[Liblas-commits] libpc: cleaned up source conventions
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Feb 11 13:14:01 EST 2011
details:   http://hg.liblas.orglibpc/rev/77935e0f953b
changeset: 36:77935e0f953b
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Feb 11 09:22:07 2011 -0800
description:
Subject: libpc: added exceptions and versioning support
details:   http://hg.liblas.orglibpc/rev/6165d4718fc7
changeset: 37:6165d4718fc7
date:      Fri Feb 11 10:13:52 2011 -0800
description:
diffstat:
 apps/pc2pc.cpp               |   15 +-
 include/libpc/Bounds.hpp     |  382 +++++++++++++++++++-----------------------
 include/libpc/Range.hpp      |   85 +++++---
 include/libpc/exceptions.hpp |  126 ++++++++++++++
 include/libpc/version.hpp    |   87 +++++++++
 src/CMakeLists.txt           |    3 +
 src/ColorFilter.cpp          |    2 +-
 src/FauxReader.cpp           |   12 +-
 src/version.cpp              |  132 ++++++++++++++
 9 files changed, 592 insertions(+), 252 deletions(-)
diffs (truncated from 1197 to 300 lines):
diff -r 8dfc2ec4ff27 -r 6165d4718fc7 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Fri Feb 11 08:28:32 2011 -0800
+++ b/apps/pc2pc.cpp	Fri Feb 11 10:13:52 2011 -0800
@@ -10,6 +10,9 @@
 #include <iostream>
+#include "libpc/exceptions.hpp"
+#include "libpc/version.hpp"
 #include "libpc/Bounds.hpp"
 using namespace libpc;
@@ -19,7 +22,17 @@
 int main(int, char* [])
   Bounds<double> bounds(1,2,3,4,5,6);
-  std::cout << bounds;
+  std::cout << bounds << std::endl;
+  int major = LIBPC_VERSION_MAJOR;
+  int minor = LIBPC_VERSION_MINOR;
+  int patch = LIBPC_VERSION_PATCH;
+  int version = LIBPC_VERSION;
+  std::string verstring = LIBPC_VERSION_STRING;
+  std::cout << major << " " << minor << " " << patch << " (" << version << ")" << std::endl;
+  std::cout << " string: " << GetVersion() << std::endl;
   return 0;
 #if 0
diff -r 8dfc2ec4ff27 -r 6165d4718fc7 include/libpc/Bounds.hpp
--- a/include/libpc/Bounds.hpp	Fri Feb 11 08:28:32 2011 -0800
+++ b/include/libpc/Bounds.hpp	Fri Feb 11 10:13:52 2011 -0800
@@ -64,24 +64,22 @@
     typedef typename std::vector< Range<T> > RangeVec;
 private:
-    RangeVec ranges;
+    RangeVec m_ranges;
 public:
     Bounds<T>()
-        ranges.resize(0);
+        m_ranges.resize(0);
     Bounds(Bounds const& other)
-        ranges(other.ranges)
+        : m_ranges(other.m_ranges)
-    Bounds(RangeVec const& rngs)
+    Bounds(RangeVec const& ranges)
-        ranges(rngs)
+        m_ranges(ranges)
@@ -92,15 +90,15 @@
             T maxy,
             T maxz)
-        ranges.resize(3);
+        m_ranges.resize(3);
-        ranges[0].minimum = minx;
-        ranges[1].minimum = miny;
-        ranges[2].minimum = minz;
+        m_ranges[0].setMinimum(minx);
+        m_ranges[1].setMinimum(miny);
+        m_ranges[2].setMinimum(minz);
-        ranges[0].maximum = maxx;
-        ranges[1].maximum = maxy;
-        ranges[2].maximum = maxz;
+        m_ranges[0].setMaximum(maxx);
+        m_ranges[1].setMaximum(maxy);
+        m_ranges[2].setMaximum(maxz);
 #ifdef DEBUG
         verify();
@@ -114,13 +112,13 @@
             T maxy)
-        ranges.resize(2);
+        m_ranges.resize(2);
 #ifdef DEBUG
         verify();
@@ -128,26 +126,26 @@
-////Bounds( const Point& min, const Point& max)
-////    ranges.resize(3);
-////    ranges[0].minimum = min.GetX();
-////    ranges[1].minimum = min.GetY();
-////    ranges[2].minimum = min.GetZ();
-////    ranges[0].maximum = max.GetX();
-////    ranges[1].maximum = max.GetY();
-////    ranges[2].maximum = max.GetZ();
-////#ifdef DEBUG
-////    verify();
