[Liblas-commits] hg-main-tree: cleanups for oper<<, dump(),
toPTree()
liblas-commits at liblas.org
Wed Aug 17 01:04:18 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/8b6a2d6f06dd
changeset: 1121:8b6a2d6f06dd
user: Michael P. Gerlek <mpg at flaxen.com>
date: Tue Aug 16 22:02:37 2011 -0700
description:
cleanups for oper<<, dump(), toPTree()
Subject: hg-main-tree: tests for toPTree()
details: http://hg.libpc.orghg-main-tree/rev/63a402b1c172
changeset: 1122:63a402b1c172
date: Tue Aug 16 22:03:07 2011 -0700
description:
tests for toPTree()
Subject: hg-main-tree: okay to have no opts
details: http://hg.libpc.orghg-main-tree/rev/649a5bf0b633
changeset: 1123:649a5bf0b633
date: Tue Aug 16 22:03:38 2011 -0700
description:
Subject: hg-main-tree: added --schema
details: http://hg.libpc.orghg-main-tree/rev/b783d1c72c38
changeset: 1124:b783d1c72c38
date: Tue Aug 16 22:03:58 2011 -0700
description:
added --schema
diffstat:
apps/Application.hpp | 2 +-
apps/pcinfo.cpp | 58 +++-
include/pdal/Bounds.hpp | 17 +
include/pdal/Dimension.hpp | 13 +-
include/pdal/DimensionLayout.hpp | 13 +-
include/pdal/Options.hpp | 4 +-
include/pdal/Range.hpp | 16 +
include/pdal/Schema.hpp | 18 +-
include/pdal/SchemaLayout.hpp | 13 +-
include/pdal/SpatialReference.hpp | 3 +-
include/pdal/StageBase.hpp | 3 +
include/pdal/Vector.hpp | 20 +-
src/Dimension.cpp | 437 +++++++++++++++++++------------------
src/DimensionLayout.cpp | 39 +-
src/Options.cpp | 22 +-
src/Schema.cpp | 95 ++-----
src/SchemaLayout.cpp | 45 +--
src/SpatialReference.cpp | 61 +++--
src/StageBase.cpp | 25 ++-
test/unit/BoundsTest.cpp | 59 +++-
test/unit/DimensionLayoutTest.cpp | 23 +-
test/unit/DimensionTest.cpp | 22 +-
test/unit/PointBufferTest.cpp | 24 ++
test/unit/RangeTest.cpp | 20 +
test/unit/SchemaLayoutTest.cpp | 26 ++
test/unit/SchemaTest.cpp | 26 ++
test/unit/VectorTest.cpp | 22 +
27 files changed, 718 insertions(+), 408 deletions(-)
diffs (truncated from 1652 to 300 lines):
diff -r 3bee676e3465 -r b783d1c72c38 apps/Application.hpp
--- a/apps/Application.hpp Tue Aug 16 16:37:29 2011 -0700
+++ b/apps/Application.hpp Tue Aug 16 22:03:58 2011 -0700
@@ -82,7 +82,7 @@
protected:
// implement this, with calls to addOptionSet()
- virtual void addOptions() = 0;
+ virtual void addOptions() {}
// implement this, to do sanity checking of cmd line
// will throw if the user gave us bad options
diff -r 3bee676e3465 -r b783d1c72c38 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Tue Aug 16 16:37:29 2011 -0700
+++ b/apps/pcinfo.cpp Tue Aug 16 22:03:58 2011 -0700
@@ -54,13 +54,16 @@
public:
PcInfo(int argc, char* argv[]);
- int execute();
+ int execute(); // overrride
private:
- void addOptions();
- void validateOptions();
- void readOnePoint();
- void readAllPoints();
+ void addOptions(); // overrride
+ void validateOptions(); // overrride
+ void dumpOnePoint() const;
+ void dumpPointsSummary() const;
+ void dumpSchema() const;
+ void dumpStage() const;
pdal::Stage* m_reader;
std::string m_inputFile;
@@ -108,6 +111,7 @@
processing_options->add_options()
("point,p", po::value<boost::uint64_t>(&m_pointNumber), "point to dump")
("points,a", "dump stats on all points (read entire dataset)")
+ ("schema,s", "dump the schema")
addOptionSet(processing_options);
@@ -118,7 +122,7 @@
-void PcInfo::readOnePoint()
+void PcInfo::dumpOnePoint() const
const pdal::Schema& schema = m_reader->getSchema();
pdal::SchemaLayout layout(schema);
@@ -145,7 +149,7 @@
-void PcInfo::readAllPoints()
+void PcInfo::dumpPointsSummary() const
@@ -167,6 +171,29 @@
+void PcInfo::dumpSchema() const
+ const pdal::Schema& schema = m_reader->getSchema();
+ boost::property_tree::ptree tree = schema.toPTree();
+ boost::property_tree::write_json(std::cout, tree);
+ return;
+void PcInfo::dumpStage() const
+ const boost::uint64_t numPoints = m_reader->getNumPoints();
+ const pdal::SpatialReference& srs = m_reader->getSpatialReference();
+ std::cout << "driver type: " << m_reader->getName() << "\n";
+ std::cout << numPoints << " points\n";
+ std::cout << "WKT: " << srs.getWKT() << "\n";
int PcInfo::execute()
if (!pdal::FileUtils::fileExists(m_inputFile))
@@ -191,27 +218,24 @@
options.add<boost::uint8_t>("verbose", getVerboseLevel());
m_reader = AppSupport::createReader(driver, m_inputFile, options);
