[Liblas-commits] hg-main-tree: a good stopping point
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Apr 6 23:16:16 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/82cabe497436
changeset: 504:82cabe497436
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Apr 06 21:19:59 2011 -0500
description:
diffstat:
 include/libpc/drivers/oci/Common.hpp   |    7 +-
 include/libpc/drivers/oci/Iterator.hpp |    4 +-
 src/drivers/oci/Iterator.cpp           |  133 +++++++++++++++++++++++++-------
 src/drivers/oci/common.cpp             |   18 ++++
 4 files changed, 129 insertions(+), 33 deletions(-)
diffs (278 lines):
diff -r 8f814eb3342f -r 82cabe497436 include/libpc/drivers/oci/Common.hpp
--- a/include/libpc/drivers/oci/Common.hpp	Tue Apr 05 15:10:07 2011 -0700
+++ b/include/libpc/drivers/oci/Common.hpp	Wed Apr 06 21:19:59 2011 -0500
@@ -40,6 +40,8 @@
 #include "oci_wrapper.h"
 #include <boost/shared_ptr.hpp>
+#include <boost/scoped_ptr.hpp>
 #include <boost/property_tree/ptree.hpp>
 #include <cpl_port.h>
@@ -77,7 +79,8 @@
 public:
-    Block() {};
+    Block(Connection connection);
+    ~Block() ;
     boost::int32_t           obj_id;
     boost::int32_t           blk_id;
@@ -89,6 +92,8 @@
     boost::int32_t           num_points;
     boost::int32_t           num_unsorted_points;
     boost::int32_t           pt_sort_dim;
+    boost::scoped_ptr<std::vector<uint8_t> > chunk;
+    Connection              m_connection;
 private:
diff -r 8f814eb3342f -r 82cabe497436 include/libpc/drivers/oci/Iterator.hpp
--- a/include/libpc/drivers/oci/Iterator.hpp	Tue Apr 05 15:10:07 2011 -0700
+++ b/include/libpc/drivers/oci/Iterator.hpp	Wed Apr 06 21:19:59 2011 -0500
@@ -57,6 +57,7 @@
     const Reader& getReader() const;
     boost::uint32_t readBuffer(PointBuffer& data);
+    boost::uint32_t unpackOracleData(PointBuffer& data);
     Statement m_statement;
     bool m_at_end;
@@ -66,8 +67,7 @@
     sdo_pc* m_pc;
     sdo_pc_blk* m_block_table_type;
-    std::vector<boost::uint8_t> m_points;
-    boost::uint32_t m_blob_read_byte_size;
+    std::vector<boost::uint8_t>::size_type m_points;
 private:
     const Reader& m_reader;
diff -r 8f814eb3342f -r 82cabe497436 src/drivers/oci/Iterator.cpp
--- a/src/drivers/oci/Iterator.cpp	Tue Apr 05 15:10:07 2011 -0700
+++ b/src/drivers/oci/Iterator.cpp	Wed Apr 06 21:19:59 2011 -0500
@@ -49,6 +49,7 @@
 IteratorBase::IteratorBase(const Reader& reader)
     : m_at_end(false)
+    , m_block(0)
     , m_reader(reader)
@@ -70,14 +71,8 @@
     else if (m_querytype == QUERY_BLK_TABLE)
         doBlockTableDefine();
-        reader.getConnection()->CreateType(&(m_block->blk_extent));
-        reader.getConnection()->CreateType(&(m_block->blk_extent->sdo_ordinates), reader.getConnection()->GetOrdinateType());
-        reader.getConnection()->CreateType(&(m_block->blk_extent->sdo_elem_info), reader.getConnection()->GetElemInfoType());
-    // setNumPoints(1000);
     return;
@@ -93,35 +88,98 @@
     return m_reader;
+boost::uint32_t IteratorBase::unpackOracleData(PointBuffer& data)
+    return 0;
 boost::uint32_t IteratorBase::readBuffer(PointBuffer& data)
-    boost::uint32_t numPoints = data.getCapacity();
+    boost::uint32_t requestedNumPoints = data.getCapacity();
+    boost::uint32_t numPointsRead = 0;
+    bool bDidRead = false;
-    bool bDidRead = m_statement->Fetch();
-    if (!bDidRead)
+    std::cout << " Existing block has " << m_block->num_points << " points" << std::endl;
+    if (!m_block->num_points)
-        m_at_end = true;
-        return 0;
+        // We still have a block of data from the last readBuffer call
+        // that was partially read.
+        std::cout << "reading because we have no points" << std::endl;
+        bDidRead = m_statement->Fetch();
+        if (!bDidRead)
+            m_at_end = true;
+            return 0;
+    } else
+        // Our read was already "done" last readBuffer call, but if we're done,
+        // we're done
+        if (m_at_end) return 0;
+        bDidRead = true;
+        std::cout << "we already had points in our cache, using those" << std::endl;
-    std::cout << "This block has " << m_block->num_points << " points" << std::endl;
-    boost::uint32_t nAmountRead;
+    while (bDidRead)
+        std::cout << "This block has " << m_block->num_points << " points" << std::endl;
+        numPointsRead = numPointsRead + m_block->num_points;
+        if (numPointsRead > requestedNumPoints)
+            // We're done.  We still have more data, but the
+            // user is going to have to request another buffer.
