[Liblas-commits] libpc: building with liblas' Bounds class now
liblas-commits at liblas.org
Fri Feb 11 00:46:24 EST 2011
details: http://hg.liblas.orglibpc/rev/46b2d79f3ae6
changeset: 31:46b2d79f3ae6
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Feb 10 21:46:18 2011 -0800
description:
diffstat:
apps/pc2pc.cpp | 12 +++++++--
apps/pcinfo.cpp | 10 +++++--
include/libpc/Bounds.hpp | 52 +++++++++++++++++++++---------------------
include/libpc/Field.hpp | 1 +
include/libpc/MosaicFilter.hpp | 7 ++++-
include/libpc/Range.hpp | 6 ++--
include/libpc/Utils.hpp | 6 ++++-
include/libpc/export.hpp | 3 +-
mpg-config.bat | 4 +-
src/Field.cpp | 2 +
src/Filter.cpp | 3 ++
src/Header.cpp | 8 ++++--
src/MosaicFilter.cpp | 3 +-
src/PointData.cpp | 6 +++-
src/PointLayout.cpp | 2 +
src/Reader.cpp | 3 ++
src/Stage.cpp | 3 ++
src/Writer.cpp | 2 +
18 files changed, 87 insertions(+), 46 deletions(-)
diffs (truncated from 421 to 300 lines):
diff -r 605c80e02696 -r 46b2d79f3ae6 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Thu Feb 10 20:53:09 2011 -0800
+++ b/apps/pc2pc.cpp Thu Feb 10 21:46:18 2011 -0800
@@ -9,11 +9,17 @@
* See LICENSE.txt in this source distribution for more information.
-#include <libpc/Bounds.hpp>
+#include <iostream>
+#include "libpc/Bounds.hpp"
+using namespace libpc;
int main(int, char* [])
- Bounds bounds(1,2,3,4,5,6);
- bounds.dump();
+ Bounds<double> bounds(1,2,3,4,5,6);
+ std::cout << bounds;
return 0;
#if 0
diff -r 605c80e02696 -r 46b2d79f3ae6 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Thu Feb 10 20:53:09 2011 -0800
+++ b/apps/pcinfo.cpp Thu Feb 10 21:46:18 2011 -0800
@@ -9,12 +9,16 @@
- Bounds bounds(0,1,2,3,4,5);
- bounds.dump();
+ Bounds<double> bounds(0,1,2,3,4,5);
return 0;
#if 0
diff -r 605c80e02696 -r 46b2d79f3ae6 include/libpc/Bounds.hpp
--- a/include/libpc/Bounds.hpp Thu Feb 10 20:53:09 2011 -0800
+++ b/include/libpc/Bounds.hpp Thu Feb 10 21:46:18 2011 -0800
@@ -42,22 +42,21 @@
#include "libpc/export.hpp"
#include "libpc/Range.hpp"
+#include "libpc/Utils.hpp"
namespace libpc
template <typename T>
-class Bounds
+class LIBPC_DLL Bounds
public:
+ typedef T value_type;
+ typedef typename std::vector< Range<T> >::size_type size_type;
+ typedef typename std::vector< Range<T> > RangeVec;
- typedef T value_type;
- typedef typename std::vector< Range<T> >::size_type size_type;
- typedef typename std::vector< Range<T> > RangeVec;
private:
- RangeVec ranges;
+ RangeVec ranges;
public:
@@ -288,13 +287,14 @@
/// Does this Bounds contain other?
bool contains(Bounds const& other) const
- for (size_type i = 0; i < dimension(); i++) {
- if ( ranges[i].contains(other.ranges[i]) )
- return true;
- else // As soon as it is not contains, we're false
- return false;
- return true;
+ // BUG: this loop only executes once, what is intended semantics?
+ for (size_type i = 0; i < dimension(); i++) {
+ if ( ranges[i].contains(other.ranges[i]) )
+ return true;
+ else // As soon as it is not contains, we're false
+ return false;
+ return true;
/////// Does this Bounds this point other?
