[Liblas-commits] hg-main-tree: added support class for the apps
liblas-commits at liblas.org
Mon Aug 15 17:02:56 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/74f565d6ec8f
changeset: 1099:74f565d6ec8f
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Aug 15 12:34:52 2011 -0700
description:
Subject: hg-main-tree: lint
details: http://hg.libpc.orghg-main-tree/rev/88a33994dd73
changeset: 1100:88a33994dd73
date: Mon Aug 15 12:57:12 2011 -0700
description:
lint
Subject: hg-main-tree: turn compare_no_case into a safer function
details: http://hg.libpc.orghg-main-tree/rev/32eec148a72e
changeset: 1101:32eec148a72e
date: Mon Aug 15 13:07:02 2011 -0700
description:
Subject: hg-main-tree: added copy ctor
details: http://hg.libpc.orghg-main-tree/rev/18de837c4805
changeset: 1102:18de837c4805
date: Mon Aug 15 13:22:06 2011 -0700
description:
added copy ctor
Subject: hg-main-tree: handle unknown options
details: http://hg.libpc.orghg-main-tree/rev/6401f2b79b79
changeset: 1103:6401f2b79b79
date: Mon Aug 15 13:50:31 2011 -0700
description:
Subject: hg-main-tree: start of for-real pcinfo app
details: http://hg.libpc.orghg-main-tree/rev/0dec1d001f3a
changeset: 1104:0dec1d001f3a
date: Mon Aug 15 14:02:39 2011 -0700
description:
diffstat:
apps/AppSupport.cpp | 92 ++++++++++++++++++++++++++++++++
apps/AppSupport.hpp | 67 +++++++++++++++++++++++
apps/Application.cpp | 14 +++-
apps/CMakeLists.txt | 7 +-
apps/pc2pc.cpp | 2 +
apps/pcinfo.cpp | 123 ++++++++++++++++++++++--------------------
apps/pcpipeline.cpp | 2 +
include/pdal/Options.hpp | 3 +
include/pdal/Utils.hpp | 13 +---
src/Options.cpp | 11 +++-
src/Utils.cpp | 32 +++++++++++
src/XMLSchema.cpp | 118 ++++++++++++++++++++--------------------
src/drivers/faux/Reader.cpp | 6 +-
src/drivers/las/ZipPoint.cpp | 2 +-
src/drivers/oci/Iterator.cpp | 21 +++---
src/drivers/oci/Reader.cpp | 26 ++++----
src/drivers/oci/Writer.cpp | 6 +-
test/unit/OptionsTest.cpp | 18 ++++++
18 files changed, 399 insertions(+), 164 deletions(-)
diffs (truncated from 1037 to 300 lines):
diff -r 4c606c33b9c6 -r 0dec1d001f3a apps/AppSupport.cpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/apps/AppSupport.cpp Mon Aug 15 14:02:39 2011 -0700
@@ -0,0 +1,92 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#include "AppSupport.hpp"
+#include <boost/filesystem.hpp>
+#include <pdal/Utils.hpp>
+#include <pdal/PipelineManager.hpp>
+#include <pdal/PipelineReader.hpp>
+#include <pdal/drivers/las/Reader.hpp>
+#ifdef PDAL_HAVE_LIBLAS
+#include <pdal/drivers/liblas/Reader.hpp>
+#endif
+AppSupport::FileType AppSupport::inferFileType(const std::string& filename)
+ const std::string ext = boost::filesystem::extension(filename);
+ if (pdal::Utils::compare_no_case(ext, ".las")==0) return LAS;
+ if (pdal::Utils::compare_no_case(ext, ".laz")==0) return LAZ;
+ if (pdal::Utils::compare_no_case(ext, ".xml")==0) return XML;
+ return UNKNOWN;
+pdal::Stage* AppSupport::createReader(FileType type, const std::string& filename, const pdal::Options& extraOptions)
+ pdal::Stage* reader = NULL;
+ pdal::Options opts(extraOptions);
+ opts.add<std::string>("filename", filename);
+ switch (type)
+ case LAS:
+ case LAZ:
+ reader = new pdal::drivers::las::LasReader(opts);
+ reader->initialize();
+ break;
+ case LIBLAS_LAS:
+ case LIBLAS_LAZ:
+ reader = new pdal::drivers::liblas::LiblasReader(opts);
+ break;
+#endif
+ case XML:
+ pdal::PipelineManager* pipeManager(new pdal::PipelineManager); // BUG: memleak
+ pdal::PipelineReader pipeReader(*pipeManager);
+ pipeReader.readReaderPipeline(filename);
+ reader = pipeManager->getStage();
+ break;
+ default:
+ return NULL;
+ return reader;
diff -r 4c606c33b9c6 -r 0dec1d001f3a apps/AppSupport.hpp
+++ b/apps/AppSupport.hpp Mon Aug 15 14:02:39 2011 -0700
@@ -0,0 +1,67 @@
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_APPSUPPORT_HPP
+#define INCLUDED_APPSUPPORT_HPP
+#include <string>
+#include <pdal/Options.hpp>
+#include <pdal/Stage.hpp>
+// this is a static class with some helper functions the cmd line apps need
+class AppSupport
+public:
+ enum FileType
+ LAS,
+ LAZ,
+ LIBLAS_LAS,
+ LIBLAS_LAZ,
+ XML,
+ UNKNOWN
+ static FileType inferFileType(const std::string& filename);
+ // creates a Reader using the given driver type
+ // caller takes ownership of the returned pointer... unless it's of type XML :-(
+ static pdal::Stage* createReader(FileType type, const std::string& filename, const pdal::Options& options);
+ AppSupport& operator=(const AppSupport&); // not implemented
+ AppSupport(const AppSupport&); // not implemented
+#endif
diff -r 4c606c33b9c6 -r 0dec1d001f3a apps/Application.cpp
--- a/apps/Application.cpp Mon Aug 15 12:21:54 2011 -0700
+++ b/apps/Application.cpp Mon Aug 15 14:02:39 2011 -0700
@@ -226,9 +226,17 @@
options.add(*sub_options);
- po::store(po::command_line_parser(m_argc, m_argv).
