[Liblas-commits] hg-main-tree: move pipeline xml files into a subdir
liblas-commits at liblas.org
Mon Aug 15 21:56:54 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/2b336b016482
changeset: 1105:2b336b016482
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Aug 15 17:21:47 2011 -0700
description:
Subject: hg-main-tree: use StageFactory now
details: http://hg.libpc.orghg-main-tree/rev/d578a5bea239
changeset: 1106:d578a5bea239
date: Mon Aug 15 18:14:01 2011 -0700
description:
Subject: hg-main-tree: checkpoint for driver.pipeline.reader
details: http://hg.libpc.orghg-main-tree/rev/730887bf9816
changeset: 1107:730887bf9816
date: Mon Aug 15 18:56:50 2011 -0700
description:
diffstat:
apps/AppSupport.cpp | 60 +++++------
apps/AppSupport.hpp | 15 +--
apps/pcinfo.cpp | 126 +++----------------------
include/pdal/drivers/pipeline/Iterator.hpp | 79 ++++++++++++++++
include/pdal/drivers/pipeline/Reader.hpp | 85 +++++++++++++++++
src/CMakeLists.txt | 50 +++++++--
src/drivers/pipeline/Iterator.cpp | 91 ++++++++++++++++++
src/drivers/pipeline/Reader.cpp | 103 +++++++++++++++++++++
test/data/pipeline/1.2-with-color.las | 0
test/data/pipeline/pipeline_bad01.xml | 26 +++++
test/data/pipeline/pipeline_bad02.xml | 26 +++++
test/data/pipeline/pipeline_bad03.xml | 29 +++++
test/data/pipeline/pipeline_bad04.xml | 26 +++++
test/data/pipeline/pipeline_bad05.xml | 33 ++++++
test/data/pipeline/pipeline_bad06.xml | 33 ++++++
test/data/pipeline/pipeline_bad07.xml | 33 ++++++
test/data/pipeline/pipeline_bad08.xml | 26 +++++
test/data/pipeline/pipeline_bad09.xml | 26 +++++
test/data/pipeline/pipeline_bad10.xml | 18 +++
test/data/pipeline/pipeline_read.xml | 17 +++
test/data/pipeline/pipeline_readcomments.xml | 18 +++
test/data/pipeline/pipeline_write.xml | 25 +++++
test/data/pipeline/pipeline_write2.xml | 35 +++++++
test/data/pipeline/pipeline_writecomments.xml | 26 +++++
test/data/pipeline/utm15.las | 0
test/data/pipeline_bad01.xml | 26 -----
test/data/pipeline_bad02.xml | 26 -----
test/data/pipeline_bad03.xml | 29 -----
test/data/pipeline_bad04.xml | 26 -----
test/data/pipeline_bad05.xml | 33 ------
test/data/pipeline_bad06.xml | 33 ------
test/data/pipeline_bad07.xml | 33 ------
test/data/pipeline_bad08.xml | 26 -----
test/data/pipeline_bad09.xml | 26 -----
test/data/pipeline_bad10.xml | 18 ---
test/data/pipeline_read.xml | 17 ---
test/data/pipeline_readcomments.xml | 18 ---
test/data/pipeline_write.xml | 25 -----
test/data/pipeline_write2.xml | 35 -------
test/data/pipeline_writecomments.xml | 26 -----
test/unit/PipelineReaderTest.cpp | 46 ++++----
test/unit/PipelineWriterTest.cpp | 8 +-
42 files changed, 866 insertions(+), 591 deletions(-)
diffs (truncated from 1903 to 300 lines):
diff -r 0dec1d001f3a -r 730887bf9816 apps/AppSupport.cpp
--- a/apps/AppSupport.cpp Mon Aug 15 14:02:39 2011 -0700
+++ b/apps/AppSupport.cpp Mon Aug 15 18:56:50 2011 -0700
@@ -38,54 +38,48 @@
#include <pdal/Utils.hpp>
#include <pdal/PipelineManager.hpp>
#include <pdal/PipelineReader.hpp>
-#include <pdal/drivers/las/Reader.hpp>
-#ifdef PDAL_HAVE_LIBLAS
-#include <pdal/drivers/liblas/Reader.hpp>
-#endif
+#include <pdal/StageFactory.hpp>
-AppSupport::FileType AppSupport::inferFileType(const std::string& filename)
+std::string AppSupport::inferReaderDriver(const std::string& filename)
const std::string ext = boost::filesystem::extension(filename);
- if (pdal::Utils::compare_no_case(ext, ".las")==0) return LAS;
- if (pdal::Utils::compare_no_case(ext, ".laz")==0) return LAZ;
- if (pdal::Utils::compare_no_case(ext, ".xml")==0) return XML;
+ // maybe this should live in StageFactory?
