[Liblas-commits] hg: use boost::uint64_t for SetClass's bitset too
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Sep 2 16:04:31 EDT 2010
changeset 6322659c82fe in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6322659c82fe
summary: use boost::uint64_t for SetClass's bitset too
diffstat:
 src/lasclassification.cpp |  2 +-
 1 files changed, 1 insertions(+), 1 deletions(-)
diffs (12 lines):
diff -r 4de090fb3f3e -r 6322659c82fe src/lasclassification.cpp
--- a/src/lasclassification.cpp	Thu Sep 02 14:39:31 2010 -0500
+++ b/src/lasclassification.cpp	Thu Sep 02 15:04:25 2010 -0500
@@ -120,7 +120,7 @@
     check_class_index(index);
-    bitset_type binval(static_cast<unsigned long>(index));
+    bitset_type binval(static_cast<boost::uint64_t>(index));
     binval <<= 0;
     // Store value in bits 0,1,2,3,4
More information about the Liblas-commits mailing list