- options(options).positional(m_positionalOptions).run(),
- m_variablesMap);
+ try
+ po::store(po::command_line_parser(m_argc, m_argv).
+ options(options).positional(m_positionalOptions).run(),
+ m_variablesMap);
+ catch (boost::program_options::unknown_option e)
+ usageError("unknown option: " + e.get_option_name());
+ exit(1);
po::notify(m_variablesMap);
diff -r 4c606c33b9c6 -r 0dec1d001f3a apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Mon Aug 15 12:21:54 2011 -0700
+++ b/apps/CMakeLists.txt Mon Aug 15 14:02:39 2011 -0700
@@ -25,6 +25,7 @@
set(PCINFO pcinfo)
set(PCPIPELINE pcpipeline)
+set(COMMON_APP_SOURCES Application.cpp Application.hpp AppSupport.cpp AppSupport.hpp)
set(PDAL_UTILITIES
${PCPIPELINE} ${PCINFO} ${PC2PC} ${PCVIEW})
@@ -52,17 +53,17 @@
# Build pcinfo
if(PCINFO)
- add_executable(${PCINFO} pcinfo.cpp Application.cpp Application.hpp)
+ add_executable(${PCINFO} pcinfo.cpp ${COMMON_APP_SOURCES})
target_link_libraries(${PCINFO} ${APPS_CPP_DEPENDENCIES} )
endif()
if(PC2PC)
- add_executable(${PC2PC} pc2pc.cpp Application.cpp Application.hpp)
+ add_executable(${PC2PC} pc2pc.cpp ${COMMON_APP_SOURCES})
target_link_libraries(${PC2PC} ${APPS_CPP_DEPENDENCIES} )
endif()
if(PCPIPELINE)
- add_executable(${PCPIPELINE} pcpipeline.cpp Application.cpp Application.hpp)
+ add_executable(${PCPIPELINE} pcpipeline.cpp ${COMMON_APP_SOURCES})
target_link_libraries(${PCPIPELINE} ${APPS_CPP_DEPENDENCIES} )
endif()
diff -r 4c606c33b9c6 -r 0dec1d001f3a apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Mon Aug 15 12:21:54 2011 -0700
+++ b/apps/pc2pc.cpp Mon Aug 15 14:02:39 2011 -0700
@@ -46,6 +46,8 @@
#include <boost/property_tree/xml_parser.hpp>
#include "Application.hpp"
using namespace pdal;
diff -r 4c606c33b9c6 -r 0dec1d001f3a apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Mon Aug 15 12:21:54 2011 -0700
+++ b/apps/pcinfo.cpp Mon Aug 15 14:02:39 2011 -0700
@@ -1,33 +1,44 @@
- * Project: libLAS -- C/C++ read/write library for LAS LIDAR data
- * Purpose: LAS information with optional configuration
- * Author: Howard Butler, hobu.inc at gmail.com
- * Copyright (c) 2010, Howard Butler, hobu.inc at gmail.com
- * See LICENSE.txt in this source distribution for more information.
+* OF SUCH DAMAGE.
-#include <pdal/drivers/las/Reader.hpp>
-#ifdef PDAL_HAVE_LIBLAS
-#include <pdal/drivers/liblas/Reader.hpp>
-#endif
#include <pdal/FileUtils.hpp>
-#ifdef PDAL_HAVE_MRSID
-#include <pdal/drivers/mrsid/Reader.hpp>
-#endif
#include <iostream>
More information about the Liblas-commits