-////#endif
+    ////Bounds( const Point& min, const Point& max)
+    ////    m_ranges.resize(3);
+    ////    m_ranges[0].minimum = min.GetX();
+    ////    m_ranges[1].minimum = min.GetY();
+    ////    m_ranges[2].minimum = min.GetZ();
+    ////    m_ranges[0].maximum = max.GetX();
+    ////    m_ranges[1].maximum = max.GetY();
+    ////    m_ranges[2].maximum = max.GetZ();
+    ////#ifdef DEBUG
+    ////    verify();
+    ////#endif
-    T (min)(std::size_t const& index) const
+    T minimum(std::size_t const& index) const
-        if (ranges.size() <= index)
+        if (m_ranges.size() <= index)
             // std::ostringstream msg;
             // msg << "Bounds dimensions, " << ranges.size() <<", is less "
@@ -155,104 +153,70 @@
             // throw std::runtime_error(msg.str());
             return 0;
-        return ranges[index].minimum;
+        return m_ranges[index].minimum();
-    void (min)(std::size_t const& index, T v)
+    void setMinimum(std::size_t const& index, T v)
-            ranges.resize(index + 1);
+            m_ranges.resize(index + 1);
-        ranges[index].minimum = v;
+        m_ranges[index].setMinimum(v);
-    T (max)(std::size_t const& index) const
+    T maximum(std::size_t const& index) const
-            // msg << "Bounds dimensions, " << ranges.size() <<", is less "
+            // msg << "Bounds dimensions, " << m_ranges.size() <<", is less "
             //     << "than the given index, " << index;
             return 0;
-        return ranges[index].maximum;
+        return m_ranges[index].maximum();
-    void (max)(std::size_t const& index, T v)
+    void setMaximum(std::size_t const& index, T v)
-        ranges[index].maximum = v;
+        m_ranges[index].setMaximum(v);
-////liblas::Point (min)() {
-////    liblas::Point p;
-////    try
-////        p.SetCoordinates(ranges[0].minimum, ranges[1].minimum, ranges[2].minimum);
-////    catch (std::runtime_error const& e)
-////        ::boost::ignore_unused_variable_warning(e);
-////        p.SetCoordinates(ranges[0].minimum, ranges[1].minimum, 0);
-////    return p;
-////liblas::Point (max)() {
-////    try
-////        p.SetCoordinates(ranges[0].maximum, ranges[1].maximum, ranges[2].maximum);
-////        p.SetCoordinates(ranges[0].maximum, ranges[1].maximum, 0);
-////    return p;
-#if 0
-// BUG: what are the semantics of these?
-    T minx() const
-        if (ranges.size() == 0) return 0;
-        return ranges[0].minimum;
-    T miny() const
-        if (ranges.size() < 2) return 0;
-        return ranges[1].minimum;
-    T minz() const
-        if (ranges.size() < 3) return 0;
-        return ranges[2].minimum;
-    T maxx() const
-        return ranges[0].maximum;
-    T maxy() const
-        return ranges[1].maximum;
-    T maxz() const
-        return ranges[2].maximum;
-#endif
+    ////liblas::Point (min)() {
+    ////    liblas::Point p;
+    ////    try
+    ////        p.SetCoordinates(m_ranges[0].minimum, m_ranges[1].minimum, m_ranges[2].minimum);
+    ////    catch (std::runtime_error const& e)
+    ////        ::boost::ignore_unused_variable_warning(e);
+    ////        p.SetCoordinates(m_ranges[0].minimum, m_ranges[1].minimum, 0);
+    ////    return p;
+    ////liblas::Point (max)() {
+    ////    try
+    ////        p.SetCoordinates(m_ranges[0].maximum, m_ranges[1].maximum, m_ranges[2].maximum);
+    ////        p.SetCoordinates(m_ranges[0].maximum, m_ranges[1].maximum, 0);
+    ////    return p;
     inline bool operator==(Bounds<T> const& rhs) const
More information about the Liblas-commits mailing list
