[Liblas-commits] hg-main-tree: oracle-read is now a
pipeline-enabled activity -- ...
liblas-commits at liblas.org
Thu Aug 4 16:30:07 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/1aec184e9220
changeset: 1009:1aec184e9220
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Aug 04 15:28:25 2011 -0500
description:
oracle-read is now a pipeline-enabled activity -- use pcpipeline
Subject: hg-main-tree: enable drivers.oci.reader to use the new options stuff. nice work mpg. basic pcpipeline works with oracle reader
details: http://hg.libpc.orghg-main-tree/rev/653acabaa3e5
changeset: 1010:653acabaa3e5
date: Thu Aug 04 15:30:00 2011 -0500
description:
diffstat:
apps/pc2pc.cpp | 177 ++++++++++++++++++-----------------
include/pdal/drivers/oci/Reader.hpp | 7 +-
src/drivers/oci/Reader.cpp | 78 +++++++++------
3 files changed, 137 insertions(+), 125 deletions(-)
diffs (truncated from 370 to 300 lines):
diff -r 33d6b15f9dd9 -r 653acabaa3e5 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Thu Aug 04 14:01:23 2011 -0500
+++ b/apps/pc2pc.cpp Thu Aug 04 15:30:00 2011 -0500
@@ -102,7 +102,6 @@
("output,o", po::value<std::string>(&m_outputFile), "output file name")
("native", "use native LAS classes (not liblas)")
("oracle-writer", "Read data from LAS file and write to Oracle")
- ("oracle-reader", "Read data from Oracle and write to LAS")
("a_srs", po::value<std::string>(&m_srs)->default_value(""), "Assign output coordinate system")
("compress", po::value<bool>(&m_bCompress)->zero_tokens()->implicit_value(true),"Compress output data if available")
("xml", po::value<std::string>(&m_xml)->default_value("log.xml"), "XML file to load process (OCI only right now)")
@@ -205,92 +204,96 @@
throw configuration_error("PDAL not compiled with Oracle support");
#endif
- else if (hasOption("oracle-reader"))
- #ifdef PDAL_HAVE_ORACLE
- try{
- boost::property_tree::ptree load_tree;
- boost::property_tree::read_xml(m_xml, load_tree);
- boost::property_tree::ptree oracle_options = load_tree.get_child("pdal.drivers.oci.reader");
- boost::property_tree::ptree las_options = load_tree.get_child("pdal.drivers.las");
- boost::property_tree::ptree srs_options = las_options.get_child("spatialreference");
- double scalex = las_options.get<double>("scale.x");
- double scaley = las_options.get<double>("scale.y");
- double scalez = las_options.get<double>("scale.z");
- double offsetx = las_options.get<double>("offset.x");
- double offsety = las_options.get<double>("offset.y");
- double offsetz = las_options.get<double>("offset.z");
- bool compress = las_options.get<bool>("compress");
- std::string out_wkt = srs_options.get<std::string>("userinput");
- pdal::OptionsOld options(oracle_options);
- pdal::drivers::oci::Reader reader(options);
- pdal::drivers::las::LasWriter* writer;
- pdal::SpatialReference out_ref(out_wkt);
- pdal::SpatialReference in_ref(reader.getSpatialReference());
- if (!(in_ref == out_ref))
- // pdal::filters::ByteSwapFilter swapper(reader);
- pdal::filters::ScalingFilter scalingFilter(reader);
- pdal::filters::ReprojectionFilter reprojectionFilter(scalingFilter, in_ref, out_ref);
- pdal::filters::DescalingFilter descalingFilter(reprojectionFilter,
- scalex, offsetx,
- scaley, offsety,
- scalez, offsetz);
- writer = new pdal::drivers::las::LasWriter(descalingFilter, ofs);
- if (compress)
- writer->setCompressed(true);
- writer->setChunkSize(oracle_options.get<boost::uint32_t>("capacity"));
- writer->setPointFormat(pdal::drivers::las::PointFormat3);
- writer->initialize();
- writer->write(0);
- delete writer;
- else
- writer = new pdal::drivers::las::LasWriter(reader, ofs);
- if (compress)
- writer->write(0);
- delete writer;
- } catch (pdal::pdal_error& e)
- std::cerr << "Error reading oracle: " << e.what() << std::endl;
- return 1;
- #else
- throw configuration_error("PDAL not compiled with Oracle support");
- #endif
+ // else if (hasOption("oracle-reader"))
+ // #ifdef PDAL_HAVE_ORACLE
+ // try{
+ // boost::property_tree::ptree load_tree;
+ // boost::property_tree::read_xml(m_xml, load_tree);
+ // boost::property_tree::ptree oracle_options = load_tree.get_child("pdal.drivers.oci.reader");
+ // boost::property_tree::ptree las_options = load_tree.get_child("pdal.drivers.las");
+ // boost::property_tree::ptree srs_options = las_options.get_child("spatialreference");
+ // double scalex = las_options.get<double>("scale.x");
+ // double scaley = las_options.get<double>("scale.y");
