[Liblas-commits] hg-main-tree: use proper comparator
liblas-commits at liblas.org
Thu Aug 11 16:29:52 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/79589109d6bf
changeset: 1038:79589109d6bf
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Aug 11 13:28:12 2011 -0700
description:
Subject: hg-main-tree: added comment about comparators
details: http://hg.libpc.orghg-main-tree/rev/d3e2cdb09606
changeset: 1039:d3e2cdb09606
date: Thu Aug 11 13:29:33 2011 -0700
description:
diffstat:
test/unit/FileUtilsTest.cpp | 10 +++++-----
test/unit/main.cpp | 8 ++++++--
2 files changed, 11 insertions(+), 7 deletions(-)
diffs (50 lines):
diff -r f31c9dca686c -r d3e2cdb09606 test/unit/FileUtilsTest.cpp
--- a/test/unit/FileUtilsTest.cpp Thu Aug 11 15:05:37 2011 -0500
+++ b/test/unit/FileUtilsTest.cpp Thu Aug 11 13:29:33 2011 -0700
@@ -106,23 +106,23 @@
// check 1-arg version: make absolute when file is relative, via current working dir
const string a = FileUtils::toAbsolutePath("foo.txt");
- BOOST_CHECK(a == root + "/" + "foo.txt");
+ BOOST_CHECK_EQUAL(a, root + "/" + "foo.txt");
// check 1-arg version: make absolute when file is already absolute
const string b = FileUtils::toAbsolutePath(drive + "/baz/foo.txt");
- BOOST_CHECK(b == "A:/baz/foo.txt");
+ BOOST_CHECK_EQUAL(b, "A:/baz/foo.txt");
// check 2-arg version: make absolute when file relative, via given base
const string c = FileUtils::toAbsolutePath("foo.txt", drive + "/a/b/c/d");
- BOOST_CHECK(c == drive + "/a/b/c/d/foo.txt");
+ BOOST_CHECK_EQUAL(c, drive + "/a/b/c/d/foo.txt");
// check 2-arg version: make absolute when file is relative, via given base (which isn't absolute)
const string d = FileUtils::toAbsolutePath("foo.txt", "x/y/z");
- BOOST_CHECK(d == root + "/" + "x/y/z/" + "foo.txt");
+ BOOST_CHECK_EQUAL(d, root + "/" + "x/y/z/" + "foo.txt");
const string e = FileUtils::toAbsolutePath(drive+"/baz/foo.txt", drive+"/a/b/c/d");
- BOOST_CHECK(e == drive+"/baz/foo.txt");
+ BOOST_CHECK_EQUAL(e, drive+"/baz/foo.txt");
return;
diff -r f31c9dca686c -r d3e2cdb09606 test/unit/main.cpp
--- a/test/unit/main.cpp Thu Aug 11 15:05:37 2011 -0500
+++ b/test/unit/main.cpp Thu Aug 11 13:29:33 2011 -0700
@@ -42,8 +42,12 @@
// Testing macros:
// BOOST_TEST_MESSAGE("...")
// BOOST_CHECK(bool)
-// for comparing to floating point values, use
+// BOOST_CHECK_EQUAL(t1, t2)
+// The 'CHECK_EQUAL function is preferred to plain 'CHECK, because the former
+// prints out the values of both arguments in the error message.
+// For comparing to floating point values, use
// BOOST_CHECK_CLOSE(a,b,perc)
// where perc is a percentage value in the range [0..100] (typically)
More information about the Liblas-commits