@@ -415,8 +415,8 @@
if ((min)(d) > (max)(d) )
// Check that we're not infinity either way
- if ( (compare_distance((min)(d), (std::numeric_limits<T>::max)()) ||
- compare_distance((max)(d), -(std::numeric_limits<T>::max)()) ))
+ if ( (Utils::compare_distance((min)(d), (std::numeric_limits<T>::max)()) ||
+ Utils::compare_distance((max)(d), -(std::numeric_limits<T>::max)()) ))
std::ostringstream msg;
msg << "liblas::Bounds::verify: Minimum point at dimension " << d
@@ -426,8 +426,8 @@
-friend std::ostream& operator<<(std::ostream& ostr, const Bounds<T>& bounds);
+//friend std::ostream& operator<<(std::ostream& ostr, const Bounds<T>& bounds);
////Bounds<T> project(liblas::SpatialReference const& in_ref, liblas::SpatialReference const& out_ref)
@@ -445,14 +445,14 @@
template<class T>
-std::ostream& operator<<(std::ostream& ostr, const Bounds<T>& bounds)
- for (std::size_type d = 0; d < dimension(); ++d)
- const Range<T>& r = bounds.ranges[d];
- ostr << "(" << r.minimum << "," << r.maximum << ")";
- return ostr;
+std::ostream& operator<<(std::ostream& ostr, const Bounds<T>& bounds)
+ for (size_t d = 0; d < bounds.dimension(); ++d)
+ const Range<T>& r = bounds.dims()[d];
+ ostr << "(" << r.minimum << "," << r.maximum << ")";
+ return ostr;
} // namespace libpc
diff -r 605c80e02696 -r 46b2d79f3ae6 include/libpc/Field.hpp
--- a/include/libpc/Field.hpp Thu Feb 10 20:53:09 2011 -0800
+++ b/include/libpc/Field.hpp Thu Feb 10 21:46:18 2011 -0800
@@ -37,6 +37,7 @@
#include <vector>
#include <string>
+#include "libpc/export.hpp"
namespace libpc
diff -r 605c80e02696 -r 46b2d79f3ae6 include/libpc/MosaicFilter.hpp
--- a/include/libpc/MosaicFilter.hpp Thu Feb 10 20:53:09 2011 -0800
+++ b/include/libpc/MosaicFilter.hpp Thu Feb 10 21:46:18 2011 -0800
@@ -39,8 +39,11 @@
+namespace libpc
// removes any points outside of the given range
-class MosaicFilter : public Filter
+class LIBPC_DLL MosaicFilter : public Filter
public:
MosaicFilter(Stage& prevStage, Stage& prevStage2);
@@ -54,4 +57,6 @@
MosaicFilter(const MosaicFilter&); // not implemented
+}; // namespace libpc
#endif
diff -r 605c80e02696 -r 46b2d79f3ae6 include/libpc/Range.hpp
--- a/include/libpc/Range.hpp Thu Feb 10 20:53:09 2011 -0800
+++ b/include/libpc/Range.hpp Thu Feb 10 21:46:18 2011 -0800
@@ -40,13 +40,13 @@
-class Range
+class LIBPC_DLL Range
public:
T minimum;
T maximum;
Range(T mmin=(std::numeric_limits<T>::max)(), T mmax=(std::numeric_limits<T>::min)())
: minimum(mmin), maximum(mmax) {}
@@ -106,7 +106,7 @@
bool empty(void) const
- return Utils::compare_distance(minimum, (std::numeric_limits<T>::max)()) && compare_distance(maximum, (std::numeric_limits<T>::min)());
+ return Utils::compare_distance(minimum, (std::numeric_limits<T>::max)()) && Utils::compare_distance(maximum, (std::numeric_limits<T>::min)());
void shift(T v)
diff -r 605c80e02696 -r 46b2d79f3ae6 include/libpc/Utils.hpp
--- a/include/libpc/Utils.hpp Thu Feb 10 20:53:09 2011 -0800
+++ b/include/libpc/Utils.hpp Thu Feb 10 21:46:18 2011 -0800
@@ -37,9 +37,12 @@
#include <cassert>
#include <limits>
+namespace libpc
-class Utils
+class LIBPC_DLL Utils
public:
static double random(double min, double max)
@@ -70,5 +73,6 @@
#endif
diff -r 605c80e02696 -r 46b2d79f3ae6 include/libpc/export.hpp
--- a/include/libpc/export.hpp Thu Feb 10 20:53:09 2011 -0800
+++ b/include/libpc/export.hpp Thu Feb 10 21:46:18 2011 -0800
@@ -54,7 +54,8 @@
#endif
#ifdef _MSC_VER
-//#pragma warning(disable:4251 4275)
+#pragma warning(disable:4251)// [templated class] needs to have dll-interface...
+//#pragma warning(disable:4275)
#endif // _MSC_VER
#endif // LIBPC_HPP_INCLUDED
diff -r 605c80e02696 -r 46b2d79f3ae6 mpg-config.bat
--- a/mpg-config.bat Thu Feb 10 20:53:09 2011 -0800
+++ b/mpg-config.bat Thu Feb 10 21:46:18 2011 -0800
@@ -1,8 +1,8 @@
@echo off
set G="Visual Studio 10 Win64"
-set LIBPC=c:\dev\libpc
-set LASZIP=c:\dev\laszip
+set LIBPC=d:\dev\libpc
+set LASZIP=d:\dev\laszip
set OSGEO4W=C:\OSGeo4W
set OSGEO4W_GDAL=C:\OSGeo4W\apps\gdal-17
set BOOST="C:\Utils\boost_1_45_0"
diff -r 605c80e02696 -r 46b2d79f3ae6 src/Field.cpp
--- a/src/Field.cpp Thu Feb 10 20:53:09 2011 -0800
+++ b/src/Field.cpp Thu Feb 10 21:46:18 2011 -0800
@@ -41,6 +41,8 @@
using std::cout;
using std::endl;
Field::Field() :
m_item(Field::InvalidItem),
diff -r 605c80e02696 -r 46b2d79f3ae6 src/Filter.cpp
--- a/src/Filter.cpp Thu Feb 10 20:53:09 2011 -0800
+++ b/src/Filter.cpp Thu Feb 10 21:46:18 2011 -0800
@@ -34,6 +34,9 @@
#include "libpc/Filter.hpp"
Filter::Filter(Stage& prevStage) :
m_prevStage(prevStage)
diff -r 605c80e02696 -r 46b2d79f3ae6 src/Header.cpp
--- a/src/Header.cpp Thu Feb 10 20:53:09 2011 -0800
+++ b/src/Header.cpp Thu Feb 10 21:46:18 2011 -0800
@@ -39,6 +39,8 @@
using std::cout;
using std::endl;
Header::Header() :
m_numPoints(0)
@@ -68,13 +70,13 @@
More information about the Liblas-commits
