[Liblas-commits] libpc: namespacing, adding Bounds class
liblas-commits at liblas.org
Thu Feb 10 23:53:16 EST 2011
details: http://hg.liblas.orglibpc/rev/5b5218def9ed
changeset: 29:5b5218def9ed
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Feb 10 20:47:31 2011 -0800
description:
Subject: libpc: merge
details: http://hg.liblas.orglibpc/rev/605c80e02696
changeset: 30:605c80e02696
date: Thu Feb 10 20:53:09 2011 -0800
description:
merge
diffstat:
apps/CMakeLists.txt | 2 +-
apps/pc2pc.cpp | 5 +-
apps/pcinfo.cpp | 6 +-
include/libpc/Bounds.hpp | 465 +++++++++++++++++++++++++++++++++++++----
include/libpc/ColorFilter.hpp | 9 +-
include/libpc/CropFilter.hpp | 11 +-
include/libpc/FauxReader.hpp | 9 +-
include/libpc/FauxWriter.hpp | 7 +-
include/libpc/Field.hpp | 7 +-
include/libpc/Filter.hpp | 10 +-
include/libpc/Header.hpp | 14 +-
include/libpc/PointData.hpp | 11 +-
include/libpc/PointLayout.hpp | 7 +-
include/libpc/Range.hpp | 153 +++++++++++++
include/libpc/Reader.hpp | 6 +-
include/libpc/Stage.hpp | 6 +-
include/libpc/Utils.hpp | 15 +
include/libpc/Writer.hpp | 6 +-
include/libpc/export.hpp | 60 +++++
mpg-config.bat | 4 +-
src/Bounds.cpp | 36 ---
src/CMakeLists.txt | 4 +-
src/ColorFilter.cpp | 5 +-
src/FauxReader.cpp | 17 +-
src/FauxWriter.cpp | 1 +
test/unit/CMakeLists.txt | 2 +-
26 files changed, 753 insertions(+), 125 deletions(-)
diffs (truncated from 1298 to 300 lines):
diff -r c60e5261cfc2 -r 605c80e02696 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Wed Feb 09 20:14:32 2011 -0800
+++ b/apps/CMakeLists.txt Thu Feb 10 20:53:09 2011 -0800
@@ -43,7 +43,7 @@
# Configure build targets
if(WIN32)
- add_definitions("-DPC_DLL_EXPORT=1")
+ add_definitions("-DLIBPC_DLL_EXPORT=1")
endif()
diff -r c60e5261cfc2 -r 605c80e02696 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Wed Feb 09 20:14:32 2011 -0800
+++ b/apps/pc2pc.cpp Thu Feb 10 20:53:09 2011 -0800
@@ -9,10 +9,11 @@
* See LICENSE.txt in this source distribution for more information.
-#include <stdio.h>
+#include <libpc/Bounds.hpp>
int main(int, char* [])
- printf("Hi\n");
+ Bounds bounds(1,2,3,4,5,6);
+ bounds.dump();
return 0;
#if 0
diff -r c60e5261cfc2 -r 605c80e02696 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Wed Feb 09 20:14:32 2011 -0800
+++ b/apps/pcinfo.cpp Thu Feb 10 20:53:09 2011 -0800
@@ -9,10 +9,12 @@
-#include <stdio.h>
- printf("Hi\n");
+ Bounds bounds(0,1,2,3,4,5);
+ bounds.dump();
return 0;
#if 0
diff -r c60e5261cfc2 -r 605c80e02696 include/libpc/Bounds.hpp
--- a/include/libpc/Bounds.hpp Wed Feb 09 20:14:32 2011 -0800
+++ b/include/libpc/Bounds.hpp Thu Feb 10 20:53:09 2011 -0800
@@ -1,5 +1,5 @@
-* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* Copyright (c) 2011, Howard Butler, hobu.inc at gmail.com
* All rights reserved.
