[Liblas-commits] hg-main-tree: add support for fetching OCIArray*
lengths
liblas-commits at liblas.org
Tue Apr 5 17:46:26 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/269e8098b0a9
changeset: 499:269e8098b0a9
user: Howard Butler <hobu.inc at gmail.com>
date: Tue Apr 05 16:46:20 2011 -0500
description:
add support for fetching OCIArray* lengths
diffstat:
apps/pc2pc.cpp | 2 +-
include/libpc/drivers/oci/oci_wrapper.h | 1 +
src/drivers/oci/Iterator.cpp | 3 +++
src/drivers/oci/oci_wrapper.cpp | 14 ++++++++++++++
4 files changed, 19 insertions(+), 1 deletions(-)
diffs (60 lines):
diff -r fbd1fc6c4e6e -r 269e8098b0a9 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Tue Apr 05 12:00:00 2011 -0500
+++ b/apps/pc2pc.cpp Tue Apr 05 16:46:20 2011 -0500
@@ -131,7 +131,7 @@
libpc::drivers::oci::Options options;
boost::property_tree::ptree& tree = options.GetPTree();
- boost::uint32_t capacity = 10000;
+ boost::uint32_t capacity = 12;
tree.put("capacity", capacity);
tree.put("connection", "lidar/lidar at 192.168.56.101/orcl");
// tree.put("connection", "lidar/lidar at oracle.hobu.biz/crrel");
diff -r fbd1fc6c4e6e -r 269e8098b0a9 include/libpc/drivers/oci/oci_wrapper.h
--- a/include/libpc/drivers/oci/oci_wrapper.h Tue Apr 05 12:00:00 2011 -0500
+++ b/include/libpc/drivers/oci/oci_wrapper.h Tue Apr 05 16:46:20 2011 -0500
@@ -455,6 +455,7 @@
void* pBuffer, int nSize, unsigned int* nAmountRead );
char* ReadCLob( OCILobLocator* phLocator );
unsigned long GetBlobLength(OCILobLocator* phLocator);
+ signed long GetArrayLength( OCIArray** ppoData);
void WriteCLob( OCILobLocator** pphLocator, char* pszData );
bool WriteBlob( OCILobLocator* phLocator,
void* pBuffer, int nSize );
diff -r fbd1fc6c4e6e -r 269e8098b0a9 src/drivers/oci/Iterator.cpp
--- a/src/drivers/oci/Iterator.cpp Tue Apr 05 12:00:00 2011 -0500
+++ b/src/drivers/oci/Iterator.cpp Tue Apr 05 16:46:20 2011 -0500
@@ -139,6 +139,9 @@
std::cout << "elem1, elem2, elem3 " << elem1 << " " << elem2 << " " << elem3 << std::endl;
+ std::cout << "elem_info size " << m_statement->GetArrayLength(&(m_block->blk_extent->sdo_elem_info)) << std::endl;
+ std::cout << "sdo_ordinates size " << m_statement->GetArrayLength(&(m_block->blk_extent->sdo_ordinates)) << std::endl;
std::cout.setf(std::ios_base::fixed, std::ios_base::floatfield);
std::cout.precision(6);
m_statement->GetElement(&(m_block->blk_extent->sdo_ordinates), 0, &x);
diff -r fbd1fc6c4e6e -r 269e8098b0a9 src/drivers/oci/oci_wrapper.cpp
--- a/src/drivers/oci/oci_wrapper.cpp Tue Apr 05 12:00:00 2011 -0500
+++ b/src/drivers/oci/oci_wrapper.cpp Tue Apr 05 16:46:20 2011 -0500
@@ -1516,6 +1516,20 @@
+signed long int OWStatement::GetArrayLength( OCIArray** ppoData)
+ sb4 length;
+ if( CheckError( OCICollSize(
+ poConnection->hEnv,
+ hError,
+ (OCIColl*) *ppoData,
+ (sb4*) &length), hError ) )
+ return 0;
+ return length;
int OWStatement::GetElement( OCIArray** ppoData, int nIndex, int* pnResult )
boolean exists;
More information about the Liblas-commits