+ // double scalez = las_options.get<double>("scale.z");
+ // double offsetx = las_options.get<double>("offset.x");
+ // double offsety = las_options.get<double>("offset.y");
+ // double offsetz = las_options.get<double>("offset.z");
+ // bool compress = las_options.get<bool>("compress");
+ // std::string out_wkt = srs_options.get<std::string>("userinput");
+ // pdal::OptionsOld options(oracle_options);
+ // pdal::drivers::oci::Reader reader_srs(options);
+ // reader_srs.initialize();
+ // pdal::drivers::oci::Reader reader(options);
+ // pdal::drivers::las::LasWriter* writer;
+ // pdal::SpatialReference out_ref(out_wkt);
+ // pdal::SpatialReference in_ref(reader_srs.getSpatialReference());
+ // if (!(in_ref == out_ref))
+ // // pdal::filters::ByteSwapFilter swapper(reader);
+ // pdal::filters::ScalingFilter scalingFilter(reader);
+ // pdal::filters::ReprojectionFilter reprojectionFilter(scalingFilter, in_ref, out_ref);
+ // pdal::filters::DescalingFilter descalingFilter(reprojectionFilter,
+ // scalex, offsetx,
+ // scaley, offsety,
+ // scalez, offsetz);
+ // writer = new pdal::drivers::las::LasWriter(descalingFilter, ofs);
+ // if (compress)
+ // writer->setCompressed(true);
+ // writer->setChunkSize(oracle_options.get<boost::uint32_t>("capacity"));
+ // writer->setPointFormat(pdal::drivers::las::PointFormat3);
+ // writer->initialize();
+ // writer->write(0);
+ // delete writer;
+ // else
+ // writer = new pdal::drivers::las::LasWriter(reader, ofs);
+ // if (compress)
+ // delete writer;
+ // } catch (pdal::pdal_error& e)
+ // std::cerr << "Error reading oracle: " << e.what() << std::endl;
+ // return 1;
+ // #else
+ // throw configuration_error("PDAL not compiled with Oracle support");
+ // #endif
diff -r 33d6b15f9dd9 -r 653acabaa3e5 include/pdal/drivers/oci/Reader.hpp
--- a/include/pdal/drivers/oci/Reader.hpp Thu Aug 04 14:01:23 2011 -0500
+++ b/include/pdal/drivers/oci/Reader.hpp Thu Aug 04 15:30:00 2011 -0500
@@ -55,7 +55,6 @@
public:
Reader(const Options&);
- Reader(OptionsOld& options);
~Reader();
virtual void initialize();
@@ -71,11 +70,8 @@
Connection getConnection () const { return m_connection;}
Statement getStatement () const { return m_statement;}
- OptionsOld& getOptionsOld() const { return m_optionsOld; }
CloudPtr getCloud() const;
std::string getQuery() const;
- bool isVerbose() const;
- bool isDebug() const;
private:
@@ -89,8 +85,8 @@
QueryType describeQueryType() const;
BlockPtr defineBlock() const;
Schema fetchSchema(sdo_pc* pc);
+ Connection Connect();
- OptionsOld& m_optionsOld;
Connection m_connection;
Statement m_statement;
QueryType m_querytype;
@@ -98,6 +94,7 @@
Schema m_schema;
sdo_pc* m_pc;
sdo_pc_blk* m_pc_block;
+ boost::uint32_t m_capacity;
diff -r 33d6b15f9dd9 -r 653acabaa3e5 src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp Thu Aug 04 14:01:23 2011 -0500
+++ b/src/drivers/oci/Reader.cpp Thu Aug 04 15:30:00 2011 -0500
@@ -38,6 +38,11 @@
#include <pdal/exceptions.hpp>
#include <pdal/FileUtils.hpp>
+#include <boost/shared_ptr.hpp>
+#include <boost/scoped_ptr.hpp>
+#include <boost/tokenizer.hpp>
+#include <boost/make_shared.hpp>
#include <iostream>
#include <map>
@@ -47,24 +52,54 @@
IMPLEMENT_STATICS(Reader, "drivers.oci.reader", "OCI Reader")
-static OptionsOld dummy;
Reader::Reader(const Options& options)
: pdal::Reader(options)
- , m_optionsOld(dummy)
+ , m_querytype(QUERY_UNKNOWN)
+ , m_capacity(0)
- throw not_yet_implemented("options ctor");
+pdal::drivers::oci::Connection Reader::Connect()
+ std::string connection = getOptions().getValueOrThrow<std::string>("connection");
-Reader::Reader(OptionsOld& optionsOld)
- : pdal::Reader(Options::none())
- , m_optionsOld(optionsOld)
- , m_querytype(QUERY_UNKNOWN)
+ if (connection.empty())
+ throw pdal_error("Oracle connection string empty! Unable to connect");
+ std::string::size_type slash_pos = connection.find("/",0);
+ std::string username = connection.substr(0,slash_pos);
+ std::string::size_type at_pos = connection.find("@",slash_pos);
+ std::string password = connection.substr(slash_pos+1, at_pos-slash_pos-1);
+ std::string instance = connection.substr(at_pos+1);
+ Connection con = boost::make_shared<OWConnection>(username.c_str(),password.c_str(),instance.c_str());
+ if (con->Succeeded())
+ if (isVerbose())
+ std::cout << "Oracle connection succeeded" << std::endl;
+ else
+ throw connection_failed("Oracle connection failed");
+ return con;
More information about the Liblas-commits