@@ -35,71 +35,432 @@
#ifndef INCLUDED_BOUNDS_HPP
#define INCLUDED_BOUNDS_HPP
-#include <limits>
+#include <vector>
+#include <iostream>
+#include <sstream>
+#include <string>
+#include "libpc/export.hpp"
+#include "libpc/Range.hpp"
+namespace libpc
+template <typename T>
class Bounds
public:
- Bounds()
- : m_minX(-std::numeric_limits<double>::infinity()),
- m_maxX(std::numeric_limits<double>::infinity()),
- m_minY(-std::numeric_limits<double>::infinity()),
- m_maxY(std::numeric_limits<double>::infinity()),
- m_minZ(-std::numeric_limits<double>::infinity()),
- m_maxZ(std::numeric_limits<double>::infinity())
- Bounds(double minX, double maxX, double minY, double maxY, double minZ, double maxZ)
- : m_minX(minX),
- m_maxX(maxX),
- m_minY(minY),
- m_maxY(maxY),
- m_minZ(minZ),
- m_maxZ(maxZ)
+ typedef T value_type;
+ typedef typename std::vector< Range<T> >::size_type size_type;
+ typedef typename std::vector< Range<T> > RangeVec;
+private:
- Bounds(const Bounds& other)
- : m_minX(other.m_minX),
- m_maxX(other.m_maxX),
- m_minY(other.m_minY),
- m_maxY(other.m_maxY),
- m_minZ(other.m_minZ),
- m_maxZ(other.m_maxZ)
+ RangeVec ranges;
+public:
- Bounds& operator=(const Bounds & other)
- if (this != &other)
+Bounds<T>()
+ ranges.resize(0);
+Bounds(Bounds const& other)
+ ranges(other.ranges)
+Bounds(RangeVec const& rngs)
+ ranges(rngs)
+Bounds( T minx,
+ T miny,
+ T minz,
+ T maxx,
+ T maxy,
+ T maxz)
+ ranges.resize(3);
+ ranges[0].minimum = minx;
+ ranges[1].minimum = miny;
+ ranges[2].minimum = minz;
+ ranges[0].maximum = maxx;
+ ranges[1].maximum = maxy;
+ ranges[2].maximum = maxz;
+#ifdef DEBUG
+ verify();
+#endif
+Bounds( T minx,
+ T miny,
+ T maxx,
+ T maxy)
+ ranges.resize(2);
+#ifdef DEBUG
+ verify();
+#endif
+////Bounds( const Point& min, const Point& max)
+//// ranges.resize(3);
+//// ranges[0].minimum = min.GetX();
+//// ranges[1].minimum = min.GetY();
+//// ranges[2].minimum = min.GetZ();
+//// ranges[0].maximum = max.GetX();
+//// ranges[1].maximum = max.GetY();
+//// ranges[2].maximum = max.GetZ();
+////#ifdef DEBUG
+//// verify();
+////#endif
+T (min)(std::size_t const& index) const
+ if (ranges.size() <= index) {
+ // std::ostringstream msg;
+ // msg << "Bounds dimensions, " << ranges.size() <<", is less "
+ // << "than the given index, " << index;
+ // throw std::runtime_error(msg.str());
+ return 0;
+ return ranges[index].minimum;
+void (min)(std::size_t const& index, T v)
+ ranges.resize(index + 1);
+ ranges[index].minimum = v;
+T (max)(std::size_t const& index) const
+ return 0;
+ return ranges[index].maximum;
+void (max)(std::size_t const& index, T v)
+ ranges[index].maximum = v;
+////liblas::Point (min)() {
+//// liblas::Point p;
+//// try
+//// p.SetCoordinates(ranges[0].minimum, ranges[1].minimum, ranges[2].minimum);
+//// catch (std::runtime_error const& e)
+//// ::boost::ignore_unused_variable_warning(e);
+//// p.SetCoordinates(ranges[0].minimum, ranges[1].minimum, 0);
+//// return p;
+////liblas::Point (max)() {
+//// try
+//// p.SetCoordinates(ranges[0].maximum, ranges[1].maximum, ranges[2].maximum);
+//// p.SetCoordinates(ranges[0].maximum, ranges[1].maximum, 0);
+//// return p;
+#if 0
+// BUG: what are the semantics of these?
+T minx() const { if (ranges.size() == 0) return 0; return ranges[0].minimum; }
+T miny() const { if (ranges.size() < 2) return 0; return ranges[1].minimum; }
+T minz() const { if (ranges.size() < 3) return 0; return ranges[2].minimum; }
+T maxx() const { if (ranges.size() == 0) return 0; return ranges[0].maximum; }
+T maxy() const { if (ranges.size() < 2) return 0; return ranges[1].maximum; }
+T maxz() const { if (ranges.size() < 3) return 0; return ranges[2].maximum; }
+#endif
+inline bool operator==(Bounds<T> const& rhs) const
+ return equal(rhs);
+inline bool operator!=(Bounds<T> const& rhs) const
+ return (!equal(rhs));
+Bounds<T>& operator=(Bounds<T> const& rhs)
+ if (&rhs != this)
- m_minX = other.m_minX;
- m_maxX = other.m_maxX;
- m_minY = other.m_minY;
- m_maxY = other.m_maxY;
- m_minZ = other.m_minZ;
- m_maxZ = other.m_maxZ;
+ ranges = rhs.ranges;
return *this;
More information about the Liblas-commits
