[Liblas-commits] hg-main-tree: add compression Option for
drivers.las.writer, but...
liblas-commits at liblas.org
Thu Aug 4 17:21:03 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/7a056e7bc4e5
changeset: 1011:7a056e7bc4e5
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Aug 04 16:21:00 2011 -0500
description:
add compression Option for drivers.las.writer, but it doesn't seem to work yet for some reason :(
diffstat:
include/pdal/drivers/las/Writer.hpp | 1 -
src/drivers/las/Writer.cpp | 25 ++++++++++++++++++++-----
2 files changed, 20 insertions(+), 6 deletions(-)
diffs (80 lines):
diff -r 653acabaa3e5 -r 7a056e7bc4e5 include/pdal/drivers/las/Writer.hpp
--- a/include/pdal/drivers/las/Writer.hpp Thu Aug 04 15:30:00 2011 -0500
+++ b/include/pdal/drivers/las/Writer.hpp Thu Aug 04 16:21:00 2011 -0500
@@ -89,7 +89,6 @@
LasHeader m_lasHeader;
boost::uint32_t m_numPointsWritten;
- bool m_isCompressed;
SummaryData m_summaryData;
SpatialReference m_spatialReference;
diff -r 653acabaa3e5 -r 7a056e7bc4e5 src/drivers/las/Writer.cpp
--- a/src/drivers/las/Writer.cpp Thu Aug 04 15:30:00 2011 -0500
+++ b/src/drivers/las/Writer.cpp Thu Aug 04 16:21:00 2011 -0500
@@ -61,6 +61,7 @@
: pdal::Writer(prevStage, options)
, m_streamManager(options.getOption<std::string>("filename").getValue())
return;
@@ -69,7 +70,6 @@
: Writer(prevStage, Options::none())
, m_streamManager(ostream)
, m_numPointsWritten(0)
- , m_isCompressed(false)
return;
@@ -90,14 +90,29 @@
m_streamManager.open();
+ try
+ Option<bool> compression = getOptions().getOption<bool>("compression");
+ setCompressed(compression.getValue());
+ catch (pdal::option_not_found const&)
+ // if we didn't get a compression option, no compression for you!
return;
const Options& LasWriter::s_getDefaultOptions()
- static Option<std::string> option1("filename", "", "file to read from");
- static Options options(option1);
+ static Options options;
+ Option<std::string> filename("filename", "", "file to read from");
+ Option<bool> compression("compression", false, "Do we LASzip-compress the data?");
+ options.add(filename);
+ options.add(compression);
return options;
@@ -331,7 +346,7 @@
for (unsigned int i=0; i<m_zipPoint->m_lz_point_size; i++)
m_zipPoint->m_lz_point_data[i] = buf[i];
- //printf("%d %d\n", v[i], i);
+ // printf("%d %d\n", buf[i], i);
bool ok = m_zipper->write(m_zipPoint->m_lz_point);
assert(ok);
@@ -341,7 +356,7 @@
Utils::write_n(m_streamManager.ostream(), buf, Support::getPointDataSize(pointFormat));
#else
- Utils::write_n(m_ostream, buf, Support::getPointDataSize(pointFormat));
+ Utils::write_n(m_streamManager.ostream(), buf, Support::getPointDataSize(pointFormat));
#endif
++numValidPoints;
More information about the Liblas-commits
