[Liblas-commits] hg: update to reflect current state
liblas-commits at liblas.org
Tue Apr 5 17:27:03 EDT 2011
details: http://hg.liblas.orghg/rev/8d795670b800
changeset: 2920:8d795670b800
user: Howard Butler <hobu.inc at gmail.com>
date: Tue Apr 05 16:26:24 2011 -0500
description:
Subject: hg: remove
details: http://hg.liblas.orghg/rev/78a99d13d177
changeset: 2921:78a99d13d177
date: Tue Apr 05 16:26:54 2011 -0500
description:
remove
diffstat:
schemas/LAS-example.xsd | 105 ------------
schemas/LAS.xsd | 74 +-------
schemas/las.xml | 141 ++++++++++++++--
schemas/prop_tree.xml | 410 ++++++++++++++++++++++++++++++++++++++++++++++++
4 files changed, 546 insertions(+), 184 deletions(-)
diffs (truncated from 816 to 300 lines):
diff -r bbad20eed7bf -r 78a99d13d177 schemas/LAS-example.xsd
--- a/schemas/LAS-example.xsd Tue Apr 05 11:39:13 2011 -0500
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,105 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
- xmlns:las="http://liblas.org/schemas/LAS/example"
- elementFormDefault="qualified"
- attributeFormDefault="unqualified"
- targetNamespace="http://liblas.org/schemas/LAS/example" version="1.0">
- <xs:simpleType name="sizeType">
- <xs:annotation><xs:documentation>
- The storage size type of the dimension.
- </xs:documentation></xs:annotation>
- <xs:restriction base="xs:string">
- <xs:enumeration value="byte"></xs:enumeration>
- <xs:enumeration value="bit"></xs:enumeration>
- </xs:restriction>
- </xs:simpleType>
- <xs:simpleType name="interpretationType" >
- Common interpretations of the data that may be used. This
- type may be extended under the expectation that clients
- know how to consume the data. In the case of string-like
- data, use uint8_t (common byte) as the interpretation
- and transform accordingly. Because nulls (or even
- multi-byte strings) might be allowed, there are
- no common string interpretations provided by defaut.
- <xs:enumeration value="int8_t"></xs:enumeration>
- <xs:enumeration value="uint8_t"></xs:enumeration>
- <xs:enumeration value="int16_t"></xs:enumeration>
- <xs:enumeration value="uint16_t"></xs:enumeration>
- <xs:enumeration value="int32_t"></xs:enumeration>
- <xs:enumeration value="uint32_t"></xs:enumeration>
- <xs:enumeration value="int64_t"></xs:enumeration>
- <xs:enumeration value="uint64_t"></xs:enumeration>
- <xs:enumeration value="double"></xs:enumeration>
- <xs:enumeration value="float"></xs:enumeration>
- <xs:enumeration value="unknown"></xs:enumeration>
- </xs:restriction>
- </xs:simpleType>
- <xs:complexType name="rangeType">
- <xs:attribute name="units" type="las:interpretationType"></xs:attribute>
- <xs:attribute name="value" type="xs:decimal"></xs:attribute>
- </xs:complexType>
- <xs:complexType name="dimensionType">
- <xs:sequence>
- <xs:element name="name" type="xs:string" />
- <xs:element name="description" type="xs:string" minOccurs="0"/>
- <xs:element name="position" type="xs:nonNegativeInteger" >
- The dimension's position in the block of point data (counting from 0)
- </xs:element>
- <xs:element name="active" type="xs:boolean">
- A dimension may have be holding its place in bytes but might not have actual
- values that mean anything. This flag can be used to skip the dimension in
- that case.
- </xs:element>
- <!--Specify the size and units of the dimension's storage-->
- <xs:element name="size" type="xs:nonNegativeInteger"></xs:element>
- <xs:element name="units" type="las:sizeType"></xs:element>
- <xs:element name="interpretation" type="las:interpretationType">
- This element describes how the data should be interpreted.
