[Liblas-commits] hg-main-tree: added binpath(); make sure paths end in trailing s...
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Aug 12 13:27:51 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/57ac04c35bd7
changeset: 1069:57ac04c35bd7
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Aug 12 10:22:14 2011 -0700
description:
added binpath(); make sure paths end in trailing slash
Subject: hg-main-tree: restore app-level catching
details:   http://hg.libpc.orghg-main-tree/rev/c6a70eb1a6a9
changeset: 1070:c6a70eb1a6a9
date:      Fri Aug 12 10:22:55 2011 -0700
description:
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/e14101254dc5
changeset: 1071:e14101254dc5
date:      Fri Aug 12 10:23:07 2011 -0700
description:
merge
diffstat:
 apps/Application.cpp                   |   28 ++++----
 include/pdal/FileUtils.hpp             |    4 +
 include/pdal/PointBuffer.hpp           |   10 +++
 include/pdal/drivers/las/Writer.hpp    |    2 +
 include/pdal/drivers/liblas/Writer.hpp |    4 +-
 src/FileUtils.cpp                      |   20 +++++-
 src/drivers/las/LasHeaderWriter.cpp    |   11 ++-
 src/drivers/las/Writer.cpp             |    4 +
 src/drivers/liblas/Writer.cpp          |    4 +
 test/unit/FileUtilsTest.cpp            |   12 +-
 test/unit/LasWriterTest.cpp            |    1 +
 test/unit/LiblasWriterTest.cpp         |    1 +
 test/unit/Support.cpp                  |  100 ++++++++++++++++++++++++++++++++-
 test/unit/Support.hpp                  |   27 ++++++++-
 test/unit/SupportTest.cpp              |   16 +++-
 test/unit/pcinfoTest.cpp               |    6 +-
 16 files changed, 212 insertions(+), 38 deletions(-)
diffs (truncated from 517 to 300 lines):
diff -r 812381915e9d -r e14101254dc5 apps/Application.cpp
--- a/apps/Application.cpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/apps/Application.cpp	Fri Aug 12 10:23:07 2011 -0700
@@ -91,21 +91,21 @@
     // call derived function
     int status = 0;
-    // try
+    try
         status = execute();
-    // catch (std::exception e)
-    //     const std::string s(e.what());
-    //     runtimeError("Caught exception: " + s);
-    //     status = 1;
-    // catch (...)
-    //     runtimeError("Caught unknown exception");
-    //     status = 1;
+    catch (std::exception e)
+        const std::string s(e.what());
+        runtimeError("Caught exception: " + s);
+        status = 1;
+    catch (...)
+        runtimeError("Caught unknown exception");
+        status = 1;
     if (status == 0 && hasOption("timer"))
diff -r 812381915e9d -r e14101254dc5 include/pdal/FileUtils.hpp
--- a/include/pdal/FileUtils.hpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/include/pdal/FileUtils.hpp	Fri Aug 12 10:23:07 2011 -0700
@@ -66,9 +66,11 @@
     static boost::uintmax_t fileSize(const std::string& filename);
     // return current working dir
+    // the result will always have a trailing '/'
     static std::string getcwd();
     // return the directory component of the given path, e.g. "d:/foo/bar/a.c" -> "d:/foo/bar"
     static std::string getDirectory(const std::string& path);
     // returns true iff the path is not relative
@@ -85,6 +87,8 @@
     static std::string toAbsolutePath(const std::string& filename, const std::string base);
 private:
+    static std::string addTrailingSlash(const std::string& path);
     FileUtils& operator=(const FileUtils&); // not implemented
     FileUtils(const FileUtils&); // not implemented;
diff -r 812381915e9d -r e14101254dc5 include/pdal/PointBuffer.hpp
--- a/include/pdal/PointBuffer.hpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/include/pdal/PointBuffer.hpp	Fri Aug 12 10:23:07 2011 -0700
