[Liblas-commits] hg: we can round-trip schema XML to/from VLRs now
liblas-commits at liblas.org
Thu Sep 2 21:41:28 EDT 2010
changeset d3c46c92ab81 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d3c46c92ab81
summary: we can round-trip schema XML to/from VLRs now
diffstat:
include/liblas/lasschema.hpp | 35 ++++--
src/detail/reader/header.cpp | 19 +++
src/lasschema.cpp | 232 ++++++++++++++++++++++++++++++------------
3 files changed, 210 insertions(+), 76 deletions(-)
diffs (truncated from 617 to 300 lines):
diff -r 6322659c82fe -r d3c46c92ab81 include/liblas/lasschema.hpp
--- a/include/liblas/lasschema.hpp Thu Sep 02 15:04:25 2010 -0500
+++ b/include/liblas/lasschema.hpp Thu Sep 02 20:41:15 2010 -0500
@@ -49,6 +49,7 @@
#include <boost/cstdint.hpp>
#include <boost/any.hpp>
#include <boost/shared_ptr.hpp>
+#include <boost/foreach.hpp>
// std
#include <iosfwd>
@@ -58,8 +59,8 @@
namespace liblas {
-class DimensionI;
-typedef boost::shared_ptr<DimensionI> DimensionPtr;
+class Dimension;
+typedef boost::shared_ptr<Dimension> DimensionPtr;
class Schema
@@ -88,8 +89,8 @@
bool HasColor() const;
bool HasTime() const;
- void AddDimension(boost::shared_ptr<DimensionI> dim);
- boost::shared_ptr<DimensionI> GetDimension(std::string const& name) const;
+ void AddDimension(boost::shared_ptr<Dimension> dim);
+ boost::shared_ptr<Dimension> GetDimension(std::string const& name) const;
void RemoveDimension(DimensionPtr dim);
std::vector<std::string> GetDimensionNames() const;
@@ -97,13 +98,13 @@
liblas::property_tree::ptree GetPTree() const;
bool IsCustom() const;
- VariableRecord const& GetVLR() const;
+ VariableRecord GetVLR() const;
protected:
boost::uint16_t m_size;
PointFormatName m_data_format_id;
+ boost::uint32_t m_nextpos;
private:
std::vector<DimensionPtr> m_dimensions;
@@ -113,13 +114,16 @@
void add_color();
void update_required_dimensions(PointFormatName data_format_id);
bool IsSchemaVLR(VariableRecord const& vlr);
+ liblas::property_tree::ptree LoadPTree(VariableRecord const& v);
+ std::vector<DimensionPtr> LoadDimensions(liblas::property_tree::ptree tree);
-class DimensionI
+class Dimension
public:
- DimensionI(std::string const& name, boost::uint32_t size_in_bits) :
+ Dimension(std::string const& name, boost::uint32_t size_in_bits) :
m_name(name),
m_bitsize(size_in_bits),
m_required(false),
@@ -129,10 +133,11 @@
m_max(0),
m_numeric(false),
m_signed(false),
- m_integer(false)
+ m_integer(false),
+ m_position(0)
- virtual ~DimensionI() {};
+ virtual ~Dimension() {};
std::string const& GetName() { return m_name; }
@@ -184,7 +189,14 @@
/// The maximum value of this dimension as a double
double GetMaximum() { return m_max; }
void SetMaximum(double max) { m_max = max; }
+ boost::uint32_t GetPosition() const { return m_position; }
+ void SetPosition(boost::uint32_t v) { m_position = v; }
+ bool operator < (Dimension const& dim) const
+ return m_position < dim.m_position;
private:
std::string m_name;
@@ -197,6 +209,7 @@
bool m_numeric;
bool m_signed;
bool m_integer;
+ boost::uint32_t m_position;
diff -r 6322659c82fe -r d3c46c92ab81 src/detail/reader/header.cpp
--- a/src/detail/reader/header.cpp Thu Sep 02 15:04:25 2010 -0500
+++ b/src/detail/reader/header.cpp Thu Sep 02 20:41:15 2010 -0500
@@ -408,6 +408,25 @@
liblas::SpatialReference srs(m_header->GetVLRs());
m_header->SetSRS(srs);
+ // Go fetch the schema from the VLRs if we've got one.