m_reader->initialize();
+ dumpStage();
if (hasOption("point"))
- readOnePoint();
+ dumpOnePoint();
if (hasOption("points"))
- readAllPoints();
+ dumpPointsSummary();
+ if (hasOption("schema"))
- const boost::uint64_t numPoints = m_reader->getNumPoints();
- const pdal::SpatialReference& srs = m_reader->getSpatialReference();
- std::cout << "driver type: " << m_reader->getName() << "\n";
- std::cout << numPoints << " points\n";
- std::cout << "WKT: " << srs.getWKT() << "\n";
+ dumpSchema();
return 0;
diff -r 3bee676e3465 -r b783d1c72c38 include/pdal/Bounds.hpp
--- a/include/pdal/Bounds.hpp Tue Aug 16 16:37:29 2011 -0700
+++ b/include/pdal/Bounds.hpp Tue Aug 16 22:03:58 2011 -0700
@@ -47,6 +47,7 @@
#include <cassert>
#include <vector>
#include <sstream>
+#include <boost/property_tree/ptree.hpp>
#include <pdal/Vector.hpp>
#include <pdal/Range.hpp>
@@ -424,6 +425,22 @@
static Bounds v(minv,minv,minv,maxv,maxv,maxv);
return v;
+ boost::property_tree::ptree toPTree() const
+ boost::property_tree::ptree tree;
+ for (std::size_t i = 0; i < size(); ++i)
+ const Range<T>& r = dimensions()[i];
+ tree.add_child(boost::lexical_cast<std::string>(i), r.toPTree());
+ return tree;
+ void dump() const
+ std::cout << *this;
diff -r 3bee676e3465 -r b783d1c72c38 include/pdal/Dimension.hpp
--- a/include/pdal/Dimension.hpp Tue Aug 16 16:37:29 2011 -0700
+++ b/include/pdal/Dimension.hpp Tue Aug 16 22:03:58 2011 -0700
@@ -281,7 +281,18 @@
m_endian = v;
- boost::property_tree::ptree GetPTree() const;
+ // returns a ptree representing the Dimension
+ // looks like this:
+ // name: X
+ // datatype: double
+ // description: ...
+ // bytesize:
+ boost::property_tree::ptree toPTree() const;
+ void dump() const;
private:
DataType m_dataType;
diff -r 3bee676e3465 -r b783d1c72c38 include/pdal/DimensionLayout.hpp
--- a/include/pdal/DimensionLayout.hpp Tue Aug 16 16:37:29 2011 -0700
+++ b/include/pdal/DimensionLayout.hpp Tue Aug 16 22:03:58 2011 -0700
@@ -102,6 +102,18 @@
return m_position > dim.m_position;
+ // returns a ptree representing the DimensionLayout
+ // dimension:
+ // [Dimension ptree]
+ // byteoffset: 41
+ // position: 17
private:
Dimension m_dimension;
std::size_t m_byteOffset;
@@ -111,7 +123,6 @@
PDAL_DLL std::ostream& operator<<(std::ostream& os, pdal::DimensionLayout const& d);
} // namespace pdal
#endif // PDAL_DIMENSIONLAYOUT_HPP_INCLUDED
diff -r 3bee676e3465 -r b783d1c72c38 include/pdal/Options.hpp
--- a/include/pdal/Options.hpp Tue Aug 16 16:37:29 2011 -0700
+++ b/include/pdal/Options.hpp Tue Aug 16 22:03:58 2011 -0700
@@ -260,6 +260,8 @@
// BUG: this should be a member variable, not a function, but doing so causes vs2010 to fail to link
static const Options& none();
private:
// get the ptree for an option
// throws pdal::option_not_found if the option name is not valid
@@ -269,7 +271,7 @@
-PDAL_DLL std::ostream& operator<<(std::ostream& ostr, const OptionsOld&);
+PDAL_DLL std::ostream& operator<<(std::ostream& ostr, const Options&);
} // namespace pdal
diff -r 3bee676e3465 -r b783d1c72c38 include/pdal/Range.hpp
--- a/include/pdal/Range.hpp Tue Aug 16 16:37:29 2011 -0700
+++ b/include/pdal/Range.hpp Tue Aug 16 22:03:58 2011 -0700
@@ -37,6 +37,9 @@
#include <pdal/pdal.hpp>
+#include <boost/lexical_cast.hpp>
#include <pdal/Utils.hpp>
namespace pdal
@@ -186,6 +189,19 @@
return m_maximum - m_minimum;
+ tree.add("minimum", getMinimum());
+ tree.add("maximum", getMaximum());
+ return tree;
+ void dump() const
diff -r 3bee676e3465 -r b783d1c72c38 include/pdal/Schema.hpp
--- a/include/pdal/Schema.hpp Tue Aug 16 16:37:29 2011 -0700
+++ b/include/pdal/Schema.hpp Tue Aug 16 22:03:58 2011 -0700
@@ -105,10 +105,19 @@
bool hasDimension(Dimension::Field field, Dimension::DataType datatype) const;
bool hasDimension(const Dimension& dim) const;
- boost::property_tree::ptree getPTree() const;
+ // returns a ptree reprsenting the Schema
+ // dimension:
+ // dimension:
- void dump() const;
static Schema from_xml(std::string const& xml, std::string const& xsd);
static Schema from_xml(std::string const& xml);
static std::string to_xml(Schema const& schema);
@@ -123,8 +132,7 @@
-PDAL_DLL std::ostream& operator<<(std::ostream& os, Schema const&);
More information about the Liblas-commits