@@ -148,6 +148,16 @@
         return;
+    inline boost::uint64_t getBufferByteLength() const
+        return m_pointSize*m_numPoints;
+    inline boost::uint64_t getBufferByteCapacity() const
+        return m_pointSize*m_capacity;
     // access to the raw memory
     inline boost::uint8_t* getData(std::size_t pointIndex) const
diff -r 812381915e9d -r e14101254dc5 include/pdal/drivers/las/Writer.hpp
--- a/include/pdal/drivers/las/Writer.hpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/include/pdal/drivers/las/Writer.hpp	Fri Aug 12 10:23:07 2011 -0700
@@ -73,6 +73,8 @@
     // up to 32 chars (default is "PDAL x.y.z")
     void setGeneratingSoftware(const std::string& softwareId);
+    void setHeaderPadding(boost::uint32_t const& v);
     // default false
     void setCompressed(bool);
diff -r 812381915e9d -r e14101254dc5 include/pdal/drivers/liblas/Writer.hpp
--- a/include/pdal/drivers/liblas/Writer.hpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/include/pdal/drivers/liblas/Writer.hpp	Fri Aug 12 10:23:07 2011 -0700
@@ -76,7 +76,9 @@
     // default false
 protected:
     virtual void writeBegin(boost::uint64_t targetNumPointsToWrite);
     virtual boost::uint32_t writeBuffer(const PointBuffer&);
diff -r 812381915e9d -r e14101254dc5 src/FileUtils.cpp
--- a/src/FileUtils.cpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/src/FileUtils.cpp	Fri Aug 12 10:23:07 2011 -0700
@@ -134,10 +134,23 @@
+std::string FileUtils::addTrailingSlash(const std::string& path)
+    std::string ret = path;
+    if (ret[ret.size() - 1] != '/')
+        ret += "/";
+    return ret;
 std::string FileUtils::getcwd()
     const boost::filesystem::path p = boost::filesystem::current_path();
-    return p.generic_string();
+    std::string path = p.generic_string();
+    path = addTrailingSlash(path);
+    return path;
@@ -165,8 +178,9 @@
 std::string FileUtils::getDirectory(const std::string& path)
     const boost::filesystem::path dir = boost::filesystem::path(path).parent_path();
-    const std::string str = dir.generic_string();
-    return str;
+    std::string ret = dir.generic_string();
+    ret = addTrailingSlash(ret);
+    return ret;
diff -r 812381915e9d -r e14101254dc5 src/drivers/las/LasHeaderWriter.cpp
--- a/src/drivers/las/LasHeaderWriter.cpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/src/drivers/las/LasHeaderWriter.cpp	Fri Aug 12 10:23:07 2011 -0700
@@ -109,6 +109,7 @@
+        boost::uint32_t padding_before_calculations = m_header.GetHeaderPadding();
         int32_t existing_padding = m_header.GetDataOffset() -
                                   (m_header.getVLRBlockSize() +
                                    m_header.GetHeaderSize());
@@ -137,12 +138,14 @@
-        m_header.SetDataOffset( m_header.GetHeaderSize() +
-                                m_header.getVLRBlockSize() +
-                                m_header.GetHeaderPadding());
+    m_header.SetDataOffset( m_header.GetHeaderSize() +
+                            m_header.getVLRBlockSize() +
+                            m_header.GetHeaderPadding() + padding_before_calculations);
         // 1. File Signature
     std::string const filesig(m_header.GetFileSignature());
diff -r 812381915e9d -r e14101254dc5 src/drivers/las/Writer.cpp
--- a/src/drivers/las/Writer.cpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/src/drivers/las/Writer.cpp	Fri Aug 12 10:23:07 2011 -0700
@@ -168,6 +168,10 @@
     m_spatialReference = srs;
+void LasWriter::setHeaderPadding(boost::uint32_t const& v)
+    m_lasHeader.SetHeaderPadding(v);
 void LasWriter::writeBegin(boost::uint64_t targetNumPointsToWrite)