+ std::map<std::string, std::string> drivers;
+ drivers[".las"] = "drivers.las.reader";
+ drivers[".laz"] = "drivers.las.reader";
+ drivers[".bin"] = "drivers.terrasolid.reader";
+ drivers[".qi"] = "drivers.qfit.reader";
+ drivers[".xml"] = "drivers.pipeline.reader";
- return UNKNOWN;
+ std::string driver = drivers[ext];
+ if (driver == "")
+ return "";
+ return driver;
-pdal::Stage* AppSupport::createReader(FileType type, const std::string& filename, const pdal::Options& extraOptions)
+pdal::Stage* AppSupport::createReader(const std::string& driver, const std::string& filename, const pdal::Options& extraOptions)
pdal::Stage* reader = NULL;
pdal::Options opts(extraOptions);
opts.add<std::string>("filename", filename);
- switch (type)
+ if (driver == "drivers.pipeline.reader")
- case LAS:
- case LAZ:
- reader = new pdal::drivers::las::LasReader(opts);
- reader->initialize();
- break;
- case LIBLAS_LAS:
- case LIBLAS_LAZ:
- reader = new pdal::drivers::liblas::LiblasReader(opts);
- break;
-#endif
- case XML:
- pdal::PipelineManager* pipeManager(new pdal::PipelineManager); // BUG: memleak
- pdal::PipelineReader pipeReader(*pipeManager);
- pipeReader.readReaderPipeline(filename);
- reader = pipeManager->getStage();
- break;
- default:
- return NULL;
+ pdal::PipelineManager* pipeManager(new pdal::PipelineManager); // BUG: memleak
+ pdal::PipelineReader pipeReader(*pipeManager);
+ pipeReader.readReaderPipeline(filename);
+ reader = pipeManager->getStage();
+ else
+ pdal::StageFactory factory;
+ reader = factory.createReader(driver, opts);
return reader;
diff -r 0dec1d001f3a -r 730887bf9816 apps/AppSupport.hpp
--- a/apps/AppSupport.hpp Mon Aug 15 14:02:39 2011 -0700
+++ b/apps/AppSupport.hpp Mon Aug 15 18:56:50 2011 -0700
@@ -44,21 +44,12 @@
class AppSupport
public:
- enum FileType
- LAS,
- LAZ,
- LIBLAS_LAS,
- LIBLAS_LAZ,
- XML,
- UNKNOWN
- static FileType inferFileType(const std::string& filename);
+ // infer the driver to use based on filename extension
+ static std::string inferReaderDriver(const std::string& filename);
// creates a Reader using the given driver type
// caller takes ownership of the returned pointer... unless it's of type XML :-(
- static pdal::Stage* createReader(FileType type, const std::string& filename, const pdal::Options& options);
+ static pdal::Stage* createReader(const std::string& driver, const std::string& filename, const pdal::Options& options);
AppSupport& operator=(const AppSupport&); // not implemented
AppSupport(const AppSupport&); // not implemented
diff -r 0dec1d001f3a -r 730887bf9816 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Mon Aug 15 14:02:39 2011 -0700
+++ b/apps/pcinfo.cpp Mon Aug 15 18:56:50 2011 -0700
@@ -50,6 +50,7 @@
bool validateOptions();
std::string m_inputFile;
+ boost::uint64_t m_pointNumber;
@@ -84,6 +85,15 @@
addOptionSet(file_options);
+ po::options_description* processing_options = new po::options_description("processing options");
+ processing_options->add_options()
+ ("point,p", po::value<boost::uint64_t>(&m_pointNumber), "point to dump")
+ ("points", "dump stats on all points (read entire dataset)")
+ addOptionSet(processing_options);
addPositionalOption("input", 1);
return;
@@ -98,9 +108,9 @@
return 1;
- AppSupport::FileType type = AppSupport::inferFileType(m_inputFile);
+ std::string driver = AppSupport::inferReaderDriver(m_inputFile);
- if (type == AppSupport::UNKNOWN)
+ if (driver == "")
runtimeError("Cannot determine file type of " + m_inputFile);
return 1;
@@ -108,21 +118,13 @@