- In the case of conflicting data, for example when then size is 2, the units "byte",
- but the interpretation is "uint32_t", the size determines how much
- precision is available.
- </xs:element>
- <xs:element name="minimum" type="las:rangeType" minOccurs="0">
- The minimum value of this dimension.
- </xs:element>
- <xs:element name="maximum" type="las:rangeType">
- The maximum value of this dimension.
- </xs:element>
- </xs:sequence>
- </xs:complexType>
- <xs:element name="LASSchema" >
- <xs:complexType>
- <xs:sequence >
- <xs:element name="dimension" type="las:dimensionType" minOccurs="1" maxOccurs="unbounded"></xs:element>
- </xs:sequence>
- </xs:complexType>
- </xs:element>
-</xs:schema>
diff -r bbad20eed7bf -r 78a99d13d177 schemas/LAS.xsd
--- a/schemas/LAS.xsd Tue Apr 05 11:39:13 2011 -0500
+++ b/schemas/LAS.xsd Tue Apr 05 16:26:54 2011 -0500
@@ -1,18 +1,6 @@
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<xs:schema xmlns:las="http://liblas.org/schemas/LAS/1.0" xmlns:xs="http://www.w3.org/2001/XMLSchema" attributeFormDefault="unqualified" elementFormDefault="qualified" targetNamespace="http://liblas.org/schemas/LAS/1.0" version="1.0">
+<xs:schema xmlns:pc="http://libpc.org/schemas/PC/1.0" xmlns:xs="http://www.w3.org/2001/XMLSchema" attributeFormDefault="unqualified" elementFormDefault="qualified" targetNamespace="http://libpc.org/schemas/PC/1.0" version="1.0">
- <xs:annotation>
- <xs:documentation>
- </xs:annotation>
- <xs:enumeration value="byte"/>
- <xs:enumeration value="bit"/>
- </xs:restriction>
- </xs:simpleType>
<xs:simpleType name="interpretationType">
<xs:annotation>
<xs:documentation>
@@ -22,7 +10,7 @@
+ no common string interpretations provided by default.
</xs:documentation>
</xs:annotation>
@@ -41,7 +29,7 @@
</xs:simpleType>
- <xs:attribute name="units" type="las:interpretationType"/>
+ <xs:attribute name="units" type="pc:interpretationType"/>
<xs:attribute name="value" type="xs:decimal"/>
</xs:complexType>
@@ -59,19 +47,10 @@
<xs:annotation>
<xs:documentation>
- The size of this dimension (assumed to be in bytes if
- no units element is available).
+ The size of this dimension in bytes.
</xs:documentation>
</xs:annotation>
- </xs:element>
- <xs:element name="required" type="xs:boolean">
- <xs:annotation>
- Is this dimension required by the LAS Point Format?
- </xs:annotation>
- </xs:element>
+ </xs:element>
<xs:element minOccurs="0" name="name" type="xs:string"/>
<xs:element minOccurs="0" name="description" type="xs:string"/>
@@ -86,29 +65,20 @@
</xs:annotation>
</xs:element>
- <xs:element minOccurs="0" name="units" type="las:sizeType">
- <xs:annotation>
- The units to use for size measurements for this
- dimension. If no units element is specified, "bytes"
- is the assumed unit.
- </xs:annotation>
- </xs:element>
- <xs:element minOccurs="0" name="interpretation" type="las:interpretationType">
+ <xs:element minOccurs="0" name="interpretation" type="pc:interpretationType">
<xs:annotation>
<xs:documentation>
interpreted. In the case of conflicting data, for
- example when then size is 2, the units "byte", but the
+ example when then size is 2, but the
much precision is available.