+ try {
+ liblas::Schema schema(m_header->GetVLRs());
+ m_header->SetSchema(schema);
+ } catch (std::runtime_error const& e)
+ // Create one from the PointFormat if we don't have
+ // one in the VLRs. Create a custom dimension on the schema
+ // That comprises the rest of the bytes after the end of the
+ // required dimensions.
+ liblas::Schema schema(m_header->GetDataFormatId());
+ // FIXME: handle custom bytes here.
+ boost::ignore_unused_variable_warning(e);
diff -r 6322659c82fe -r d3c46c92ab81 src/lasschema.cpp
--- a/src/lasschema.cpp Thu Sep 02 15:04:25 2010 -0500
+++ b/src/lasschema.cpp Thu Sep 02 20:41:15 2010 -0500
@@ -55,7 +55,8 @@
Schema::Schema(PointFormatName data_format_id):
m_size(0),
- m_data_format_id(data_format_id)
+ m_data_format_id(data_format_id),
+ m_nextpos(0)
update_required_dimensions(data_format_id);
@@ -64,48 +65,51 @@
std::ostringstream text;
- DimensionPtr x = DimensionPtr(new DimensionI("X", 32));
+ DimensionPtr x = DimensionPtr(new Dimension("X", 32));
text << "x coordinate as a long integer. You must use the scale and "
<< "offset information of the header to determine the double value.";
x->SetDescription(text.str());
x->IsInteger(true);
x->IsNumeric(true);
x->IsSigned(true);
+ x->SetPosition(m_nextpos); m_nextpos++;
AddDimension(x);
text.str("");
- DimensionPtr y = DimensionPtr(new DimensionI("Y", 32));
+ DimensionPtr y = DimensionPtr(new Dimension("Y", 32));
text << "y coordinate as a long integer. You must use the scale and "
y->SetDescription(text.str());
y->IsInteger(true);
y->IsNumeric(true);
y->IsSigned(true);
+ y->SetPosition(m_nextpos); m_nextpos++;
AddDimension(y);
text.str("");
- DimensionPtr z = DimensionPtr(new DimensionI("Z", 32));
+ DimensionPtr z = DimensionPtr(new Dimension("Z", 32));
text << "z coordinate as a long integer. You must use the scale and "
z->SetDescription(text.str());
z->IsInteger(true);
z->IsNumeric(true);
z->IsSigned(true);
+ z->SetPosition(m_nextpos); m_nextpos++;
AddDimension(z);
text.str("");
- DimensionPtr intensity = DimensionPtr(new DimensionI("Intensity", 16));
- text << "The intensity value is the integer representation of the pulse"
+ DimensionPtr intensity = DimensionPtr(new Dimension("Intensity", 16));
+ text << "The intensity value is the integer representation of the pulse "
"return magnitude. This value is optional and system specific. "
"However, it should always be included if available.";
intensity->SetDescription(text.str());
intensity->IsInteger(true);
intensity->IsNumeric(true);
+ intensity->SetPosition(m_nextpos); m_nextpos++;
AddDimension(intensity);
text.str("");
- DimensionPtr return_no = DimensionPtr(new DimensionI("Return Number", 3));
+ DimensionPtr return_no = DimensionPtr(new Dimension("Return Number", 3));
text << "Return Number: The Return Number is the pulse return number for "
"a given output pulse. A given output laser pulse can have many "
"returns, and they must be marked in sequence of return. The first "
@@ -114,10 +118,11 @@
return_no->SetDescription(text.str());
return_no->IsNumeric(true);
return_no->IsInteger(true);
+ return_no->SetPosition(m_nextpos); m_nextpos++;
AddDimension(return_no);
text.str("");
- DimensionPtr no_returns = DimensionPtr(new DimensionI("Number of Returns", 3));
+ DimensionPtr no_returns = DimensionPtr(new Dimension("Number of Returns", 3));
text << "Number of Returns (for this emitted pulse): The Number of Returns "
"is the total number of returns for a given pulse. For example, "