+            // We're not going to fill the buffer up to *exactly*
+            // the number of points the user requested.
+            // If the buffer's capacity isn't large enough to hold
+            // an oracle block, they're just not going to get anything
+            // back right now (FIXME)
+            break;
+        boost::uint32_t nAmountRead;
-    std::vector<boost::uint8_t> chunk;// = iterator.getChunk();
-    boost::uint32_t blob_length = m_statement->GetBlobLength(m_locator);
+        boost::uint32_t blob_length = m_statement->GetBlobLength(m_locator);
+        std::cout << "blob_length: " << blob_length << std::endl;
-    if (chunk.size() < blob_length)
-        chunk.resize(blob_length);
-    bool read_all_data = m_statement->ReadBlob( m_locator,
-                                     (void*)(&chunk[0]),
-                                     chunk.size(),
-                                     &nAmountRead);
-    if (!read_all_data) throw libpc_error("Did not read all blob data!");
-    std::cout << "nAmountRead: " << nAmountRead << std::endl;
+        if (m_block->chunk->size() < blob_length)
+            m_block->chunk->resize(blob_length);
+        // std::vector<boost::uint8_t> chunk;
+        // if (chunk.size() < blob_length)
+        //     chunk.resize(blob_length);
+        std::cout << " m_block->chunk->size() : " << m_block->chunk->size()<< std::endl;
+        bool read_all_data = m_statement->ReadBlob( m_locator,
+                                         (void*)(&(*m_block->chunk)[0]),
+                                         m_block->chunk->size(),
+                                         &nAmountRead);
+        if (!read_all_data) throw libpc_error("Did not read all blob data!");
+        std::cout << "nAmountRead: " << nAmountRead << " m_block->chunk->size() : " << m_block->chunk->size()<< std::endl;
+        if (!bDidRead)
+            m_at_end = true;
+            return numPointsRead;
     double x, y, z;
@@ -134,7 +192,17 @@
     gtype= m_statement->GetInteger(&(m_block->blk_extent->sdo_gtype));
     srid =m_statement->GetInteger(&(m_block->blk_extent->sdo_srid));
+    gtype = 2304;
     std::cout << "gtype: " << gtype << std::endl;
+    // See http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_objrelschema.htm#g1013735
+    boost::uint32_t dimension = gtype / 1000;
+    boost::uint32_t geom_type = gtype % 100;
+    boost::uint32_t referencing= ((gtype % 1000) / 100);
+    std::cout << "dimension: " << dimension << " geometry type: " << geom_type << " referencing " << referencing << std::endl;
     std::cout << "srid: " << srid << std::endl;
     std::cout << "elem1, elem2, elem3 " << elem1 << " " << elem2 << " " << elem3 << std::endl;
@@ -255,7 +323,7 @@
-    return numPoints;
@@ -269,8 +337,14 @@
     int   nPrecision = 0;
     signed short nScale = 0;
     char szTypeName[OWNAME];
+    if (!m_block)
+        m_block = new Block(m_reader.getConnection());
-    m_block = new Block;
+    m_block->num_points = 0;
     // block_columns[0] = "OBJ_ID";
     // block_columns[1] = "BLK_ID";
@@ -283,8 +357,7 @@
     // block_columns[8] = "PT_SORT_DIM";
     // block_columns[9] = "POINTS";
-    m_reader.getConnection()->CreateType(&(m_block->blk_extent));
-    m_reader.getConnection()->CreateType(&(m_block->blk_domain));
     while( m_statement->GetNextField(iCol, szFieldName, &hType, &nSize, &nPrecision, &nScale, szTypeName) )
diff -r 8f814eb3342f -r 82cabe497436 src/drivers/oci/common.cpp
--- a/src/drivers/oci/common.cpp	Tue Apr 05 15:10:07 2011 -0700
+++ b/src/drivers/oci/common.cpp	Wed Apr 06 21:19:59 2011 -0500
@@ -132,6 +132,24 @@
+Block::Block(Connection connection)
+    : num_points(0)
+    , chunk(new std::vector<boost::uint8_t>)
+    , m_connection(connection)
+    m_connection->CreateType(&blk_extent);
+    m_connection->CreateType(&blk_extent->sdo_ordinates, m_connection->GetOrdinateType());
+    m_connection->CreateType(&blk_extent->sdo_elem_info, m_connection->GetElemInfoType());
+    m_connection->CreateType(&blk_domain);
+Block::~Block()
+    m_connection->DestroyType(&blk_extent->sdo_ordinates);
+    m_connection->DestroyType(&blk_extent->sdo_elem_info);
+    m_connection->DestroyType(&blk_extent);
+    m_connection->DestroyType(&blk_domain);
 std::string to_upper(const std::string& input)
     std::string inp = std::string(input);
More information about the Liblas-commits mailing list
