[Liblas-commits] hg-main-tree: support setting header padding
liblas-commits at liblas.org
Fri Aug 12 13:20:05 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/ff52f4c5578e
changeset: 1062:ff52f4c5578e
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Aug 12 12:12:29 2011 -0500
description:
Subject: hg-main-tree: support setting header padding
details: http://hg.libpc.orghg-main-tree/rev/598bb618697e
changeset: 1063:598bb618697e
date: Fri Aug 12 12:12:57 2011 -0500
description:
Subject: hg-main-tree: convenience functions for determining byte current length and total byte length of the raw data buffer
details: http://hg.libpc.orghg-main-tree/rev/96e6a8dd163c
changeset: 1064:96e6a8dd163c
date: Fri Aug 12 12:13:55 2011 -0500
description:
Subject: hg-main-tree: keep existing padding on the header and don't alter it when writing the header to file
details: http://hg.libpc.orghg-main-tree/rev/3e457bd2cea2
changeset: 1065:3e457bd2cea2
date: Fri Aug 12 12:14:29 2011 -0500
description:
Subject: hg-main-tree: use setHeaderPadding methods
details: http://hg.libpc.orghg-main-tree/rev/5ee73f641295
changeset: 1066:5ee73f641295
date: Fri Aug 12 12:15:09 2011 -0500
description:
Subject: hg-main-tree: add compare_stage_data method for comparing data. Maybe we should add PointBuffer::operator==?
details: http://hg.libpc.orghg-main-tree/rev/75b3ad25e67f
changeset: 1067:75b3ad25e67f
date: Fri Aug 12 12:16:00 2011 -0500
description:
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/959cd863903f
changeset: 1068:959cd863903f
date: Fri Aug 12 12:19:56 2011 -0500
description:
merge
diffstat:
apps/Application.cpp | 8 +-
apps/Application.hpp | 2 +-
include/pdal/PointBuffer.hpp | 10 +
include/pdal/drivers/las/Writer.hpp | 2 +
include/pdal/drivers/liblas/Writer.hpp | 4 +-
src/PipelineReader.cpp | 6 +-
src/drivers/las/LasHeaderWriter.cpp | 11 +-
src/drivers/las/Writer.cpp | 4 +
src/drivers/liblas/Writer.cpp | 4 +
test/data/misc/data1.dat | 1 +
test/data/misc/data1.txt | 3 +
test/data/misc/data2.dat | 1 +
test/data/misc/data2.txt | 3 +
test/data/misc/data3.dat | 1 +
test/data/misc/data3.txt | 5 +
test/data/misc/data4a.dat | 1 +
test/data/misc/data4b.dat | 1 +
test/data/pipeline_readcomments.xml | 18 ++
test/data/pipeline_writecomments.xml | 26 +++
test/temp/README.txt | 1 +
test/unit/CMakeLists.txt | 4 +
test/unit/LasWriterTest.cpp | 19 +-
test/unit/LiblasWriterTest.cpp | 27 +-
test/unit/PipelineReaderTest.cpp | 9 +
test/unit/SpatialReferenceTest.cpp | 4 +-
test/unit/Support.cpp | 243 +++++++++++++++++++++++++++++---
test/unit/Support.hpp | 31 ++++-
test/unit/SupportTest.cpp | 228 ++++++++++++++++++++++++++++++
test/unit/pc2pcTest.cpp | 49 ++++++
test/unit/pcinfoTest.cpp | 49 ++++++
test/unit/pcpipelineTest.cpp | 49 ++++++
31 files changed, 765 insertions(+), 59 deletions(-)
diffs (truncated from 1297 to 300 lines):
diff -r b0027041eb7a -r 959cd863903f apps/Application.cpp
--- a/apps/Application.cpp Thu Aug 11 15:48:12 2011 -0500
+++ b/apps/Application.cpp Fri Aug 12 12:19:56 2011 -0500
@@ -145,7 +145,11 @@
boost::uint8_t Application::getVerboseLevel() const
- return m_verboseLevel;
+ // verboseLevel is really a u8 value, but we have to store it in a u32
+ // object because if we don't then program_options prints the default
+ // value as an unsigned char (thanks, lexical_cast!)
