[Liblas-commits] hg-main-tree: add FreeGLUT library
    liblas-commits at liblas.org
    Tue Apr  5 18:10:20 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/fb0acbbc0e2a
changeset: 500:fb0acbbc0e2a
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Tue Apr 05 14:02:08 2011 -0700
description:
Subject: hg-main-tree: add pcview
details:   http://hg.libpc.orghg-main-tree/rev/3f32b2fe089d
changeset: 501:3f32b2fe089d
date:      Tue Apr 05 14:28:51 2011 -0700
description:
add pcview
Subject: hg-main-tree: add las reading
details:   http://hg.libpc.orghg-main-tree/rev/0632d96ddacc
changeset: 502:0632d96ddacc
date:      Tue Apr 05 15:09:55 2011 -0700
description:
add las reading
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/8f814eb3342f
changeset: 503:8f814eb3342f
date:      Tue Apr 05 15:10:07 2011 -0700
description:
merge
diffstat:
 CMakeLists.txt                          |      9 +
 apps/CMakeLists.txt                     |      7 +-
 apps/pc2pc.cpp                          |      2 +-
 apps/pcview/ArcBall.cpp                 |    252 +
 apps/pcview/ArcBall.hpp                 |     72 +
 apps/pcview/ArcBallMath.cpp             |    300 +
 apps/pcview/ArcBallMath.hpp             |    197 +
 apps/pcview/CMakeLists.txt              |     81 +
 apps/pcview/Commands.cpp                |     35 +
 apps/pcview/Commands.hpp                |     93 +
 apps/pcview/Controller.cpp              |    220 +
 apps/pcview/Controller.hpp              |    108 +
 apps/pcview/Engine.cpp                  |    536 +
 apps/pcview/Engine.hpp                  |     87 +
 apps/pcview/glext.h                     |  11049 ++++++++++++++++++++++++++++++
 apps/pcview/main.cpp                    |    189 +
 cmake/modules/FindFreeGLUT.cmake        |     37 +
 include/libpc/drivers/oci/oci_wrapper.h |      1 +
 mpg-config.bat                          |      8 +
 src/drivers/oci/Iterator.cpp            |      3 +
 src/drivers/oci/oci_wrapper.cpp         |     14 +
 21 files changed, 13298 insertions(+), 2 deletions(-)
diffs (truncated from 13440 to 300 lines):
diff -r fbd1fc6c4e6e -r 8f814eb3342f CMakeLists.txt
--- a/CMakeLists.txt	Tue Apr 05 12:00:00 2011 -0500
+++ b/CMakeLists.txt	Tue Apr 05 15:10:07 2011 -0700
@@ -362,6 +362,15 @@
     endif()
 endif()
+if(WITH_FREEGLUT)
+  find_package(FreeGLUT)
+  if(FREEGLUT_FOUND)
+    include_directories(${FREEGLUT_INCLUDE_DIR})
+    add_definitions(-DHAVE_FREEGLUT=1)
+    set(LIBPC_HAVE_FREEGLUT 1)
+    message(STATUS "Found FreeGLUT")
+  endif()
+endif()
 # installation path settings
diff -r fbd1fc6c4e6e -r 8f814eb3342f apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Tue Apr 05 12:00:00 2011 -0500
+++ b/apps/CMakeLists.txt	Tue Apr 05 15:10:07 2011 -0700
@@ -4,6 +4,11 @@
 # (based originally on the libLAS files copyright Mateusz Loskot)
+if(FREEGLUT_FOUND)
+  subdirs(pcview)
+ endif()
 # includes
@@ -21,7 +26,7 @@
 set(LIBPC_UTILITIES
-    ${PCINFO} ${PC2PC})
+    ${PCINFO} ${PC2PC} ${PCVIEW})
diff -r fbd1fc6c4e6e -r 8f814eb3342f apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Tue Apr 05 12:00:00 2011 -0500
+++ b/apps/pc2pc.cpp	Tue Apr 05 15:10:07 2011 -0700
@@ -131,7 +131,7 @@
         libpc::drivers::oci::Options options;