"a laser data point may be return two (Return Number) within a "
@@ -125,10 +130,11 @@
no_returns->SetDescription(text.str());
no_returns->IsNumeric(true);
no_returns->IsInteger(true);
+ no_returns->SetPosition(m_nextpos); m_nextpos++;
AddDimension(no_returns);
text.str("");
- DimensionPtr scan_dir = DimensionPtr(new DimensionI("Scan Direction", 1));
+ DimensionPtr scan_dir = DimensionPtr(new Dimension("Scan Direction", 1));
text << "The Scan Direction Flag denotes the direction at which the "
"scanner mirror was traveling at the time of the output pulse. "
"A bit value of 1 is a positive scan direction, and a bit value "
@@ -138,20 +144,22 @@
scan_dir->SetDescription(text.str());
scan_dir->IsNumeric(true);
scan_dir->IsInteger(true);
+ scan_dir->SetPosition(m_nextpos); m_nextpos++;
AddDimension(scan_dir);
text.str("");
- DimensionPtr edge = DimensionPtr(new DimensionI("Flightline Edge", 1));
+ DimensionPtr edge = DimensionPtr(new Dimension("Flightline Edge", 1));
text << "The Edge of Flight Line data bit has a value of 1 only when "
"the point is at the end of a scan. It is the last point on "
"a given scan line before it changes direction.";
edge->SetDescription(text.str());
edge->IsNumeric(true);
edge->IsInteger(true);
+ edge->SetPosition(m_nextpos); m_nextpos++;
AddDimension(edge);
text.str("");
- DimensionPtr classification = DimensionPtr(new DimensionI("Classification", 8));
+ DimensionPtr classification = DimensionPtr(new Dimension("Classification", 8));
text << "Classification in LAS 1.0 was essentially user defined and optional. "
"LAS 1.1 defines a standard set of ASPRS classifications. In addition, "
"the field is now mandatory. If a point has never been classified, this "
@@ -161,11 +169,12 @@
"bit encoded field with the lower five bits used for class and the "
"three high bits used for flags.";
classification->SetDescription(text.str());
+ classification->SetPosition(m_nextpos); m_nextpos++;
AddDimension(classification);
text.str("");
- DimensionPtr scan_angle = DimensionPtr(new DimensionI("Scan Angle Rank", 8));
+ DimensionPtr scan_angle = DimensionPtr(new Dimension("Scan Angle Rank", 8));
text << "The Scan Angle Rank is a signed one-byte number with a "
"valid range from -90 to +90. The Scan Angle Rank is the "
"angle (rounded to the nearest integer in the absolute "
@@ -179,16 +188,18 @@
scan_angle->IsSigned(true);
scan_angle->IsInteger(true);
scan_angle->IsNumeric(true);
+ scan_angle->SetPosition(m_nextpos); m_nextpos++;
AddDimension(scan_angle);
text.str("");
- DimensionPtr user_data = DimensionPtr(new DimensionI("User Data", 8));
+ DimensionPtr user_data = DimensionPtr(new Dimension("User Data", 8));
text << "This field may be used at the userâs discretion";
user_data->SetDescription(text.str());
+ user_data->SetPosition(m_nextpos); m_nextpos++;
AddDimension(user_data);
text.str("");
- DimensionPtr point_source_id = DimensionPtr(new DimensionI("Point Source ID", 16));
+ DimensionPtr point_source_id = DimensionPtr(new Dimension("Point Source ID", 16));
text << "This value indicates the file from which this point originated. "
"Valid values for this field are 1 to 65,535 inclusive with zero "
"being used for a special case discussed below. The numerical value "
@@ -201,6 +212,7 @@
point_source_id->SetDescription(text.str());
point_source_id->IsInteger(true);
point_source_id->IsNumeric(true);
+ point_source_id->SetPosition(m_nextpos); m_nextpos++;
AddDimension(point_source_id);
text.str("");
More information about the Liblas-commits