+ const boost::uint8_t v = static_cast<boost::uint8_t>(m_verboseLevel & 0x000000ff);
+ return v;
@@ -200,7 +204,7 @@
basic_options->add_options()
("help,h", "produce help message")
("debug,d", po::value<bool>(&m_isDebug)->zero_tokens(), "Enable debug mode")
- ("verbose,v", po::value<boost::uint8_t>(&m_verboseLevel)->default_value(0), "Set verbose message level (default is 0)")
+ ("verbose,v", po::value<boost::uint32_t>(&m_verboseLevel)->default_value(0), "Set verbose message level")
("version", "Show version info")
("timer", "Show execution time")
diff -r b0027041eb7a -r 959cd863903f apps/Application.hpp
--- a/apps/Application.hpp Thu Aug 11 15:48:12 2011 -0500
+++ b/apps/Application.hpp Fri Aug 12 12:19:56 2011 -0500
@@ -89,7 +89,7 @@
void addBasicOptionSet();
bool m_isDebug;
- boost::uint8_t m_verboseLevel;
+ boost::uint32_t m_verboseLevel;
const int m_argc;
char** m_argv;
const std::string m_appName;
diff -r b0027041eb7a -r 959cd863903f include/pdal/PointBuffer.hpp
--- a/include/pdal/PointBuffer.hpp Thu Aug 11 15:48:12 2011 -0500
+++ b/include/pdal/PointBuffer.hpp Fri Aug 12 12:19:56 2011 -0500
@@ -148,6 +148,16 @@
return;
+ inline boost::uint64_t getBufferByteLength() const
+ return m_pointSize*m_numPoints;
+ inline boost::uint64_t getBufferByteCapacity() const
+ return m_pointSize*m_capacity;
// access to the raw memory
inline boost::uint8_t* getData(std::size_t pointIndex) const
diff -r b0027041eb7a -r 959cd863903f include/pdal/drivers/las/Writer.hpp
--- a/include/pdal/drivers/las/Writer.hpp Thu Aug 11 15:48:12 2011 -0500
+++ b/include/pdal/drivers/las/Writer.hpp Fri Aug 12 12:19:56 2011 -0500
@@ -73,6 +73,8 @@
// up to 32 chars (default is "PDAL x.y.z")
void setGeneratingSoftware(const std::string& softwareId);
+ void setHeaderPadding(boost::uint32_t const& v);
// default false
void setCompressed(bool);
diff -r b0027041eb7a -r 959cd863903f include/pdal/drivers/liblas/Writer.hpp
--- a/include/pdal/drivers/liblas/Writer.hpp Thu Aug 11 15:48:12 2011 -0500
+++ b/include/pdal/drivers/liblas/Writer.hpp Fri Aug 12 12:19:56 2011 -0500
@@ -76,7 +76,9 @@
// default false
protected:
virtual void writeBegin(boost::uint64_t targetNumPointsToWrite);
virtual boost::uint32_t writeBuffer(const PointBuffer&);
diff -r b0027041eb7a -r 959cd863903f src/PipelineReader.cpp
--- a/src/PipelineReader.cpp Thu Aug 11 15:48:12 2011 -0500
+++ b/src/PipelineReader.cpp Fri Aug 12 12:19:56 2011 -0500
@@ -449,7 +449,8 @@
m_inputXmlFile = filename;
boost::property_tree::ptree tree;
- boost::property_tree::xml_parser::read_xml(filename, tree);
+ boost::property_tree::xml_parser::read_xml(filename, tree,
+ boost::property_tree::xml_parser::no_comments);
boost::optional<boost::property_tree::ptree> opt( tree.get_child_optional("WriterPipeline") );
if (!opt.is_initialized())
@@ -472,7 +473,8 @@
boost::optional<boost::property_tree::ptree> opt( tree.get_child_optional("ReaderPipeline") );
diff -r b0027041eb7a -r 959cd863903f src/drivers/las/LasHeaderWriter.cpp
--- a/src/drivers/las/LasHeaderWriter.cpp Thu Aug 11 15:48:12 2011 -0500
+++ b/src/drivers/las/LasHeaderWriter.cpp Fri Aug 12 12:19:56 2011 -0500
@@ -109,6 +109,7 @@
+ boost::uint32_t padding_before_calculations = m_header.GetHeaderPadding();
int32_t existing_padding = m_header.GetDataOffset() -
(m_header.getVLRBlockSize() +
m_header.GetHeaderSize());
@@ -137,12 +138,14 @@
- m_header.SetDataOffset( m_header.GetHeaderSize() +
- m_header.getVLRBlockSize() +
- m_header.GetHeaderPadding());
+ m_header.SetDataOffset( m_header.GetHeaderSize() +
+ m_header.getVLRBlockSize() +
+ m_header.GetHeaderPadding() + padding_before_calculations);
// 1. File Signature
std::string const filesig(m_header.GetFileSignature());
diff -r b0027041eb7a -r 959cd863903f src/drivers/las/Writer.cpp
--- a/src/drivers/las/Writer.cpp Thu Aug 11 15:48:12 2011 -0500
+++ b/src/drivers/las/Writer.cpp Fri Aug 12 12:19:56 2011 -0500
@@ -168,6 +168,10 @@
m_spatialReference = srs;
+void LasWriter::setHeaderPadding(boost::uint32_t const& v)
+ m_lasHeader.SetHeaderPadding(v);
void LasWriter::writeBegin(boost::uint64_t targetNumPointsToWrite)
diff -r b0027041eb7a -r 959cd863903f src/drivers/liblas/Writer.cpp
--- a/src/drivers/liblas/Writer.cpp Thu Aug 11 15:48:12 2011 -0500
+++ b/src/drivers/liblas/Writer.cpp Fri Aug 12 12:19:56 2011 -0500
@@ -129,6 +129,10 @@
m_externalHeader->SetCompressed(v);
+void LiblasWriter::setHeaderPadding(boost::uint32_t const& v)
+ m_externalHeader->SetHeaderPadding(v);
void LiblasWriter::setFormatVersion(boost::uint8_t majorVersion, boost::uint8_t minorVersion)
diff -r b0027041eb7a -r 959cd863903f test/data/misc/data1.dat
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/test/data/misc/data1.dat Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,1 @@
+abcde
\ No newline at end of file
diff -r b0027041eb7a -r 959cd863903f test/data/misc/data1.txt
+++ b/test/data/misc/data1.txt Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,3 @@
+The quick brown fox
+jumped over
+the lazy dog.