         boost::property_tree::ptree& tree = options.GetPTree();
-        boost::uint32_t capacity = 10000;
+        boost::uint32_t capacity = 12;
         tree.put("capacity", capacity);
         tree.put("connection", "lidar/lidar at 192.168.56.101/orcl");
         // tree.put("connection", "lidar/lidar at oracle.hobu.biz/crrel");
diff -r fbd1fc6c4e6e -r 8f814eb3342f apps/pcview/ArcBall.cpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/apps/pcview/ArcBall.cpp	Tue Apr 05 15:10:07 2011 -0700
@@ -0,0 +1,252 @@
+// This code is derived from the well-known, much-copied Arcball class:
+//      (C) 1999-2003 Tatewake.com
+// This code is provided under the license terms from the http://nehe.gamedev.net/
+// tutorials/basecode series, which (depending on where you look) is either CC-SA or
+// the following:
+//     If you plan to put this program on your web page or a cdrom of
+//     any sort, let me know via email, I'm curious to see where
+//     it ends up :)
+//     If you use the code for your own projects please give me credit,
+//     or mention my web site somewhere in your program or it's docs.
+// http://nehe.gamedev.net/data/lessons/lesson.asp?lesson=48
+#include <libpc/libpc.hpp>
+#ifdef LIBPC_COMPILER_MSVC
+#include <windows.h>
+#endif
+#include <gl/gl.h>
+#include <gl/glu.h>
+#include <cmath>
+#include <cassert>
+#include "ArcBall.hpp"
+// ArcBallControl
+ArcBall::ArcBall(GLfloat NewWidth, GLfloat NewHeight)
+    //Clear initial values
+    this->StVec.s.X     =
+    this->StVec.s.Y     =
+    this->StVec.s.Z     =
+    this->EnVec.s.X     =
+    this->EnVec.s.Y     =
+    this->EnVec.s.Z     = 0.0f;
+    //Set initial bounds
+    this->setBounds(NewWidth, NewHeight);
+void ArcBall::setBounds(GLfloat NewWidth, GLfloat NewHeight)
+    assert((NewWidth > 1.0f) && (NewHeight > 1.0f));
+    //Set adjustment factor for width/height
+    this->AdjustWidth  = 1.0f / ((NewWidth  - 1.0f) * 0.5f);
+    this->AdjustHeight = 1.0f / ((NewHeight - 1.0f) * 0.5f);
+//Arcball sphere constants:
+//Diameter is       2.0f
+//Radius is         1.0f
+//Radius squared is 1.0f
+void ArcBall::_mapToSphere(const Point2fT* NewPt, Vector3fT* NewVec) const
+    Point2fT TempPt;
+    GLfloat length;
+    //Copy paramter into temp point
+    TempPt = *NewPt;
+    //Adjust point coords and scale down to range of [-1 ... 1]
+    TempPt.s.X  =        (TempPt.s.X * this->AdjustWidth)  - 1.0f;
+    TempPt.s.Y  = 1.0f - (TempPt.s.Y * this->AdjustHeight);
+    //Compute the square of the length of the vector to the point from the center
+    length      = (TempPt.s.X * TempPt.s.X) + (TempPt.s.Y * TempPt.s.Y);
+    //If the point is mapped outside of the sphere... (length > radius squared)
+    if (length > 1.0f)
+        GLfloat norm;
+        //Compute a normalizing factor (radius / sqrt(length))
+        norm    = 1.0f / sqrtf(length);
+        //Return the "normalized" vector, a point on the sphere
+        NewVec->s.X = TempPt.s.X * norm;
+        NewVec->s.Y = TempPt.s.Y * norm;
+        NewVec->s.Z = 0.0f;
+    else    //Else it's on the inside
+        //Return a vector to a point mapped inside the sphere sqrt(radius squared - length)
+        NewVec->s.X = TempPt.s.X;
+        NewVec->s.Y = TempPt.s.Y;