diff -r 812381915e9d -r e14101254dc5 src/drivers/liblas/Writer.cpp
--- a/src/drivers/liblas/Writer.cpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/src/drivers/liblas/Writer.cpp	Fri Aug 12 10:23:07 2011 -0700
@@ -129,6 +129,10 @@
     m_externalHeader->SetCompressed(v);
+void LiblasWriter::setHeaderPadding(boost::uint32_t const& v)
+    m_externalHeader->SetHeaderPadding(v);
 void LiblasWriter::setFormatVersion(boost::uint8_t majorVersion, boost::uint8_t minorVersion)
diff -r 812381915e9d -r e14101254dc5 test/unit/FileUtilsTest.cpp
--- a/test/unit/FileUtilsTest.cpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/test/unit/FileUtilsTest.cpp	Fri Aug 12 10:23:07 2011 -0700
@@ -84,7 +84,7 @@
 #if 0
     // this is hardcoded for mpg's environment
     const std::string cwd = FileUtils::getcwd();
-    BOOST_CHECK(cwd == "D:/dev/pdal/test/unit");
+    BOOST_CHECK(cwd == "D:/dev/pdal/test/unit/");
 #endif
     return;
@@ -106,7 +106,7 @@
     // check 1-arg version: make absolute when file is relative, via current working dir
     const string a = FileUtils::toAbsolutePath("foo.txt");
-    BOOST_CHECK_EQUAL(a, root + "/" + "foo.txt");
+    BOOST_CHECK_EQUAL(a, root + "foo.txt");
     // check 1-arg version: make absolute when file is already absolute
     const string b = FileUtils::toAbsolutePath(drive + "/baz/foo.txt");
@@ -118,11 +118,11 @@
     // check 2-arg version: make absolute when file is relative, via given base (which isn't absolute)
     const string d = FileUtils::toAbsolutePath("foo.txt", "x/y/z");
-    BOOST_CHECK_EQUAL(d, root + "/" + "x/y/z/" + "foo.txt");
+    BOOST_CHECK_EQUAL(d, root + "x/y/z/" + "foo.txt");
     const string e = FileUtils::toAbsolutePath(drive+"/baz/foo.txt", drive+"/a/b/c/d");
-    BOOST_CHECK_EQUAL(e, drive+"/baz/foo.txt");
+    BOOST_CHECK_EQUAL(e, drive + "/baz/foo.txt");
     return;
@@ -132,11 +132,11 @@
     // test absolute case
     const std::string a = FileUtils::getDirectory(drive + "/a/b/foo.txt");
-    BOOST_CHECK_EQUAL(a, drive+"/a/b");
+    BOOST_CHECK_EQUAL(a, drive + "/a/b/");
     // test relative case
     const std::string b = FileUtils::getDirectory("a/b/foo.txt");
-    BOOST_CHECK_EQUAL(b, "a/b");
+    BOOST_CHECK_EQUAL(b, "a/b/");
     return;
diff -r 812381915e9d -r e14101254dc5 test/unit/LasWriterTest.cpp
--- a/test/unit/LasWriterTest.cpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/test/unit/LasWriterTest.cpp	Fri Aug 12 10:23:07 2011 -0700
@@ -109,6 +109,7 @@
         writer.setPointFormat(::pdal::drivers::las::PointFormat3);
         writer.setSystemIdentifier("");
         writer.setGeneratingSoftware("TerraScan");
+        writer.setHeaderPadding(2);
         writer.initialize();
diff -r 812381915e9d -r e14101254dc5 test/unit/LiblasWriterTest.cpp
--- a/test/unit/LiblasWriterTest.cpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/test/unit/LiblasWriterTest.cpp	Fri Aug 12 10:23:07 2011 -0700
@@ -150,6 +150,7 @@
         writer.write(numPoints);
diff -r 812381915e9d -r e14101254dc5 test/unit/Support.cpp
--- a/test/unit/Support.cpp	Fri Aug 12 09:41:58 2011 -0700
+++ b/test/unit/Support.cpp	Fri Aug 12 10:23:07 2011 -0700
@@ -43,24 +43,118 @@
 #include <pdal/Schema.hpp>
 #include <pdal/Dimension.hpp>
 #include <pdal/PointBuffer.hpp>
+#include <pdal/StageIterator.hpp>
+#include <pdal/Options.hpp>
+#include <pdal/PointBuffer.hpp>
+#include <pdal/Stage.hpp>
+#include <pdal/SchemaLayout.hpp>
+#include <pdal/exceptions.hpp>
 #include "TestConfig.hpp"
+std::string Support::datapath()
+    const std::string s = TestConfig::g_data_path;
+    return s;
More information about the Liblas-commits mailing list