diff -r b0027041eb7a -r 959cd863903f test/data/misc/data2.dat
+++ b/test/data/misc/data2.dat Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,1 @@
+abcdf
diff -r b0027041eb7a -r 959cd863903f test/data/misc/data2.txt
+++ b/test/data/misc/data2.txt Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,3 @@
+jumped o'er
+the lazy dog.
diff -r b0027041eb7a -r 959cd863903f test/data/misc/data3.dat
+++ b/test/data/misc/data3.dat Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,1 @@
+abc
diff -r b0027041eb7a -r 959cd863903f test/data/misc/data3.txt
+++ b/test/data/misc/data3.txt Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,5 @@
+jumped over
+the lazy dog.
+Oh, that
+lazy dog.
diff -r b0027041eb7a -r 959cd863903f test/data/misc/data4a.dat
+++ b/test/data/misc/data4a.dat Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,1 @@
+abcdefghijklmnopqrstuvwxyz
diff -r b0027041eb7a -r 959cd863903f test/data/misc/data4b.dat
+++ b/test/data/misc/data4b.dat Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,1 @@
+abcDEFGhijklmnopqrstuvw**z
diff -r b0027041eb7a -r 959cd863903f test/data/pipeline_readcomments.xml
+++ b/test/data/pipeline_readcomments.xml Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,18 @@
+<?xml version="1.0"?>
+<ReaderPipeline>
+ <Filter>
+ <Type>filters.crop</Type>
+ <Option>
+ <Name>bounds</Name>
+ <Value>([0,1000000],[0,1000000],[0,1000000])</Value>
+ </Option>
+ <Reader>
+ <Type>drivers.las.reader</Type>
+ <Option>
+ <Name>filename</Name>
+ <Value>1.2-with-color.las</Value>
+ </Option>
+ <!-- This is a comment -->
+ </Reader>
+ </Filter>
+</ReaderPipeline>
diff -r b0027041eb7a -r 959cd863903f test/data/pipeline_writecomments.xml
+++ b/test/data/pipeline_writecomments.xml Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,26 @@
+<?xml version="1.0" encoding="utf-8"?>
+<WriterPipeline>
+ <Writer>
+ <Type>drivers.las.writer</Type>
+ <Option>
+ <Value>out.las</Value>
+ <Description>junk junk junk</Description>
+ </Option>
+ <Filter>
+ <Option>
+ </Option>
+ <Reader>
+ <Option>
+ </Option>
+ </Reader>
+ </Filter>
+ </Writer>
+</WriterPipeline>
diff -r b0027041eb7a -r 959cd863903f test/temp/README.txt
+++ b/test/temp/README.txt Fri Aug 12 12:19:56 2011 -0500
@@ -0,0 +1,1 @@
+The unit tests write files into this directory. This directory must exist.
diff -r b0027041eb7a -r 959cd863903f test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt Thu Aug 11 15:48:12 2011 -0500
+++ b/test/unit/CMakeLists.txt Fri Aug 12 12:19:56 2011 -0500
@@ -12,6 +12,9 @@
endif()
SET(PDAL_UNITTEST_TEST_SRC
+ pc2pcTest.cpp
+ pcinfoTest.cpp
+ pcpipelineTest.cpp
BoundsTest.cpp
ByteSwapFilterTest.cpp
CacheFilterTest.cpp
@@ -47,6 +50,7 @@
StageFactoryTest.cpp
StreamManagerTest.cpp
+ SupportTest.cpp
TerraSolidTest.cpp
UtilsTest.cpp
VectorTest.cpp
diff -r b0027041eb7a -r 959cd863903f test/unit/LasWriterTest.cpp
--- a/test/unit/LasWriterTest.cpp Thu Aug 11 15:48:12 2011 -0500
+++ b/test/unit/LasWriterTest.cpp Fri Aug 12 12:19:56 2011 -0500
@@ -57,7 +57,7 @@
More information about the Liblas-commits
