[Liblas-commits] hg: add option to provide a schema document to the
pc_other_attr...
liblas-commits at liblas.org
Fri Apr 22 13:26:50 EDT 2011
details: http://hg.liblas.orghg/rev/55ba3cb6ba0e
changeset: 2928:55ba3cb6ba0e
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Apr 22 12:26:41 2011 -0500
description:
add option to provide a schema document to the pc_other_attrs column of the point cloud
diffstat:
apps/las2oci.cpp | 69 ++++++++++++++++++++++++++++++++++++++++++++-----------
1 files changed, 55 insertions(+), 14 deletions(-)
diffs (174 lines):
diff -r 5385bcbdfc4d -r 55ba3cb6ba0e apps/las2oci.cpp
--- a/apps/las2oci.cpp Thu Apr 21 14:26:48 2011 -0600
+++ b/apps/las2oci.cpp Fri Apr 22 12:26:41 2011 -0500
@@ -387,7 +387,8 @@
std::string const& header_blob_column,
std::vector<boost::uint8_t> const& header_data,
std::string const& boundary_column,
- std::string const& boundary_wkt)
+ std::string const& boundary_wkt,
+ std::string const& point_schema_override)
ostringstream oss;
@@ -405,7 +406,12 @@
ostringstream columns;
ostringstream values;
+ bool bHaveSchemaOverride;
+ if (point_schema_override.size() > 0)
+ bHaveSchemaOverride = true;
if (!aux_columns_u.empty() ) {
columns << cloudColumnName_u << "," << aux_columns_u;
@@ -414,8 +420,13 @@
columns << cloudColumnName_u;
values << "pc";
- int nPos = 2; // Bind column position
+ int nPCPos = 1;
+ int nSchemaPos = 1;
+ if (bHaveSchemaOverride)
+ nSchemaPos++; // PC ID is now bound second
+ int nPos = nSchemaPos+1; // Bind column position
if (!header_blob_column_u.empty()){
columns << "," << header_blob_column_u;
values <<", :" << nPos;
@@ -435,7 +446,7 @@
ostringstream s_gtype;
ostringstream s_eleminfo;
ostringstream s_geom;
+ ostringstream s_schema;
IsGeographic(connection, srid);
@@ -472,6 +483,13 @@
+ s_schema << "xmltype(:"<<nSchemaPos<<")";
+ } else
+ s_schema << "NULL";
// extent* e = GetExtent( *(query->bounds.get()), bUse3d );
liblas::Bounds<double> e = *(query->bounds.get());
@@ -497,22 +515,24 @@
oss << "declare\n"
-" pc_id NUMBER := :1;\n"
+" pc_id NUMBER := :"<<nPCPos<<";\n"
" pc sdo_pc;\n"
"begin\n"
" -- Initialize the Point Cloud object.\n"
" pc := sdo_pc_pkg.init( \n"
-" '"<< pcTableName_u<<"', -- Table that has the SDO_POINT_CLOUD column defined\n"
-" '"<< cloudColumnName_u<<"', -- Column name of the SDO_POINT_CLOUD object\n"
-" '"<<blkTableName_u<<"', -- Table to store blocks of the point cloud\n"
+" '"<< pcTableName_u <<"', -- Table that has the SDO_POINT_CLOUD column defined\n"
+" '"<< cloudColumnName_u <<"', -- Column name of the SDO_POINT_CLOUD object\n"
+" '"<< blkTableName_u <<"', -- Table to store blocks of the point cloud\n"
" 'blk_capacity="<<blk_capacity<<"', -- max # of points per block\n"
<< s_geom.str() <<
", -- Extent\n"
" 0.5, -- Tolerance for point cloud\n"
" "<<nDimension<<", -- Total number of dimensions\n"
-" null);\n"
-" :1 := pc.pc_id;\n"
+" NULL,"
+" NULL,"
+" "<< s_schema.str() <<");\n"
+" :"<<nPCPos<<" := pc.pc_id;\n"
" -- Insert the Point Cloud object into the \"base\" table.\n"
" insert into " << pcTableName_u << " ( ID, "<< columns.str() <<
@@ -526,6 +546,15 @@
long output = 0;
statement = connection->CreateStatement(oss.str().c_str());
statement->Bind(&pc_id);
+ OCILobLocator* schema_locator ;
+ OCILobLocator* boundary_locator ;
+ char* schema = (char*) malloc(point_schema_override.size() * sizeof(char));
+ strncpy(schema, point_schema_override.c_str(), point_schema_override.size());
+ statement->WriteCLob( &schema_locator, schema );
+ statement->Bind(&schema_locator);
if (bInsertHeaderBlob) {
OCILobLocator** locator =(OCILobLocator**) VSIMalloc( sizeof(OCILobLocator*) * 1 );
statement->Define( locator, 1 );
@@ -538,9 +567,8 @@
char* wkt = (char*) malloc(boundary_wkt.size() * sizeof(char));
strncpy(wkt, boundary_wkt.c_str(), boundary_wkt.size());
if (!boundary_column_u.empty()){
- OCILobLocator* locator ;
- statement->WriteCLob( &locator, wkt );
- statement->Bind(&locator);
+ statement->WriteCLob( &boundary_locator, wkt );
+ statement->Bind(&boundary_locator);
statement->Bind(&srid);
@@ -626,6 +654,7 @@
("block-table-name", po::value< string >(), "The table name in which to put the block data. This table must be of type SDO_PC.BLK_TABLE. This table will be created using the filename of the input LAS file if not specified. Use -d to delete the table if it already exists.")
("block-table-partition-column", po::value< string >(), "The column name in which to put the partition id for the block as specified in --block-table-partition-value")
("block-table-partition-value", po::value< boost::int32_t >(), "The value for the partition id for the block to be placed in the column specified by --block-table-partition-column")
+ ("point-schema-override", po::value< string >(), "A schema document to set for the pc_other_attrs column")
("overwrite,d", po::value<bool>()->zero_tokens(), "Drop block table before inserting data.")
("block-capacity", po::value<boost::uint32_t>()->default_value(3000), "Maximum number of points to be inserted into each block")
("precision,p", po::value<boost::uint32_t>()->default_value(8), "Number of decimal points to write into SQL for point coordinate data. Used in user_sdo_geom_metadata entry and defining the PC_EXTENT for the point cloud object.")
@@ -639,6 +668,7 @@
("cached", po::value<bool>()->zero_tokens(), "Cache the entire file on the first read")
return file_options;
@@ -683,6 +713,7 @@
std::string aux_columns("");
std::string aux_values("");
+ std::string point_schema_override("");
bool bUseExistingBlockTable = false;
bool bDropTable = false;
@@ -966,6 +997,15 @@
std::cout << "Setting output pre-block-sql to: " << sql << std::endl; // Tell filename instead
+ if (vm.count("point-schema-override"))
+ std::string point_schema_file = vm["point-schema-override"].as< string >();
+ point_schema_override = ReadSQLData(point_schema_file);
+ if (verbose)
+ std::cout << "Setting output point-schema-override to: " << point_schema_file << std::endl;
if (vm.count("solid"))
bUseSolidGeometry = vm["solid"].as< bool >();
@@ -1229,7 +1269,8 @@
header_blob_column,
header_data,
base_table_boundary_column,
- base_table_boundary_wkt);
+ base_table_boundary_wkt,
+ point_schema_override);
if (!pre_block_sql.empty()) {
More information about the Liblas-commits
