[Liblas-commits] hg-main-tree: turn off failing popen tests on unix
liblas-commits at liblas.org
Mon Aug 15 15:03:29 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/357144aac7f8
changeset: 1095:357144aac7f8
user: mpg
date: Mon Aug 15 12:03:11 2011 -0700
description:
diffstat:
test/unit/Support.cpp | 14 +++++++++++---
test/unit/pc2pcTest.cpp | 2 ++
test/unit/pcinfoTest.cpp | 3 +++
test/unit/pcpipelineTest.cpp | 2 ++
4 files changed, 18 insertions(+), 3 deletions(-)
diffs (92 lines):
diff -r f9edd098efe9 -r 357144aac7f8 test/unit/Support.cpp
--- a/test/unit/Support.cpp Mon Aug 15 10:23:01 2011 -0700
+++ b/test/unit/Support.cpp Mon Aug 15 12:03:11 2011 -0700
@@ -444,9 +444,9 @@
#ifdef PDAL_COMPILER_MSVC
const std::string dos_command = replaceAll(command, "/", "\\");
- fp = _popen(dos_command.c_str(), "r");
+ fp = _popen(dos_command.c_str(), mode.c_str());
#else
- fp = popen(command.c_str(), "r");
+ fp = popen(command.c_str(), mode.c_str());
#endif
return fp;
@@ -473,12 +473,20 @@
status = 0;
- #endif
+#endif
return status;
+// BUG:
+// Under unix, the pclose() operation causes the boost unit test system
+// to produce a fatal error iff the process started by popen returns a
+// nonzero status code. For this reason, I've put all the "negative"
+// cmd line app tests under #ifdef PDAL_COMPILER_MSVC.
+// This problem shows up on mpg's Ubuntu 11.4 machine (gcc 4.5.2, boost 1.47.0)
+// as well as on Hobu's machine.
int Support::run_command(const std::string& cmd, std::string& output)
const int maxbuf = 4096;
diff -r f9edd098efe9 -r 357144aac7f8 test/unit/pc2pcTest.cpp
--- a/test/unit/pc2pcTest.cpp Mon Aug 15 10:23:01 2011 -0700
+++ b/test/unit/pc2pcTest.cpp Mon Aug 15 12:03:11 2011 -0700
@@ -52,6 +52,7 @@
+#ifdef PDAL_COMPILER_MSVC
BOOST_AUTO_TEST_CASE(pc2pcTest_test1)
const std::string cmd = appName();
@@ -65,5 +66,6 @@
return;
+#endif
BOOST_AUTO_TEST_SUITE_END()
diff -r f9edd098efe9 -r 357144aac7f8 test/unit/pcinfoTest.cpp
--- a/test/unit/pcinfoTest.cpp Mon Aug 15 10:23:01 2011 -0700
+++ b/test/unit/pcinfoTest.cpp Mon Aug 15 12:03:11 2011 -0700
@@ -52,6 +52,7 @@
BOOST_AUTO_TEST_CASE(pcinfoTest_1)
@@ -65,5 +66,7 @@
return;
+#endif
diff -r f9edd098efe9 -r 357144aac7f8 test/unit/pcpipelineTest.cpp
--- a/test/unit/pcpipelineTest.cpp Mon Aug 15 10:23:01 2011 -0700
+++ b/test/unit/pcpipelineTest.cpp Mon Aug 15 12:03:11 2011 -0700
@@ -52,6 +52,7 @@
BOOST_AUTO_TEST_CASE(pcpipelineTest_1)
@@ -65,5 +66,6 @@
return;
+#endif
More information about the Liblas-commits
