[Liblas-commits] libpc: added Dimension (from liblas)
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Feb 11 14:51:37 EST 2011
details:   http://hg.liblas.orglibpc/rev/c61d04bc7d5b
changeset: 38:c61d04bc7d5b
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Feb 11 11:51:31 2011 -0800
description:
diffstat:
 apps/pc2pc.cpp              |   33 ++-
 include/libpc/Dimension.hpp |  330 ++++++++++++++++++++++++++++++++++++++++++++
 src/CMakeLists.txt          |    2 +
 src/Dimension.cpp           |  163 +++++++++++++++++++++
 4 files changed, 516 insertions(+), 12 deletions(-)
diffs (truncated from 571 to 300 lines):
diff -r 6165d4718fc7 -r c61d04bc7d5b apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Fri Feb 11 10:13:52 2011 -0800
+++ b/apps/pc2pc.cpp	Fri Feb 11 11:51:31 2011 -0800
@@ -14,26 +14,35 @@
 #include "libpc/version.hpp"
 #include "libpc/Bounds.hpp"
+#include "libpc/Dimension.hpp"
 using namespace libpc;
 int main(int, char* [])
-  Bounds<double> bounds(1,2,3,4,5,6);
-  std::cout << bounds << std::endl;
+        Bounds<double> bounds(1,2,3,4,5,6);
+        std::cout << bounds << std::endl;
-  int major = LIBPC_VERSION_MAJOR;
-  int minor = LIBPC_VERSION_MINOR;
-  int patch = LIBPC_VERSION_PATCH;
-  int version = LIBPC_VERSION;
-  std::string verstring = LIBPC_VERSION_STRING;
-  std::cout << major << " " << minor << " " << patch << " (" << version << ")" << std::endl;
-  std::cout << " string: " << GetVersion() << std::endl;
+        int major = LIBPC_VERSION_MAJOR;
+        int minor = LIBPC_VERSION_MINOR;
+        int patch = LIBPC_VERSION_PATCH;
+        int version = LIBPC_VERSION;
+        std::string verstring = LIBPC_VERSION_STRING;
+        std::cout << major << " " << minor << " " << patch << " (" << version << ")" << std::endl;
-  return 0;
+        std::cout << " string: " << GetVersion() << std::endl;
+        Dimension dim("foo", 8);
+        std::cout << dim << std::endl;
+    return 0;
 #if 0
diff -r 6165d4718fc7 -r c61d04bc7d5b include/libpc/Dimension.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/Dimension.hpp	Fri Feb 11 11:51:31 2011 -0800
@@ -0,0 +1,330 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  LAS Dimension implementation for C++ libLAS
+ * Author:   Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_DIMENSION_HPP_INCLUDED
+#define LIBLAS_DIMENSION_HPP_INCLUDED
+#include <string>
+// boost
+#include <boost/property_tree/ptree.hpp>
+#include <boost/cstdint.hpp>
+#include <libpc/version.hpp>
+#include <libpc/export.hpp>
+namespace libpc
+/// Dimension definition
+class LIBPC_DLL Dimension
+public:
+    Dimension(std::string const& name, std::size_t size_in_bits);
+    Dimension& operator=(Dimension const& rhs);
+    Dimension(Dimension const& other);
+    virtual ~Dimension() {}
+    inline std::string const& GetName() const
+        return m_name;
+    /// bits, total logical size of point record, including any custom
+    /// dimensions
+    inline std::size_t GetBitSize() const
+        return m_bit_size;
+    /// bytes, physical/serialisation size of record
+    std::size_t GetByteSize() const;
+    /// The byte location to start reading/writing
+    /// point data from in a composited schema.  liblas::Schema
+    /// will set these values for you when liblas::Dimension are
+    /// added to the liblas::Schema.
+    inline std::size_t GetByteOffset() const
+        return m_byte_offset;
+    inline void SetByteOffset(std::size_t v)
+        m_byte_offset = v;
+    /// The bit location within the byte to start reading data.  liblas::Schema
+    /// added to the liblas::Schema.  This value will be 0 for dimensions
+    /// that are composed of entire bytes.
+    inline std::size_t GetBitOffset() const
+        return m_bit_offset;
+    inline void SetBitOffset(std::size_t v)
+        m_bit_offset = v;
+    /// Is this dimension required by PointFormatName
+    inline bool IsRequired() const
+        return m_required;
+    inline void IsRequired(bool v)
+        m_required = v;
+    /// Is this dimension being used.  A dimension with
+    /// IsActive false may exist as a placeholder in PointFormatName-specified
+    /// dimensions, but have their IsActive flag set to false.  In this
+    /// case, those values may be disregarded.
+    inline bool IsActive() const
+        return m_active;
+    inline void IsActive(bool v)
+        m_active = v;
+    inline std::string GetDescription() const
+        return m_description;
+    inline void SetDescription(std::string const& v)
+        m_description = v;
+    /// Is this dimension a numeric dimension.  Dimensions with IsNumeric == false
+    /// are considered generic bit/byte fields/
+    inline bool IsNumeric() const
+        return m_numeric ;
+    inline void IsNumeric(bool v)
+        m_numeric = v;
+    /// Does this dimension have a sign?  Only applicable to dimensions with
+    /// IsNumeric == true.
+    inline bool IsSigned() const
+        return m_signed;
+    inline void IsSigned(bool v)
+        m_signed = v;
+    /// Does this dimension interpret to an integer?  Only applicable to dimensions
+    /// with IsNumeric == true.
+    inline bool IsInteger() const
+        return m_integer;
+    inline void IsInteger(bool v)
+        m_integer = v;
+    /// The minimum value of this dimension as a double
+    inline double GetMinimum() const
+        return m_min;
+    inline void SetMinimum(double min)
+        m_min = min;
+    /// The maximum value of this dimension as a double
+    inline double GetMaximum() const
+        return m_max;
+    inline void SetMaximum(double max)
+        m_max = max;
+    /// The index position of the index.  In a standard ePointFormat0
+    /// data record, the X dimension would have a position of 0, while
+    /// the Y dimension would have a position of 1, for example.
+    inline boost::uint32_t GetPosition() const
+        return m_position;
+    inline void SetPosition(boost::uint32_t v)
+        m_position = v;
+    /// The scaling value for this dimension as a double.  This should
+    /// be positive or negative powers of ten.
+    inline double GetScale() const
+        return m_scale;
+    inline void SetScale(double v)
+        m_scale = v;
+    /// The offset value for this dimension.  Usually zero, but it
+    /// can be set to any value in combination with the scale to
+    /// allow for more expressive ranges.
+    inline double GetOffset() const
+        return m_offset;
+    inline void SetOffset(double v)
+        m_offset = v;
+    /// If true, this dimension uses scale/offset values
+    inline bool IsFinitePrecision() const
+        return m_precise;
+    inline void IsFinitePrecision(bool v)
+        m_precise = v;
+    inline bool operator < (Dimension const& dim) const
+        return m_position < dim.m_position;
More information about the Liblas-commits mailing list