+        NewVec->s.Z = sqrtf(1.0f - length);
+void ArcBall::click(const Point2fT* NewPt)
+    //Map the point to the sphere
+    this->_mapToSphere(NewPt, &this->StVec);
+void ArcBall::drag(const Point2fT* NewPt, Quat4fT* NewRot)
+    this->_mapToSphere(NewPt, &this->EnVec);
+    //Return the quaternion equivalent to the rotation
+    if (NewRot)
+        Vector3fT  Perp;
+        //Compute the vector perpendicular to the begin and end vectors
+        Vector3fCross(&Perp, &this->StVec, &this->EnVec);
+        //Compute the length of the perpendicular vector
+        if (Vector3fLength(&Perp) > Epsilon)    //if its non-zero
+            //We're ok, so return the perpendicular vector as the transform after all
+            NewRot->s.X = Perp.s.X;
+            NewRot->s.Y = Perp.s.Y;
+            NewRot->s.Z = Perp.s.Z;
+            //In the quaternion values, w is cosine (theta / 2), where theta is rotation angle
+            NewRot->s.W= Vector3fDot(&this->StVec, &this->EnVec);
+        else                                    //if its zero
+            //The begin and end vectors coincide, so return an identity transform
+            NewRot->s.X =
+            NewRot->s.Y =
+            NewRot->s.Z =
+            NewRot->s.W = 0.0f;
+// ArcBallControl
+ArcBallControl::ArcBallControl(int width, int height)
+    : ArcBall((GLfloat)width, (GLfloat)height)
+    , m_isClicked(false)
+    , m_isDragging(false)
+    reset();
+    return;
+ArcBallControl::~ArcBallControl()
+    return;
+void ArcBallControl::reset()
+    ArcBall::Matrix3fSetIdentity(&m_lastRot);
+    ArcBall::Matrix3fSetIdentity(&m_thisRot);
+    ArcBall::Matrix4fSetIdentity(&m_transform);
+    ArcBall::Matrix4fSetRotationFromMatrix3f(&m_transform, &m_thisRot);
+// returns true if an update is needed
+bool ArcBallControl::update(int x, int y)
+    if (!m_isDragging)
+        return false;
+    if (!m_isClicked)
+        m_isDragging = false;
+        return false;
+    // still clicked, still dragging
+    m_mousePt.s.X = (GLfloat)x;
+    m_mousePt.s.Y = (GLfloat)y;
+    dragAction();
+    return true;
+void ArcBallControl::dragAction()
+    ArcBall::Quat4fT thisQuat;
+    this->drag(&m_mousePt, &thisQuat);					// Update End Vector And Get Rotation As Quaternion
+    ArcBall::Matrix3fSetRotationFromQuat4f(&m_thisRot, &thisQuat);			// Convert Quaternion Into Matrix3fT
+    ArcBall::Matrix3fMulMatrix3f(&m_thisRot, &m_lastRot);				// Accumulate Last Rotation Into This One
+    ArcBall::Matrix4fSetRotationFromMatrix3f(&m_transform, &m_thisRot);			// Set Our Final Transform's Rotation From This One
+    return;
+bool ArcBallControl::changeState(bool isClicked, int mx, int my)
+    m_isClicked = isClicked;
+    m_mousePt.s.X = (GLfloat)mx;
+    m_mousePt.s.Y = (GLfloat)my;
+        if (!m_isClicked)
+            return false;
+        // first click
+        m_isDragging = true;							// Prepare For Dragging
+        m_lastRot = m_thisRot;							// Set Last Static Rotation To Last Dynamic One
+        this->click(&m_mousePt);						// Update Start Vector And Prepare For Dragging
+        return false;
+    // we are dragging
+    if (!m_isClicked)
+        // no longer dragging
+        return false;
More information about the Liblas-commits
