[Liblas-commits] hg-main-tree: added toPTree()
liblas-commits at liblas.org
Tue Aug 16 19:37:45 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/ab5feaec6887
changeset: 1117:ab5feaec6887
user: Michael P. Gerlek <mpg at flaxen.com>
date: Tue Aug 16 16:33:22 2011 -0700
description:
added toPTree()
Subject: hg-main-tree: dump a point
details: http://hg.libpc.orghg-main-tree/rev/5a3b4adbe9c4
changeset: 1118:5a3b4adbe9c4
date: Tue Aug 16 16:33:56 2011 -0700
description:
dump a point
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/81a6d2019289
changeset: 1119:81a6d2019289
date: Tue Aug 16 16:34:03 2011 -0700
description:
merge
Subject: hg-main-tree: sync test with pg's fix
details: http://hg.libpc.orghg-main-tree/rev/3bee676e3465
changeset: 1120:3bee676e3465
date: Tue Aug 16 16:37:29 2011 -0700
description:
diffstat:
apps/pcinfo.cpp | 11 ++++-
apps/pcpipeline.cpp | 5 +-
include/pdal/PointBuffer.hpp | 21 +++++++++-
src/PointBuffer.cpp | 85 +++++++++++++++++++++++++++++++++++++++----
test/unit/pcpipelineTest.cpp | 2 +-
5 files changed, 108 insertions(+), 16 deletions(-)
diffs (222 lines):
diff -r ccdbae669d00 -r 3bee676e3465 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Tue Aug 16 13:04:42 2011 -0700
+++ b/apps/pcinfo.cpp Tue Aug 16 16:37:29 2011 -0700
@@ -43,6 +43,8 @@
#include <pdal/FileUtils.hpp>
#include <pdal/PointBuffer.hpp>
#include <pdal/filters/StatsFilter.hpp>
+#include <boost/property_tree/xml_parser.hpp>
+#include <boost/property_tree/json_parser.hpp>
#include "AppSupport.hpp"
#include "Application.hpp"
@@ -132,7 +134,12 @@
throw app_runtime_error("problem reading point number " + m_pointNumber);
- std::cout << "Read point " << m_pointNumber << "\n";
+ std::cout << "Read point " << m_pointNumber << ":\n";
+ boost::property_tree::ptree t = data.toPTree();
+ write_json(std::cout, t.get_child("0"));
+ std::cout << "\n";
return;
@@ -148,7 +155,7 @@
boost::uint64_t totRead = 0;
while (!iter->atEnd())
- pdal::PointBuffer data(layout, 1024);
+ pdal::PointBuffer data(layout, iter->getChunkSize());
const boost::uint32_t numRead = iter->read(data);
totRead += numRead;
diff -r ccdbae669d00 -r 3bee676e3465 apps/pcpipeline.cpp
--- a/apps/pcpipeline.cpp Tue Aug 16 13:04:42 2011 -0700
+++ b/apps/pcpipeline.cpp Tue Aug 16 16:37:29 2011 -0700
@@ -72,7 +72,7 @@
if (!hasOption("input"))
- throw app_usage_error("--input/-i required");
+ throw app_usage_error("input file name required");
return;
@@ -84,10 +84,11 @@
po::options_description* file_options = new po::options_description("file options");
file_options->add_options()
- ("input,i", po::value<std::string>(&m_inputFile), "input file name (required)")
+ ("input,i", po::value<std::string>(&m_inputFile), "input file name")
addOptionSet(file_options);
+ addPositionalOption("input", 1);
diff -r ccdbae669d00 -r 3bee676e3465 include/pdal/PointBuffer.hpp
--- a/include/pdal/PointBuffer.hpp Tue Aug 16 13:04:42 2011 -0700
+++ b/include/pdal/PointBuffer.hpp Tue Aug 16 16:37:29 2011 -0700
@@ -178,15 +178,32 @@
// access to the raw memory
void getData(boost::uint8_t** data, std::size_t* array_size) const;
+ // returns a ptree containing the point records, useful for dumping
+ // and such
+ // The tree will look like this:
+ // 0:
+ // X: 1.00
+ // Y: 2.00
+ // Z: 3.00
+ // 1:
+ // X: 1.00
+ // Y: 2.00
+ // Z: 3.00
+ // If you want to print out details about the fields, e.g. the byte
+ // offset or the datatype, use the Schema's ptree dumper.
