[Liblas-commits] hg-main-tree: popen debugging
liblas-commits at liblas.org
Mon Aug 15 13:23:21 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/f9edd098efe9
changeset: 1094:f9edd098efe9
user: mpg
date: Mon Aug 15 10:23:01 2011 -0700
description:
popen debugging
diffstat:
test/unit/Support.cpp | 77 ++++++++++++++++++++++++++++++--------------------
1 files changed, 46 insertions(+), 31 deletions(-)
diffs (103 lines):
diff -r 7c6a019c7576 -r f9edd098efe9 test/unit/Support.cpp
--- a/test/unit/Support.cpp Mon Aug 15 09:27:47 2011 -0700
+++ b/test/unit/Support.cpp Mon Aug 15 10:23:01 2011 -0700
@@ -438,53 +438,68 @@
#endif
-int Support::run_command(const std::string& rawcmd, std::string& output)
+static FILE* portable_popen(const std::string& command, const std::string& mode)
+ FILE* fp = 0;
+#ifdef PDAL_COMPILER_MSVC
+ const std::string dos_command = replaceAll(command, "/", "\\");
+ fp = _popen(dos_command.c_str(), "r");
+#else
+ fp = popen(command.c_str(), "r");
+#endif
+ return fp;
+static int portable_pclose(FILE* fp)
+ int status = 0;
+ status = _pclose(fp);
+#else
+ status = pclose(fp);
+ if (status == -1)
+ throw std::runtime_error("error executing command");
+ if (WIFEXITED(status) != 0)
+ status = WEXITSTATUS(status);
+ else
+ status = 0;
+ #endif
+ return status;
+int Support::run_command(const std::string& cmd, std::string& output)
const int maxbuf = 4096;
char buf[maxbuf];
- std::string cmd;
-#ifdef PDAL_COMPILER_MSVC
- cmd = replaceAll(rawcmd, "/", "\\");
-#else
- cmd = rawcmd;
-#endif
output = "";
- FILE* fp = 0;
- fp = _popen(cmd.c_str(), "r");
-#else
- fp = popen(cmd.c_str(), "r");
-#endif
+ FILE* fp = portable_popen(cmd.c_str(), "r");
while (!feof(fp))
if (fgets(buf, maxbuf, fp) == NULL)
if (feof(fp)) break;
- if (ferror(fp))
- #ifdef PDAL_COMPILER_MSVC
- _pclose(fp);
- #else
- pclose(fp);
- #endif
- throw std::runtime_error("error executing command");
+ if (ferror(fp)) break;
output += buf;
- int stat = _pclose(fp);
-#else
- int stat = pclose(fp);
-#endif
+ int stat = portable_pclose(fp);
return stat;
More information about the Liblas-commits