if (hasOption("liblas"))
- switch (type)
+ if (driver == "drivers.las.reader")
- case AppSupport::LAS:
- type = AppSupport::LIBLAS_LAS;
- break;
- case AppSupport::LAZ:
- type = AppSupport::LIBLAS_LAZ;
- break;
- default:
- // switch has no effect
- break;
+ driver = "drivers.liblas.reader";
- pdal::Stage* reader = AppSupport::createReader(type, m_inputFile, pdal::Options::none());
+ pdal::Stage* reader = AppSupport::createReader(driver, m_inputFile, pdal::Options::none());
const boost::uint64_t numPoints = reader->getNumPoints();
const pdal::SpatialReference& srs = reader->getSpatialReference();
@@ -130,7 +132,7 @@
std::cout << numPoints << " points\n";
std::cout << "WKT: " << srs.getWKT() << "\n";
- if (type != AppSupport::XML)
+ if (driver != "drivers.pipeline.reader")
delete reader;
@@ -147,17 +149,6 @@
#if 0
-#include <liblas/liblas.hpp>
-#include "laskernel.hpp"
-#include <boost/cstdint.hpp>
-#include <boost/foreach.hpp>
-#include <locale>
-using namespace liblas;
-using namespace std;
liblas::Summary check_points( liblas::Reader& reader,
@@ -201,20 +192,7 @@
-void OutputHelp( std::ostream & oss, po::options_description const& options)
- oss << "--------------------------------------------------------------------\n";
- oss << " lasinfo (" << GetFullVersion() << ")\n";
- oss << options;
- oss <<"\nFor more information, see the full documentation for lasinfo at:\n";
- oss << " http://liblas.org/utilities/lasinfo.html\n";
- oss << "----------------------------------------------------------\n";
void PrintVLRs(std::ostream& os, liblas::Header const& header)
@@ -249,26 +227,9 @@
bool use_locale = false;
boost::uint32_t point = 0;
- std::vector<liblas::FilterPtr> filters;
- std::vector<liblas::TransformPtr> transforms;
- liblas::Header header;
- try {
- po::options_description file_options("lasinfo options");
- po::options_description filtering_options = GetFilteringOptions();
- po::options_description header_options = GetHeaderOptions();
- po::positional_options_description p;
- p.add("input", 1);
- p.add("output", 1);
file_options.add_options()
- ("help,h", "produce help message")
- ("input,i", po::value< string >(), "input LAS file")
- ("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Verbose message output")
("no-vlrs", po::value<bool>(&show_vlrs)->zero_tokens()->implicit_value(false), "Don't show VLRs")
("no-schema", po::value<bool>(&show_schema)->zero_tokens()->implicit_value(false), "Don't show schema")
("no-check", po::value<bool>(&check)->zero_tokens()->implicit_value(false), "Don't scan points")
@@ -280,60 +241,17 @@
// --xml
// --json
// --restructured text output
- po::variables_map vm;
- po::options_description options;
- options.add(file_options).add(filtering_options);
- po::store(po::command_line_parser(argc, argv).
- options(options).positional(p).run(), vm);
- po::notify(vm);
- if (vm.count("help"))
- OutputHelp(std::cout, options);
- return 1;
if (vm.count("point"))
show_point = true;
- if (vm.count("input"))
- input = vm["input"].as< string >();
- std::ifstream ifs;
- if (verbose)
- std::cout << "Opening " << input << " to fetch Header" << std::endl;
- if (!liblas::Open(ifs, input.c_str()))
- std::cerr << "Cannot open " << input << " for read. Exiting..." << std::endl;
- return 1;
- liblas::ReaderFactory f;
- liblas::Reader reader = f.CreateWithStream(ifs);
- header = reader.GetHeader();
- } else {
- std::cerr << "Input LAS file not specified!\n";
- return 1;
- filters = GetFilters(vm, verbose);
More information about the Liblas-commits