+ boost::property_tree::ptree toPTree() const;
private:
SchemaLayout m_schemaLayout;
boost::scoped_array<boost::uint8_t> m_data;
std::size_t m_pointSize;
boost::uint32_t m_numPoints;
boost::uint32_t m_capacity;
Bounds<double> m_bounds;
diff -r ccdbae669d00 -r 3bee676e3465 src/PointBuffer.cpp
--- a/src/PointBuffer.cpp Tue Aug 16 13:04:42 2011 -0700
+++ b/src/PointBuffer.cpp Tue Aug 16 16:37:29 2011 -0700
@@ -34,6 +34,11 @@
+#include <boost/lexical_cast.hpp>
+#include <pdal/exceptions.hpp>
namespace pdal
@@ -127,6 +132,75 @@
+boost::property_tree::ptree PointBuffer::toPTree() const
+ boost::property_tree::ptree tree;
+ const SchemaLayout& schemaLayout = getSchemaLayout();
+ const std::vector<DimensionLayout>& dimensionLayouts = schemaLayout.getDimensionLayouts();
+ const boost::uint32_t numPoints = getNumPoints();
+ for (boost::uint32_t pointIndex=0; pointIndex<numPoints; pointIndex++)
+ const std::string pointstring = boost::lexical_cast<std::string>(pointIndex) + ".";
+ for (SchemaLayout::DimensionLayoutsCIter citer=dimensionLayouts.begin(); citer != dimensionLayouts.end(); ++citer)
+ const DimensionLayout& dimensionLayout = *citer;
+ const Dimension& dimension = dimensionLayout.getDimension();
+ const std::size_t fieldIndex = dimensionLayout.getPosition();
+ const std::string key = pointstring + dimension.getFieldName();
+ std::string value = "";
+ switch (dimension.getDataType())
+#define GETFIELDAS(type) getField<##type##>(pointIndex, fieldIndex)
+#define STRINGIFY(x) boost::lexical_cast<std::string>(x)
+ // note we convert 8-bit fields to ints, so they aren't treated as chars
+ case Dimension::Int8:
+ value += STRINGIFY((int)GETFIELDAS(boost::int8_t));
+ break;
+ case Dimension::Uint8:
+ value += STRINGIFY((int)GETFIELDAS(boost::uint8_t));
+ break;
+ case Dimension::Int16:
+ value += STRINGIFY(GETFIELDAS(boost::int16_t));
+ break;
+ case Dimension::Uint16:
+ value += STRINGIFY(GETFIELDAS(boost::uint16_t));
+ break;
+ case Dimension::Int32:
+ value += STRINGIFY(GETFIELDAS(boost::int32_t));
+ break;
+ case Dimension::Uint32:
+ value += STRINGIFY(GETFIELDAS(boost::uint32_t));
+ break;
+ case Dimension::Int64:
+ value += STRINGIFY(GETFIELDAS(boost::int64_t));
+ break;
+ case Dimension::Uint64:
+ value += STRINGIFY(GETFIELDAS(boost::uint64_t));
+ break;
+ case Dimension::Float:
+ value += STRINGIFY(GETFIELDAS(float));
+ break;
+ case Dimension::Double:
+ value += STRINGIFY(GETFIELDAS(double));
+ break;
+ default:
+ throw pdal_error("unknown dimension data type");
+ tree.add(key, value);
+ return tree;
std::ostream& operator<<(std::ostream& ostr, const PointBuffer& PointBuffer)
using std::endl;
@@ -135,18 +209,11 @@
const std::size_t numPoints = PointBuffer.getNumPoints();
- int cnt = 0;
- for (boost::uint32_t pointIndex=0; pointIndex<numPoints; pointIndex++)
- ++cnt;
- ostr << "Contains " << cnt << " points (" << PointBuffer.getNumPoints() << " total)" << endl;
+ ostr << "Contains " << numPoints << " points" << endl;
ostr << "Point: " << pointIndex << endl;
diff -r ccdbae669d00 -r 3bee676e3465 test/unit/pcpipelineTest.cpp
--- a/test/unit/pcpipelineTest.cpp Tue Aug 16 13:04:42 2011 -0700
+++ b/test/unit/pcpipelineTest.cpp Tue Aug 16 16:37:29 2011 -0700
@@ -61,7 +61,7 @@
int stat = Support::run_command(cmd, output);
BOOST_CHECK_EQUAL(stat, 1);
- const std::string expected = "Usage error: --input";
+ const std::string expected = "Usage error: input file name required";
BOOST_CHECK_EQUAL(output.substr(0, expected.length()), expected);
return;
More information about the Liblas-commits