</xs:documentation>
</xs:annotation>
</xs:element>
- <xs:element minOccurs="0" name="minimum" type="las:rangeType">
+ <xs:element minOccurs="0" name="minimum" type="pc:rangeType">
<xs:annotation>
<xs:documentation>
@@ -116,7 +86,7 @@
</xs:annotation>
</xs:element>
- <xs:element minOccurs="0" name="maximum" type="las:rangeType">
+ <xs:element minOccurs="0" name="maximum" type="pc:rangeType">
<xs:annotation>
<xs:documentation>
@@ -135,36 +105,18 @@
<xs:element minOccurs="0" name="scale" type="xs:double">
<xs:annotation>
<xs:documentation>
- The scale (usually a negative log10 exponent) of this
- dimension. Used to support scaled integer types
+ The scale of this dimension. Used to support scaled integer types
</xs:documentation>
</xs:annotation>
- </xs:element>
- <xs:element minOccurs="0" name="byteOffset" type="xs:nonNegativeInteger">
- <xs:annotation>
- The byte offset to start reading this dimension from
- the front of the point record.
- </xs:annotation>
- </xs:element>
- <xs:element minOccurs="0" name="bitOffset" type="xs:nonNegativeInteger">
- <xs:annotation>
- The bit offset to start reading this dimension from the
- calculated (or specified, using byteOffset) byte offset
- of the dimension.
- </xs:annotation>
- </xs:element>
+ </xs:element>
</xs:all>
</xs:complexType>
- <xs:element name="LASSchema">
+ <xs:element name="PointCloudSchema">
<xs:complexType>
<xs:sequence>
- <xs:element maxOccurs="unbounded" minOccurs="1" name="dimension" type="las:dimensionType"/>
+ <xs:element maxOccurs="unbounded" minOccurs="1" name="dimension" type="pc:dimensionType"/>
</xs:sequence>
</xs:complexType>
</xs:element>
diff -r bbad20eed7bf -r 78a99d13d177 schemas/las.xml
--- a/schemas/las.xml Tue Apr 05 11:39:13 2011 -0500
+++ b/schemas/las.xml Tue Apr 05 16:26:54 2011 -0500
@@ -1,19 +1,124 @@
-<las:LASSchema xmlns:las="http://liblas.org/schemas/LAS/1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://liblas.org/schemas/LAS/1.0 ">
- <las:dimension>
- <las:position>0</las:position>
- <las:size>0</las:size>
- <las:required>true</las:required>
- <las:name>las:name</las:name>
- <las:description>las:description</las:description>
- <las:active>true</las:active>
- <las:units>byte</las:units>
- <las:interpretation>int8_t</las:interpretation>
- <las:minimum units="int8_t" value="0.0"/>
- <las:maximum units="int8_t" value="0.0"/>
- <las:offset>0.0</las:offset>
- <las:scale>0.0</las:scale>
- <las:byteOffset>0</las:byteOffset>
- <las:bitOffset>0</las:bitOffset>
- </las:dimension>
-</las:LASSchema>
\ No newline at end of file
+<pc:PointCloudSchema xmlns:pc="http://libpc.org/schemas/PC/1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://libpc.org/schemas/PC/1.0 libPC.xsd ">
+ <pc:dimension>
+ <pc:position>1</pc:position>
+ <pc:size>4</pc:size>
+ <pc:name>X</pc:name>
+ <pc:description>x coordinate as a long integer. You must use the scale and offset information of the header to determine the double value</pc:description>
+ <pc:interpretation>int32_t</pc:interpretation>
+ <pc:minimum units="double" value="42.0"/>
+ <pc:maximum units="double" value="84.0"/>
+ <pc:offset>0.0</pc:offset>
+ <pc:scale>0.001</pc:scale>
+ </pc:dimension>
+ <pc:dimension>
+ <pc:position>2</pc:position>
+ <pc:name>Y</pc:name>
+ <pc:description>y coordinate as a long integer. You must use the scale and offset information of the header to determine the double value</pc:description>
+ <pc:minimum units="double" value="14.0"/>
+ <pc:maximum units="double" value="28.0"/>
More information about the Liblas-commits
