[Liblas-commits] hg-main-tree: fix test for unix
liblas-commits at liblas.org
Thu Aug 11 16:31:30 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/a1fdabfec72d
changeset: 1040:a1fdabfec72d
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Aug 11 13:31:17 2011 -0700
description:
fix test for unix
diffstat:
test/unit/FileUtilsTest.cpp | 2 +-
1 files changed, 1 insertions(+), 1 deletions(-)
diffs (12 lines):
diff -r d3e2cdb09606 -r a1fdabfec72d test/unit/FileUtilsTest.cpp
--- a/test/unit/FileUtilsTest.cpp Thu Aug 11 13:29:33 2011 -0700
+++ b/test/unit/FileUtilsTest.cpp Thu Aug 11 13:31:17 2011 -0700
@@ -110,7 +110,7 @@
// check 1-arg version: make absolute when file is already absolute
const string b = FileUtils::toAbsolutePath(drive + "/baz/foo.txt");
- BOOST_CHECK_EQUAL(b, "A:/baz/foo.txt");
+ BOOST_CHECK_EQUAL(b, drive + "/baz/foo.txt");
// check 2-arg version: make absolute when file relative, via given base
const string c = FileUtils::toAbsolutePath("foo.txt", drive + "/a/b/c/d");
More information about the Liblas-commits
