[Liblas-commits] hg-main-tree: srs round-tripping passing
liblas-commits at liblas.org
Fri Apr 22 13:21:11 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/9c0730a8eb2e
changeset: 624:9c0730a8eb2e
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Apr 22 10:21:05 2011 -0700
description:
diffstat:
test/unit/SpatialReferenceTest.cpp | 25 ++++++++++++++++++-------
1 files changed, 18 insertions(+), 7 deletions(-)
diffs (76 lines):
diff -r 264d697702b6 -r 9c0730a8eb2e test/unit/SpatialReferenceTest.cpp
--- a/test/unit/SpatialReferenceTest.cpp Fri Apr 22 10:04:35 2011 -0700
+++ b/test/unit/SpatialReferenceTest.cpp Fri Apr 22 10:21:05 2011 -0700
@@ -35,12 +35,25 @@
#include <boost/test/unit_test.hpp>
#include <libpc/SpatialReference.hpp>
+#include <libpc/Utils.hpp>
using namespace libpc;
BOOST_AUTO_TEST_SUITE(SpatialReferenceTest)
+ BOOST_AUTO_TEST_CASE(test_env_vars)
+ const char* gdal_data = getenv("GDAL_DATA");
+ const char* proj_lib = getenv("PROJ_LIB");
+ BOOST_CHECK(Utils::fileExists(gdal_data));
+ BOOST_CHECK(Utils::fileExists(proj_lib));
+ return;
BOOST_AUTO_TEST_CASE(test_ctor)
SpatialReference srs;
@@ -55,7 +68,6 @@
// Test round-tripping proj.4 string
BOOST_AUTO_TEST_CASE(test_proj4_roundtrip)
-#if 0
SpatialReference ref;
const std::string proj4 = "+proj=utm +zone=15 +datum=WGS84 +units=m +no_defs ";
@@ -63,12 +75,11 @@
ref.setProj4(proj4);
const std::string ret = ref.getProj4();
- BOOST_CHECK(ret == proj4);
+ BOOST_CHECK(ret == proj4 || ret == proj4_ellps);
ref.setProj4(proj4_ellps);
const std::string ret2 = ref.getProj4();
BOOST_CHECK(ret2 == proj4_ellps);
-#endif
return;
@@ -77,20 +88,20 @@
// Test setting EPSG:4326 from User string
BOOST_AUTO_TEST_CASE(test_userstring_roundtrip)
-#if 0
const std::string code = "EPSG:4326";
const std::string proj4 = "+proj=longlat +datum=WGS84 +no_defs ";
+ const std::string proj4_ellps = "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ";
const std::string wkt = "GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\",\"4326\"]]";
+ const std::string wkt_vs2010_debug = "GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.01745329251994328,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\",\"4326\"]]";
ref.setFromUserInput(code);
const std::string ret_proj = ref.getProj4();
const std::string ret_wkt = ref.getWKT();
- BOOST_CHECK(ret_proj == proj4);
- BOOST_CHECK(ret_wkt == wkt);
-#endif
+ BOOST_CHECK(ret_proj == proj4 || ret_proj == proj4_ellps);
+ BOOST_CHECK(ret_wkt == wkt || ret_wkt == wkt_vs2010_debug);
return;
More information about the Liblas-commits
