intensity_filter = MakeIntensityFilter(intensities, liblas::FilterI::eExclusion);
+ liblas::FilterPtr intensity_filter = MakeIntensityFilter(intensities, liblas::FilterI::eExclusion);
@@ -256,12 +256,12 @@
std::string low = angles.substr(0,dash);
std::string high = angles.substr(dash+1, angles.size());
- liblas::FilterI* lt_filter = MakeScanAngleFilter(">="+low, liblas::FilterI::eInclusion);
+ liblas::FilterPtr lt_filter = MakeScanAngleFilter(">="+low, liblas::FilterI::eInclusion);
- liblas::FilterI* gt_filter = MakeScanAngleFilter("<="+high, liblas::FilterI::eInclusion);
+ liblas::FilterPtr gt_filter = MakeScanAngleFilter("<="+high, liblas::FilterI::eInclusion);
} else {
- liblas::FilterI* angle_filter = MakeScanAngleFilter(angles, liblas::FilterI::eInclusion);
+ liblas::FilterPtr angle_filter = MakeScanAngleFilter(angles, liblas::FilterI::eInclusion);
filters.push_back(angle_filter);
@@ -275,7 +275,7 @@
if (IsDualRangeFilter(angles)) {
throw std::runtime_error("Range filters are not supported for drop-scan-angle");
} else {
- liblas::FilterI* angle_filter = MakeScanAngleFilter(angles, liblas::FilterI::eExclusion);
+ liblas::FilterPtr angle_filter = MakeScanAngleFilter(angles, liblas::FilterI::eExclusion);
@@ -292,12 +292,12 @@
std::string low = times.substr(0,dash);
std::string high = times.substr(dash+1, times.size());
- liblas::FilterI* lt_filter = MakeTimeFilter(">="+low, liblas::FilterI::eInclusion);
+ liblas::FilterPtr lt_filter = MakeTimeFilter(">="+low, liblas::FilterI::eInclusion);
- liblas::FilterI* gt_filter = MakeTimeFilter("<="+high, liblas::FilterI::eInclusion);
+ liblas::FilterPtr gt_filter = MakeTimeFilter("<="+high, liblas::FilterI::eInclusion);
} else {
- liblas::FilterI* time_filter = MakeTimeFilter(times, liblas::FilterI::eInclusion);
+ liblas::FilterPtr time_filter = MakeTimeFilter(times, liblas::FilterI::eInclusion);
filters.push_back(time_filter);
@@ -311,7 +311,7 @@
if (IsDualRangeFilter(times)) {
throw std::runtime_error("Range filters are not supported for drop-time");
} else {
- liblas::FilterI* time_filter = MakeTimeFilter(times, liblas::FilterI::eExclusion);
+ liblas::FilterPtr time_filter = MakeTimeFilter(times, liblas::FilterI::eExclusion);
@@ -339,7 +339,7 @@
colors.push_back(color);
- liblas::FilterI* color_filter = MakeColorFilter(colors[0], colors[1], liblas::FilterI::eInclusion);
+ liblas::FilterPtr color_filter = MakeColorFilter(colors[0], colors[1], liblas::FilterI::eInclusion);
filters.push_back(color_filter);
if (vm.count("drop-color"))
@@ -365,7 +365,7 @@
- liblas::FilterI* color_filter = MakeColorFilter(colors[0], colors[1], liblas::FilterI::eExclusion);
More information about the Liblas-commits
